Home » Archived » BIRT » How to set the zoom value when rendering in pdf?
How to set the zoom value when rendering in pdf? [message #824543] Mon, 19 March 2012 19:59 Go to next message
Mike Wulkan is currently offline Mike WulkanFriend
If I change the __format=html to __format=pdf I get my report rendered as a pdf and displayed using the browser's pdf plugin.
However the default pdf zoom value seems to vary so I'd like to fix the value myself. I know that when you display a pdf file in the browser directly you can add the zoom= parameter directly but how do you pass this parameter on the BIRT report URL?
Mike
Re: How to set the zoom value when rendering in pdf? [message #824661 is a reply to message #824543] Mon, 19 March 2012 22:58 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Try
http://localhost:8090/3.7.1/frameset?__report=master.rptdesign&__format=pdf&#zoom=100
Jason
> Thanks
> Mike
Re: How to set the zoom value when rendering in pdf? [message #825052 is a reply to message #824661] Tue, 20 March 2012 12:01 Go to previous messageGo to next message
Thanks Jason, but when I try that it isn't parsing anything after the zoom=100 and prompts me for parameters.
I did find a way to set a default zoom level for myself by using the Adobe Reader GUI and then going to preferences and setting the Default Layout and Zoom. However I would still like to be able to set it directly when the page is launched so that all my users won't have to do this additional setup.
Re: How to set the zoom value when rendering in pdf? [message #825234 is a reply to message #825052] Tue, 20 March 2012 16:34 Go to previous messageGo to next message
Mike,
Can you not make the zoom parameter the last one?
Jason
Re: How to set the zoom value when rendering in pdf? [message #825299 is a reply to message #825234] Tue, 20 March 2012 17:46 Go to previous messageGo to next message
Yes that works, thanks.
Re: How to set the zoom value when rendering in pdf? [message #1028519 is a reply to message #825299] Thu, 28 March 2013 11:15 Go to previous messageGo to next message
megha mukim is currently offline megha mukimFriend
Wanted same help regarding the zoom level.
I have a set of reports to be generated but when exported as pdf except two rpts all are zoomed to 100%. how to set the zoom level for the remaining two, though I haven't set the level for any of the rpt yet.
Thanks for the help in advance.
Re: How to set the zoom value when rendering in pdf? [message #1029754 is a reply to message #1028519] Sat, 30 March 2013 04:50 Go to previous message
Did you add the zoom parameter?
Previous Topic:PDFRender - OutputStream not closed ?
Next Topic:Change library inheritance in rptdesign
Current Time: Sun Sep 24 05:08:20 GMT 2023
Powered by FUDForum. Page generated in 0.03369 seconds
