Home » Archived » BIRT » Set a global variable using report parameter(Which event must be handled in order to have the parameter already set?)
Set a global variable using report parameter [message #820661] Wed, 14 March 2012 08:03 Go to next message
I want to read a report parameter and, basing on its value, create some derived variables to be put in the report context:
reportContext.setGlobalVariable("global_refdate", params["refdate"].value);
The final goal is to use these variables inside dynamic text elements, report header/footer, ...
The problem is that I can't understand where to put the script, because I don't know when the parameter is evaluated (and not null) during the report generation.
I've put it in many event handler scripts of the report element:
initialize
before factory
after factory
but the global variable is always null when I'm trying to use it with:
reportContext.getPersistentGlobalVariable("global_refdate");
Can someone help me, please?
Thanks in advance...
Re: Set a global variable using report parameter [message #820768 is a reply to message #820661] Wed, 14 March 2012 10:47 Go to previous messageGo to next message
A friend suggested me the solution: I was not setting the variable as "Persistent".
WRONG --> reportContext.setGlobalVariable("global_refdate", params["refdate"].value);
CORRECT --> reportContext.setPersistentGlobalVariable("global_refdate", params["refdate"].value);
Now it seems working, by putting the script in the initialize event handler of report component.
Thanks anyway...
Re: Set a global variable using report parameter [message #821037 is a reply to message #820661] Wed, 14 March 2012 17:35 Go to previous messageGo to next message
The beforeFactory is ideal. Are you setting global variable like:
setPersistentGlobalVariable or using setGlobalVariable?
the get must match.
Jason
> report generation.
> initialize
> before factory
> after factory
Re: Set a global variable using report parameter [message #831941 is a reply to message #821037] Thu, 29 March 2012 10:51 Go to previous message
I will try with "beforeFactory"...
Previous Topic:Data set expressions and design element expressions
Next Topic:Problems with hyperlinks on images/report designer
Current Time: Tue Nov 04 08:39:28 EST 2025
Powered by FUDForum. Page generated in 0.04281 seconds
