Re: can you update the derby core plugin version? [message #815485 is a reply to message #814849] |
Wed, 07 March 2012 18:20 |
Does it fail when you delete the 10.5 version? You may also want to
remove the sampledb plugin.
org.eclipse.birt.report.data.oda.sampledb_version
Jason
On 3/6/2012 7:05 PM, Aaron Titus wrote:
> Hello Everyone,
> I recently downloaded the all-in-one indigo eclipse BIRT project
> distribution. I noticed that within the BIRT Project, it automatically
> includes an older (10.5) version of the apache derby core plugin. I
> would like to use the latest version, which is 10.8. I noticed that if
> install the newer plugin versions, then both are present at the same time.
> Which does it use? How can I safely eliminate the older 10.5 derby core
> plugin and use the new 10.8 plugin without breaking BIRT?
> Thank you in Advance, Aaron
Re: can you update the derby core plugin version? [message #817230 is a reply to message #816994] |
Fri, 09 March 2012 20:26 |
Currently the derby plugin is used only for the sample db. I see no
reason why the new one will not work.
Jason
On 3/9/2012 8:55 AM, Aaron Titus wrote:
> Jason Weathersby wrote on Wed, 07 March 2012 13:20
>> Jason
> Well, I was nervous to just remove it and see what happens, that is why
> I made the post here. Since the plugin name is different from the
> default derby one, I want to know if BIRT has some dependency on these
> and if I remove them, will BIRT stop functioning properly?
FUDForum. Page generated in 0.03242 seconds
