Re: Servlet ClassNotFound exception [message #825442 is a reply to message #825250] |
Tue, 20 March 2012 21:06 |
Violeta Georgieva Messages: 278 Registered: October 2010 |
Quote:Here is the warning message that the WABHeaders WAS changed:
WE0006W WABHeaders set to 'defaulted' in org.eclipse.virgo.web.properties. This option may not be supported in future releases.
I'll fix the problem with the plain web applications transformation. You can track https://bugs.eclipse.org/bugs/show_bug.cgi?id=354730
Quote:ERROR system-artifacts org.apache.catalina.startup.HostConfig Application base [C:\JavaApps\virgo-tomcat-server-3.0.2.RELEASE\virgo-tomcat-server-3.0.2.RELEASE\webapps] for host [localhost] does not exist or is not a directory. deployOnStartUp and autoDeploy have been set to false to prevent deployment errors. Other errors may still occur.
This is fixed with https://bugs.eclipse.org/bugs/show_bug.cgi?id=360571 in 3.5.0.M01. You should not worry, it's just a log. You can apply the fix on your system - it is in the tomcat-server.xml file.
It's great that everything is working now.
[Updated on: Tue, 20 March 2012 21:07] Report message to a moderator
FUDForum. Page generated in 0.03714 seconds
