Building the designer, Nullpointer in DEUtil.java [message #824922] |
Tue, 20 March 2012 08:39 |
hage Mising name Messages: 67 Registered: September 2011 |
Member |
Hi there,
i checked out the resources via eclipse cvs plugin, and build the designer successfully with the export wizard from the .product-file. The build is successfull and the designer starts on my ubuntu. Clicking the "new" button, selecting the "Report"-entry and clicking "Next>" will generate a NullPointerException in DEUtil like this:
at org.eclipse.core.internal.runtime.FindSupport.findInPlugin(FindSupport.java:232)
at org.eclipse.core.internal.runtime.FindSupport.find(FindSupport.java:99)
at org.eclipse.core.internal.runtime.FindSupport.find(FindSupport.java:60)
at org.eclipse.core.runtime.FileLocator.find(FileLocator.java:84)
at org.eclipse.birt.report.designer.util.DEUtil.getDefaultLibraryHandle(DEUtil.java:3235)
at org.eclipse.birt.report.designer.internal.ui.wizards.WizardTemplateChoicePage.getDefaultLibraryHandleFromResource(WizardTemplateChoicePage.java:1043)
at org.eclipse.birt.report.designer.internal.ui.wizards.WizardTemplateChoicePage.createControl(WizardTemplateChoicePage.java:350)
the line of code which went wrong is:
URL url = FileLocator.find( Platform.getBundle( IResourceLocator.FRAGMENT_RESOURCE_HOST ),
new Path( DEFAULT_LIBRARY ),
null );
DEFAULT_LIBRARY is defined like this:
public static final String DEFAULT_LIBRARY = "/ThemesReportItems.rptlibrary"; //$NON-NLS-1$
i searched the whole repo, but i can't find a file ThemesReportItems.rptlibrary there. what am i missing?
Consequence of this is an empty wizardpage showing up, so i can't create an emtpy / new report.
thx in advance,
hag
[Updated on: Tue, 20 March 2012 08:48] Report message to a moderator
FUDForum. Page generated in 0.03424 seconds
