Home » Archived » EPP » Build custom package
Re: Build custom package [message #9099 is a reply to message #9075] |
Tue, 24 June 2008 18:45 |
Originally posted by: mknauer.innoopract.com
See answers below...
Marco Maccaferri wrote:
> I'm playing with EPP these days to build a custom package. It generally
> works, however I can't get the update manager to work. From Help ->
> Software Updates I get the following message:
> Cannot launch the update UI. The installation has not been configured
> property for software updates.
So you are able to start and to run the created package? That doesn't sound
too bad.
> This seems true since the built package doesn't contains the p2 and
> dropins folders, nor it contains the p2-related folders under the
> configuration folder.
That is interesting - there seem to be something missing.
> My guess is that I'm not using the correct root files, but since the
> configuration files points to a local folder, I don't know how to get
> the correct files. Also I think that there are some files that needs to
> be generated rather than copied, but doesn't seems that there is a way
> to generate these files.
Maybe... are you using the 'root' files from the Eclipse Platform team? Such
as the platform download like this one for RC4? E.g. the file
eclipse-platform-3.4RC4-win32.zip from
http://ganymede-mirror1.eclipse.org/eclipse/downloads/drops/ S-3.4RC4-200806091311/download.php?dropFile=eclipse-platform -3.4RC4-win32.zip
> What am I missing ?
I suggest opening a bug and attaching the EPP configuration file to it. Then
we can have a look...
> Regards,
> Marco.
Re: Build custom package [message #9119 is a reply to message #9099] |
Wed, 25 June 2008 08:16 |
Marco Maccaferri Messages: 147 Registered: July 2009 |
> too bad.
Yes, the created package works well, except for the update manager.
Yes, I tried with that file, however, I get errors about what looks like
conflicting packages, such as:
Bundle org.eclipse.help_3.3.100.v20080515 failed to resolve.:
Another singleton version selected: org.eclipse.help_3.3.100.v20080610
I guess that the features and plugins contained in the zipped file are
conflicting with the plugins downloaded from the repository.
After removing the features and plugins folders from the zipped file,
the package build works well, however the product doesn't activate the
additional features (the features that were not included with the root
files package). I guess that the p2 files are not updated with the
additional features and the original set was unchanged, making the
product unusable.
Well, since eclipse 3.4 is released today, I'll wait a bit and try to
build a package with the stable 3.4 files, just is case.
Anyway, you can confirm that the EPP build should create all required
files automatically ? There isn't any additional step to do, right ?
Marco.
Re: Build custom package [message #577424 is a reply to message #9075] |
too bad.
> What am I missing ?
> Regards,
> Marco.
Twitter: @mknauer23 and @EclipseRAP
Re: Build custom package [message #577441 is a reply to message #9099] |
> too bad.
product unusable.
Marco.
Current Time: Fri Apr 26 12:04:11 GMT 2024
Powered by FUDForum. Page generated in 0.03434 seconds
