Home » Eclipse Projects » GEF » How can i draw a connection with lables?
How can i draw a connection with lables? [message #100740] Mon, 20 October 2003 02:23 Go to next message
Originally posted by: eeoo_lee.hotmail.com
I want to use some lables to descirbe the realtionship between the source
and target model.I intend to place the labels on the connetion which can
move together with the connection. How can I do that?
Thanks!
Re: How can i draw a connection with lables? [message #101059 is a reply to message #100740] Mon, 20 October 2003 12:05 Go to previous messageGo to next message
This is how I did it:
1. My own class LabeledPolylineConnection extends PolylineConnection.
2. In the constructor, it creates a Label.
3. Because PolylineConnection uses DelegatingLayout, I add the label
as a child with a Locator constraint: add(label, new LabelLocator());
3. The LabelLocator class implements Locator; it computes and sets
the label's bounds based on the connection's start and end points.
-JPL
Re: How can i draw a connection with lables? [message #101071 is a reply to message #100740] Mon, 20 October 2003 12:53 Go to previous messageGo to next message
There is an article that shows how to do this in draw2d. The link is off
the GEF homepage.
"lianglee" <eeoo_lee@hotmail.com> wrote in message
news:bmvv06$bo9$1@eclipse.org...
> Thanks!
Re: How can i draw a connection with lables? [message #101180 is a reply to message #101059] Mon, 20 October 2003 23:20 Go to previous messageGo to next message
> -JPL
Thanks for your reply ,but I still have a question. The label I want to
creat e is an editable one. I don't know the label on the connection in
your case is a figure or a model? If it's a figure,can it be edited on
the connection?
Re: How can i draw a connection with lables? [message #101193 is a reply to message #101180] Mon, 20 October 2003 23:31 Go to previous message
Even if there is no model, you can still create an editpart for the label.
This has been discussed before, but one solution is to use a spurious model
object. Perhaps a tuple consising of the connection model object and some
string.
Once you have an editpart, everything else is easier.
news:bn28mq$jvg$1@eclipse.org...
> Jan Ploski wrote:
source
can
> > -JPL
> the connection?
Previous Topic:NullPointerException at org.eclipse.gef.ui.parts.GraphicalEditor.getCommandStack(GraphicalEditor.ja
Next Topic:what's the process of a container adding an element
Current Time: Wed Nov 05 07:46:52 EST 2025
Powered by FUDForum. Page generated in 0.05854 seconds
