AUT launches, unable to observe or collect technical names [message #817033] |
Fri, 09 March 2012 14:59 |
Robert Barnard Messages: 10 Registered: March 2012 Location: Sandy Springs, GA, USA |
As I am new to Jubula, this posting is as much informational as it is a query for help.
I am experiencing two different behaviors between the Jubula ITE and "Eclipse for Testers IDE", using the same project (which was written in the ITE), with our product as the AUT.
The Jubula ITE is able to create test specifications and start a AUT, but was not able to collect technical names ("green frame" no where to be seen) or record actions in the Observation view. The AUT did have the RC-RCP plugin installed, including a listing in the "configuration/config.ini" (and no phantom/unseen blank spaces existed in the file).
The "Eclipse for Testers IDE" is able to bring up the same test project, launch the same AUT and the green frame displays upon entering Object Mapping mode and hovering over parts of the AUT. It also records actions in Observer. It has not collected any technical names in the "Unassigned technical names" view as I would expect.
My first thought was that I had applied the wrong version of the plugin to the AUT (ie if there were a difference between the RC-RCP plug in from the ITE vs IDE). But there doesn't appear to be a difference since the plugin I applied is from the ITE and seems to be working with the Eclipse for Testers IDE.
So baring a mix-up with the plugin(s), it seems the Jubula ITE (from my experience) is somewhat broken or, at least, operates differently than the test mode of "Eclipse for Testers" IDE. I am not concerned about using one tool versus the other as long as I can create and run tests.
However, I have yet to accomplish mapping of component to technical names on the test, then run it. This is my focus for today.
As always, any observations, comments, questions, and/or suggestions are appreciated.
Thank you
FUDForum. Page generated in 0.02911 seconds
