Re: dropin folder for implementing plugin [message #815728 is a reply to message #815511] |
Thu, 08 March 2012 01:16 |
On 3/7/2012 12:04 PM, Igor Buitendijk wrote:
> Hello;
> I want to install the eclipseuml-installer. People say I need to use the
> dropin folder, but there's no such folder to be found.
> The only folder I have is the plugin folder.
> Have tried to put the jar file into here, but no result after closing
> eclipse en restart the program.
> Does anyone know how I can start using UML diagrams, for my ideas are
> all gone!
> I use version 3.3 many thanks for the help!
It depends on your version of Eclipse. The dropin folder showed up about
the time it became practice not to use plugin (or dropin) for installing
plugins. Maybe Galileo or Helios(?). (You're supposed to use Help ->
Install New Software, but not all plugins are set up to accommodate this.)
So, to answer your question, for Europa (3.3), you use the plugin
subdirectory.
FUDForum. Page generated in 0.08686 seconds
