Home » Language IDEs » ServerTools (WTP) » no static resources in running tomcat
no static resources in running tomcat [message #819708] Tue, 13 March 2012 04:25 Go to next message
I have faceted wtp project with maven (org.eclipse.wst.common.project.facet.core.nature). I found that in latest 3.3.2 my static resources eg: html files are not copied into server environment (.metadata\.plugins\org.eclipse.wst.server.core\), web.xml and other configurations are copied. Any additional configuration required?
Re: no static resources in running tomcat [message #820035 is a reply to message #819708] Tue, 13 March 2012 12:39 Go to previous message
I don't use maven, so I can't comment on how well it does or doesn't
integrate with WTP in various use cases. If something that should be
publishing and isn't, then it's most likely in the Deployment Assembly
page in the project's Properties dialog where something is missing. I
know you can specify that certain project folder in a Dynamic Web
Project should be included in the published Web application.
Larry
Previous Topic:Why are web editors read-only?
Next Topic:[resolved]
Current Time: Thu Sep 25 06:44:58 EDT 2025
Powered by FUDForum. Page generated in 0.06048 seconds
