Home » Archived » M2M (model-to-model transformation) » [ATL] Changing UML Property Datatype
[ATL] Changing UML Property Datatype [message #100158] |
Wed, 18 February 2009 11:38 |
Ronan B Messages: 273 Registered: July 2009 |
I'm attempting to change all of a source models's UML properties from
unset to a UML PrimitiveType of String in the target model.
The transformation I have written seems to do this but the underlying XMI
is totally different to that of a property type set using the UML editor.
Basically the type being set using my transformation isn't the proper UML2
PrimitiveType. I need the types to be set properly.
My transform is as follows...
module SetDefaultAttributeTypes; -- Module Template
create OUT : UML refining IN : UML;
rule AssignDataTypeToProperty
from
s : UML!Property
s.name.equals('test')
to
out : UML!Property
name <- s.name.debug(),
isLeaf <- s.isLeaf,
isStatic <- s.isStatic,
isOrdered <- s.isOrdered,
isUnique <- s.isUnique,
isReadOnly <- s.isReadOnly,
isDerived <- s.isDerived,
isDerivedUnion <- s.isDerivedUnion,
eAnnotations <- s.eAnnotations,
ownedComment <- s.ownedComment,
clientDependency <- s.clientDependency,
nameExpression <- s.nameExpression,
datatype <- pt,
upperValue <- s.upperValue,
lowerValue <- s.lowerValue,
templateParameter <- s.templateParameter,
end <- s.end,
deployment <- s.deployment,
redefinedProperty <- s.redefinedProperty,
defaultValue <- s.defaultValue,
subsettedProperty <- s.subsettedProperty,
association <- s.association,
qualifier <- s.qualifier
pt : UML!DataType
name <- 'String'
As you can see i'm using the refining mode of ATL 3.0. This shouldn't
matter in the context of my fundamental problem. Any help appreciated!
Ronan
Re: [ATL] Changing UML Property Datatype [message #100186 is a reply to message #100158] |
Wed, 18 February 2009 12:38 |
Tristan Faure Messages: 460 Registered: July 2009 |
Hi i don't really know to do that but "i think"
1) it's normal it's not the same as uml editor because you create a new
data type for each property
2) the simplest solution you create once the data type in model rule for
example and you reference it in other rule (resolveTemp)
3) if you want to use data type from UML2 Primitive type it's here that
i'm not sure. you should have two input model, your uml and the
primitive types. and you should create a helper getting the
corresponding type in second uml file and maybe you should use eSet
function of ATL (@see wiki for use)
Ronan a écrit :
> XMI is totally different to that of a property type set using the UML
> editor. Basically the type being set using my transformation isn't the
> proper UML2 PrimitiveType. I need the types to be set properly.
> from s : UML!Property
> to
> out : UML!Property
> isLeaf <- s.isLeaf,
> datatype <- pt,
> end <- s.end,
> pt : UML!DataType
> name <- 'String'
> Ronan
Re: [ATL] Changing UML Property Datatype [message #100359 is a reply to message #100293] |
Thu, 19 February 2009 14:56 |
Just to follow up on this.
I have got the primitive types in the source model now by loading in the
types as a second input model [see
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg02239.html ].
I have a skeleton rule to build these in the output model..
rule CopyTypes
from s : UML!PrimitiveType
to t : UML!PrimitiveType
However I get an error when I refer to this rule using resolveTemp. I do
the following
type <- thisModule.resolveTemp(s.type,'tx') or
type <- thisModule.resolveTemp(UML!PrimitiveType,'tx')
The compiler complains that the first param is OclUndefined, which it is
in the source model. It is undefined as it is unset, this is the purpose
of my transform i.e. to set this to a datatype in the target model. Any
ideas?
The error in full is...
Operation not found:
OclUndefined.getNamedTargetFromSource(org.eclipse.emf.ecore. impl.EClassImpl,java.lang.String)
ATL VM Stack:
main: #24
local variables: self=thisModule
__exec__: #48
local variables: self=thisModule,
e=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@10b086ea
__applyCopyPropertyWithoutType: 189:11-189:57#200
link=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@10b086ea,
s=org.eclipse.uml2.uml.internal.impl.PropertyImpl@2d7a9077 (name:
SubNetworkId, visibility: protected) (isLeaf: false) (isStatic: false)
(isOrdered: false, isUnique: true, isReadOnly: false) (isDerived: false,
isDerivedUnion: false, aggregation: none),
t=org.eclipse.uml2.uml.internal.impl.PropertyImpl@290c06c3 (name:
SubNetworkId, visibility: <unset>) (isLeaf: false) (isStatic: false)
xx=org.eclipse.uml2.uml.internal.impl.PrimitiveTypeImpl@35697535 (name:
<unset>, visibility: <unset>) (isLeaf: false, isAbstract: false)
resolveTemp: #6
value=org.eclipse.emf.ecore.impl.EClassImpl@6013a567 (name: PrimitiveType)
(instanceClassName: null) (abstract: false, interface: false), name=tx
Re: [ATL] Changing UML Property Datatype [message #100386 is a reply to message #100359] |
Thu, 19 February 2009 15:52 |
I think it's what i said in previous post
maybe you should use Primitive type as input and do not to try to
transform it and maybe:
use this statement type <-
UML!PrimitiveType.allInstancesFrom('IN')->select(...Integer)
> rule CopyTypes
> from s : UML!PrimitiveType to t : UML!PrimitiveType (
> the following
> type <- thisModule.resolveTemp(s.type,'tx') or type <-
> ideas?
> ATL VM Stack:
> main: #24 local variables: self=thisModule
> __exec__: #48 local variables: self=thisModule,
> __applyCopyPropertyWithoutType: 189:11-189:57#200 local variables:
> self=thisModule,
> resolveTemp: #6 local variables: self=thisModule,
> PrimitiveType) (instanceClassName: null) (abstract: false, interface:
> false), name=tx
Re: [ATL] Changing UML Property Datatype [message #100455 is a reply to message #100386] |
Fri, 20 February 2009 14:45 |
Yep thanks for that. In fact you need a few things to get this working.
1) You must take the primitive types in as an extra input model. In my
case called INTYPES : UML
2) You must write a rule to copy all these types to the target
rule CopyTypes
collaborationUse <- s.collaborationUse,
elementImport <- s.elementImport,
general <- s.general,
generalization <- s.generalization,
isAbstract <- s.isAbstract,
isLeaf <- s.isLeaf,
ownedAttribute <- s.ownedAttribute,
ownedOperation <- s.ownedOperation,
ownedRule <- s.ownedRule,
ownedTemplateSignature <- s.ownedTemplateSignature,
ownedUseCase <- s.ownedUseCase,
owningTemplateParameter <- s.owningTemplateParameter,
package <- s.package,
packageImport <- s.packageImport,
powertypeExtent <- s.powertypeExtent,
redefinedClassifier <- s.redefinedClassifier,
representation <- s.representation,
substitution <- s.substitution,
templateBinding <- s.templateBinding,
useCase <- s.useCase,
visibility <- s.visibility
3) Write a helper to manager the type mapping e.g. String, Integer etc
helper def : mapTypes(in_type : UML!PrimitiveType) : UML!PrimitiveType =
if in_type.oclIsUndefined()
then
UML!PrimitiveType.allInstancesFrom('INTYPES')->select(e|e.name =
'String')->at(1)
endif;
This is an example I will rewrite this helper as a map later.
4) Assign the type to the UML!Property type attribute
type <- thisModule.resolveTemp(thisModule.mapType(s.type),'t')
It seems rather complex but this is the only way i could get this working.
Thanks for all the help and pointers :)
Ronan
Re: [ATL] Changing UML Property Datatype [message #520166 is a reply to message #100455] |
Thu, 11 March 2010 12:23 |
Michael Messages: 2 Registered: March 2010 |
hi Ronan,
which model did you takte as input for primitive types? Can't find the right one on the Internet..
Thanks!
Michael
Ronan wrote on Fri, 20 February 2009 09:45 | Hi,
rule CopyTypes
isLeaf <- s.isLeaf,
then
'String')->at(1)
endif;
Ronan
Current Time: Sat Apr 27 01:30:51 GMT 2024
Powered by FUDForum. Page generated in 0.03598 seconds
