Remove the diagram file only [message #819767] |
Tue, 13 March 2012 09:55 |
when I right delete a .di file, the .uml corresponding file is also automatically removed. I think it is an incorrect behavior because the model can exists without the diagram.
Is there a way to remove the .di file only?
Thank you.
I use Papyrus 0.8.2 on Eclipse 3.7.1.
Re: Remove the diagram file only [message #820791 is a reply to message #820783] |
Wed, 14 March 2012 15:13 |
Camille Letavernier >
True :The "filters" option is in the *Project* explorer, not in the *Model* explorer.
But I don't found the "Di View" option.
See the new screenshot attached.
How can I get this Di view option?
Re: Remove the diagram file only [message #821314 is a reply to message #820821] |
Thu, 15 March 2012 07:34 |
Oops.
Ok now on the correct view: I can uncheck the "Di view" option.
Now, the di files are not agregated[1] bellow a common parent.
But it doesn't resolve my problem : when I delete the ".di" file, the ".uml" is automatically removed!
Thank you.
[1]agregated : my firefox dictionary tells me to put 2 "g" to agregated like this "aggregated" and I see only one "g" in the description of the "Di view" option), probably a spelling error to report.
[Updated on: Thu, 15 March 2012 07:38] Report message to a moderator
FUDForum. Page generated in 0.04381 seconds
