Home » Modeling » TMF (Xtext) » Using Xtext and Xtend
Using Xtext and Xtend [message #816120] Thu, 08 March 2012 07:54 Go to next message
I read Xtend User Guide and examine Xtend examples but I could not decide where to start. I defined my own DSL with Xtext. Now I want to complete a textual editor. With the help of defined Xtext a grammer a user can create an instance model. I want to put some constraints to this model. For example, there is an element with type type1. I want to constraint the user to create only two instance elementes of type1.
For example:
main: (type1|type2)*
type1: name=ID;
type2: name=ID;
instance model:
type1instance1;
type1instance2;
If the user creates one more type, the editor must give an error.
I want to do such constraints and I could not decide what must I do. Can I supply it with Xtend. If yes how? Is there any documentation except Xtend User Guide?
Thank you very much.
Re: Using Xtext and Xtend [message #816354 is a reply to message #816120] Thu, 08 March 2012 13:54 Go to previous messageGo to next message
i am not quite sure what this has to do with Xtend. Yes you could write the Validator using Xtend but it will work with Java as well
to get an idea where to start with validation have a look at
http://www.eclipse.org/Xtext/documentation/2_1_0/060-validation.php
~Christian
Re: Using Xtext and Xtend [message #849578 is a reply to message #816354] Thu, 19 April 2012 05:12 Go to previous messageGo to next message
I can not find any samples for my question. Does anyone can give me a simple example about these constraints? How can I strict the user to define a specific number of instances with Validation Package?
Thanks.
Re: Using Xtext and Xtend [message #849643 is a reply to message #849578] Thu, 19 April 2012 06:27 Go to previous messageGo to next message
if your grammar is like:
Main: elements += (Type1|Type2)* ;
Type1: 'type1' name=ID ';' ;
Type2: 'type2' name=ID ';' ;
Your check function in Validator could look like:
@Check
public void checkOnlyTwoInstancesOfType1(Type1 type1){
	Main main = EcoreUtil2.getContainerOfType(type1, Main.class);
	List<Type1> type1s = EcoreUtil2.getAllContentsOfType(main, Type1.class);
	if(type1s.size()>2){
		error("Too many Type1 objects", MyDslPackage.Literals.TYPE1__NAME);
Michal
Re: Using Xtext and Xtend [message #849699 is a reply to message #849643] Thu, 19 April 2012 07:27 Go to previous messageGo to next message
Thank you very much for your answer. I added your solution to my validation package but now I got some new errors:
Main cannot be resolved to a type
List cannot be resolved to a type
Re: Using Xtext and Xtend [message #849708 is a reply to message #849699] Thu, 19 April 2012 07:34 Go to previous messageGo to next message
You need to import necessary packages...
import java.util.List;
import org.eclipse.xtext.EcoreUtil2;
import org.eclipse.xtext.validation.Check;
import org.xtext.example.mydsl.myDsl.Main;
import org.xtext.example.mydsl.myDsl.MyDslPackage;
import org.xtext.example.mydsl.myDsl.Type1;
Suggestion: Use editor code completion! It adds your imports automatically...
Michal
Re: Using Xtext and Xtend [message #849731 is a reply to message #849708] Thu, 19 April 2012 08:04 Go to previous messageGo to next message
I am using auto completion, only import org.xtext.example.mydsl.myDsl.Main was missing but when I import it, I received another error:
The import org.xtext.example.mydsl7.myDsl.Main cannot be resolved
I think sth is missing but I couldn't understand
Thank you,
Re: Using Xtext and Xtend [message #849736 is a reply to message #849731] Thu, 19 April 2012 08:07 Go to previous messageGo to next message
You have to use your package to import. org.xtext.example.mydsl.myDsl is my one ...
Re: Using Xtext and Xtend [message #849747 is a reply to message #849736] Thu, 19 April 2012 08:17 Go to previous messageGo to next message
I am sorry but again the same problem. I am writing my grammer from the start:
My .xtext file:
grammar org.xtext.example.mydsl7.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl ".../example/mydsl7/MyDsl"
type1: name=ID;
type2: name=ID;
MyDslJavaValidator.java:
package org.xtext.example.mydsl7.validation;
import org.xtext.example.mydsl7.myDsl.MyDslPackage;
import org.xtext.example.mydsl7.myDsl.Plan;
import org.xtext.example.mydsl7.myDsl.Main;
@Check
My problems:
1. The import org.xtext.example.mydsl7.myDsl.Main cannot be resolved
2.Multiple markers at this line
- Main cannot be resolved to a type
- Bound mismatch: The generic method getContainerOfType(EObject, Class<T>) of type EcoreUtil2 is not applicable for the arguments (Plan,
Class<Main>). The inferred type Main is not a valid substitute for the bounded parameter <T extends EObject>
3.The method error(String, Integer) in the type AbstractDeclarativeValidator is not applicable for the arguments (String, EAttribute)
Re: Using Xtext and Xtend [message #849761 is a reply to message #849747] Thu, 19 April 2012 08:31 Go to previous messageGo to next message
the errors occur as the method I sent you is applicable for the grammar, which I sent you. Certainly, if you use other grammar, you need to adjust the method...
Btw. your grammar does not look valid...
Michal
Re: Using Xtext and Xtend [message #849773 is a reply to message #849761] Thu, 19 April 2012 08:44 Go to previous messageGo to next message
I am sorry, I copied oldest version of the grammer. The existing grammer in my Xtext is as you sent me. I mean the grammer is:
now. But the others are same. I mean I have the same problems that I sent you above.
Thank you very much for your patient, I realy have to solve this problem. Thank you.
Re: Using Xtext and Xtend [message #849777 is a reply to message #849773] Thu, 19 April 2012 08:50 Go to previous messageGo to next message
Have you run your MWE2 Workflow after you changed grammar?
You have to import "Main" from your package.
Michal
Re: Using Xtext and Xtend [message #849784 is a reply to message #849777] Thu, 19 April 2012 08:55 Go to previous messageGo to next message
I didn't run the MW2 Workflow because validator package is giving errors.
I added this:
But it says : The import org.xtext.example.mydsl7.myDsl.Main cannot be resolved
It seems like I have to have a Main class or interface.
Re: Using Xtext and Xtend [message #849794 is a reply to message #849784] Thu, 19 April 2012 09:04 Go to previous messageGo to next message
Ignore the errors in validator. Just run the MWE2 Workflow! Main interface will be generated...
Re: Using Xtext and Xtend [message #849808 is a reply to message #849794] Thu, 19 April 2012 09:15 Go to previous messageGo to next message
I run it but nothigg has changed. "Main" and "error" keyword are giving errors. It says tho change type of TYPE1__NAME to Integer
Re: Using Xtext and Xtend [message #849828 is a reply to message #849808] Thu, 19 April 2012 09:37 Go to previous messageGo to next message
Are all following files: Main.java, MyDslFactory.java, MyDslPackage.java, Type1.java, Type2.java present in your src-gen folder (in org.xtext.example.mydsl7.myDsl package?)
If yes, the classes must be available in Validator.
If not, generation failed. There must be something wrong in your grammar or in workflow.
Michal
[Updated on: Thu, 19 April 2012 09:38] by Moderator
Re: Using Xtext and Xtend [message #849835 is a reply to message #849828] Thu, 19 April 2012 09:44 Go to previous messageGo to next message
Main.java doesn't exist. in my src-gen folder. My grammer seems correct maybe I have to change sth on my workflow file.
Re: Using Xtext and Xtend [message #849839 is a reply to message #849835] Thu, 19 April 2012 09:49 Go to previous messageGo to next message
The default works perfect on my site. Just right click on the GenerateMyDsl.mwe2 -> Run as -> MWE2 Workflow and Proceed with lunch ... If there is any error, you should see it in the Console output.
Michal
Re: Using Xtext and Xtend [message #849843 is a reply to message #849835] Thu, 19 April 2012 09:49 Go to previous messageGo to next message
hi,
in xtext 2.2. you have to change the workflow to get the main
fragment = generator.GeneratorFragment {
generateMwe = false
generateJavaMain = true
Re: Using Xtext and Xtend [message #849848 is a reply to message #849843] Thu, 19 April 2012 09:54 Go to previous messageGo to next message
I think he does not need this ... He calls "Main" the first rule in the grammar (entry point...).
Michal
Re: Using Xtext and Xtend [message #849849 is a reply to message #849843] Thu, 19 April 2012 09:56 Go to previous messageGo to next message
Can I add them directly to the workflow or is there sth else to add more? (There are some errors after these additions.)
Re: Using Xtext and Xtend [message #849851 is a reply to message #849849] Thu, 19 April 2012 09:58 Go to previous messageGo to next message
which xtext version do you use?
~Christian
Re: Using Xtext and Xtend [message #850103 is a reply to message #849851] Thu, 19 April 2012 15:14 Go to previous messageGo to next message
Xtext version:
Version: 1.0.2.v201102150722 (Eclipse Helios)
Re: Using Xtext and Xtend [message #850112 is a reply to message #850103] Thu, 19 April 2012 15:26 Go to previous messageGo to next message
The is nö Main in this Version - only the Workflow in the Generator Project
Re: Using Xtext and Xtend [message #850601 is a reply to message #850112] Fri, 20 April 2012 02:57 Go to previous messageGo to next message
I added workflow
generateMwe = false
but it still gives errors.
Then which version should I download and where? (Because I always see this version)
I really have to solve this problem:( Thank you very much for your replies.
Re: Using Xtext and Xtend [message #850610 is a reply to message #850601] Fri, 20 April 2012 03:04 Go to previous messageGo to next message
i somehow lost the overview whatb your actual problem is.
as i said: you need Xtext 2.0 for that
~Christian
Re: Using Xtext and Xtend [message #850632 is a reply to message #850610] Fri, 20 April 2012 03:29 Go to previous messageGo to next message
My actual problem is I defined a grammer and a user can create a model by regarding this grammer. I want to put some constraints to this grammer. For example, there is an element with type type1. I want to constraint the user to create only two instance elementes of type1. If the user creates one element, editor must give an error.
To do this, I wrote:
@Check
to my validation package but it gives errors.
Re: Using Xtext and Xtend [message #850671 is a reply to message #850632] Fri, 20 April 2012 04:15 Go to previous messageGo to next message
I dowloaded Xtext 2.0.0 and coppied project there.
Now again I have two errors in validation package
My xtext grammer is this:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Agent:
'Agent'
(belief+=Belief | plan+=Plan)*;
Belief:
'Belief' name=ID ;
Plan:
'Plan' name=ID ;
I want to make user to create max two instances of these elements. I mean the insance model can be like this:
Agent
Plan plan1
Plan plan2
or like this:
Belief belief1
Belief belief2
Plan plan1
To supply this constraint, I added htis code to the validation package:
package org.xtext.example.mydsl.validation;
import java.awt.List;
import org.apache.log4j.chainsaw.Main;
import org.eclipse.xtend.typesystem.emf.EcoreUtil2;
import org.xtext.example.mydsl.myDsl.Plan;
public class MyDslJavaValidator extends AbstractMyDslJavaValidator {
@Check
public void checkOnlyTwoInstancesofPlan(Plan plan)
Main main = EcoreUtil2.getContainerOfType(plan, Main.class);
List<Plan> plans = EcoreUtil2.getAllContentsOfType(main, Plan.class);
if(plans.size()>2){
error("Too many Plan objects", MyDslPackage.Literals.PLAN__NAME);
Then, I received these errors:
1.
- The method getContainerOfType(Plan, Class<Main>) is undefined for the type
EcoreUtil2
- Line breakpoint:MyDslJavaValidator [line: 26] -
checkOnlyTwoInstancesofPlan(Plan)
- The type List is not generic; it cannot be parameterized with arguments <Plan>
- The method getAllContentsOfType(Main, Class<Plan>) is undefined for the type
EcoreUtil2
I am realy confused and very sad. I have been tring to solve this problem for 5 days.
Re: Using Xtext and Xtend [message #850675 is a reply to message #850671] Fri, 20 April 2012 04:19 Go to previous messageGo to next message
The List, which you want to use is not java.awt.List but java.util.List
Michal
Re: Using Xtext and Xtend [message #850677 is a reply to message #850675] Fri, 20 April 2012 04:23 Go to previous messageGo to next message
and also you probably want to use Agent.class instead of Main.class (as no Main entity is defined in your grammar and org.apache.log4j.chainsaw.Main is probably not the one you want...)
Do not forget to change Main main ---> Agent main.
Michal
Re: Using Xtext and Xtend [message #850697 is a reply to message #850677] Fri, 20 April 2012 04:39 Go to previous messageGo to next message
I changed them but the problem is,
getContainerOfType, getAllContentsOfType and List aren't defined by editor.
Re: Using Xtext and Xtend [message #850705 is a reply to message #850697] Fri, 20 April 2012 04:49 Go to previous messageGo to next message
import org.eclipse.xtext.EcoreUtil2 instead of org.eclipse.xtend.typesystem.emf.EcoreUtil2
Re: Using Xtext and Xtend [message #850721 is a reply to message #850705] Fri, 20 April 2012 05:05 Go to previous message
Thank you very much!! The problems are fixed !!!!
[Updated on: Fri, 20 April 2012 05:06] by Moderator
Previous Topic:Adding built-in types to the domain model example
Next Topic:Problems with version
Current Time: Thu Sep 25 12:59:08 EDT 2025
Powered by FUDForum. Page generated in 0.06346 seconds
