Re: Adobe Flash Builder plugin for eclipse [message #820872 is a reply to message #820855] |
Wed, 14 March 2012 17:14   |
On 3/14/2012 10:54 AM, Smita Tendulkar wrote:
> Hello,
> Is there any Adobe Flash Builder plugin available for Eclipse Indigo? If
> so, how do I install it?
> I have Windows 7 (64-bit) machine with Eclipse Indigi already installed
> on it. I have already created workspace for my Java project and it has a
> flex component that I will need to work on now. I do not wish to install
> Adobe flash Builder separately (it will unnecessarily complecate the
> things!!!) and hence keen to know if any Adobe Flash Builder plugin is
> available for eclipse Indigo?
> Any help/suggestion appreciated.
> Thanks :)
Since Eclipse doesn't create or maintain Flex tools for use with
Eclipse, this is a matter you should take up with Adobe or its developer
community instead.
Re: Adobe Flash Builder plugin for eclipse [message #917094 is a reply to message #917083] |
Wed, 19 September 2012 20:14   |
On 9/19/2012 2:02 PM, Sridhar Goranti wrote:
> Hello,
> Even I am looking for Adobe Flash Builder plugin for Eclipse Indigo and
> plugins to run my java web applications from Adobe Flash Builder 3.
> Any help/suggestion appreciated here.
> Thanks & Regards,
> Sridhar Goranti
If you are having trouble finding, installing or using the Adobe Flash
Builder development tools, you should be aware that they are written on
top of the Eclipse platform by the Adobe community and not by the
eclipse.org community.
You can wait here for someone who happens to know if you like.
I found a lot of promising links by Googling "flash builder eclipse
plugins".
FUDForum. Page generated in 0.02886 seconds
