Re: Can't get Eclipse to start [message #816317 is a reply to message #816298] |
Thu, 08 March 2012 17:42 |
On 3/8/2012 10:08 AM, J. P. wrote:
> I have a new Windows 7 64-bit machine, but I cannot get Eclipse to start
> up properly.
> [snip]
Since you're running Windows 64-bit...
Ensure you've downloaded 64-bit Eclipse package and, if you're going to
do Java development, a proper Sun JDK that is also 64-bit from
java.sun.com -> Downloads -> Popular Downloads. 1.6.0_31 is good, but it
should be a JDK not merely a JRE if you're going to do Java development.
(If doing C/C++, PHP, or other non-Java, it's probably not going to be
useful; you only need a JRE to run Eclipse itself.)
Next, example http://wiki.eclipse.org/Eclipse.ini for what should be in
your eclipse.ini file.
FUDForum. Page generated in 0.30876 seconds
