Home » Newcomers » Newcomers » why are source files zipped ...
Re: why are source files zipped ... [message #98126 is a reply to message #98097] |
Mon, 29 August 2005 06:18 |
Originally posted by: daniel.rohe.stud.tu-ilmenau.de
Yes you can navigate the source code within Eclipse. Start Eclipse and open
the Plug-in Perspective. There is a second tab Plug-ins on the left side.
This tab provides a list of all installed plug-ins. Click with the right
mouse button on a plug-in and select "Import" -> "Import as binary plug-in".
This action creates a new project in your workspace that links to the
imported plug-in. There you can browse the source code.
Kind regards,
Daniel
"Daniel Gross" <gross@fis.utoronto.ca> schrieb im Newsbeitrag
news:431257C1.90508@fis.utoronto.ca...
> Hello,
> Although not completely new to Java, I am new to Eclipse. I would like to
> study some of the Eclipse source code, while analyzing its architecture.
> After downloading the latest version, i found that the source code, such
> as in the the following folder is stored in a zipped file.
> C:\apps\eclipse-SDK-3.1-win32\eclipse\plugins\org.eclipse.rc p.source.win32.win32.x86_3.1.0\src\org.eclipse.swt.win32.win 32.x86_3.1.0
> Is there a particular reason why this is so? Can i navigate the source
> code from within Eclipse without first unzipping it ...
> appreciating your response,
> Daniel
Re: why are source files zipped ... [message #98171 is a reply to message #98126] |
Mon, 29 August 2005 10:51 |
David Read Messages: 35 Registered: July 2009 |
Member |
Hi Daniel,
That is a very useful tip, but after I have finished browsing the source code, how do I reinstate the plug-in to be external? Can I just remove the new project from my workspace, and Eclipse will revert to external at the next restart?
David.
> Kind regards,
> Daniel
>>Hello,
>>Daniel
Re: why are source files zipped ... [message #98347 is a reply to message #98171] |
Mon, 29 August 2005 16:52 |
Yes, just remove the project from the workspace directory. The project
contains only a reference to the original source code in the
plugins-directory. You don't have to restart Eclipse after removing the
project from the workspace.
Kind regards,
Daniel
"David Read" <DavidRead@gmx.net> schrieb im Newsbeitrag
news:deupc3$90v$1@news.eclipse.org...
> Hi Daniel,
> next restart?
> Best regards,
> David.
>> open the Plug-in Perspective. There is a second tab Plug-ins on the left
>> side. This tab provides a list of all installed plug-ins. Click with the
>> right mouse button on a plug-in and select "Import" -> "Import as binary
>> plug-in". This action creates a new project in your workspace that links
>> to the imported plug-in. There you can browse the source code.
>> Kind regards,
>> Daniel
>>>Hello,
>>>Daniel
Re: why are source files zipped ... [message #98362 is a reply to message #98347] |
Mon, 29 August 2005 16:57 |
Daniel Gross Messages: 18 Registered: July 2009 |
Junior Member |
Is it possible to see the eclipse core source code from within eclipse
also. As far as i understand that part of eclipse is not a pluggin.
thank,
Daniel
> Kind regards,
> Daniel
>>Hi Daniel,
>>next restart?
>>Best regards,
>>David.
>>>Kind regards,
>>>Daniel
>>>>Hello,
>>>>Daniel
Re: why are source files zipped ... [message #98392 is a reply to message #98362] |
Mon, 29 August 2005 18:02 |
What do you mean with Eclipse core? I've read somewhere the philosophy of
Eclipse is "everything is a plug-in". In my plug-in development workspace I
can import every plug-in, even Eclipse core.
Eclipse Core (org.eclipse.core.* - plug-ins)
Eclipse UI (org.eclipse.ui.* - plug-ins)
OSGi Runtime (org.eclipse.osgi.* - plug-ins)
The Eclipse launcher is not a plug-in. But it is only needed to start the
runtime system with a plug-in that contains an application extension. For
more information on this look at the RCP (Rich Client Platform) project. The
source code for the Eclipse launcher can be found in the Eclipse CVS.
Kind regards,
Daniel
news:deveph$7o4$1@news.eclipse.org...
> Hello,
> thank,
> Daniel
>> Kind regards,
>> Daniel
>>>Hi Daniel,
>>>the next restart?
>>>Best regards,
>>>David.
>>>>Kind regards,
>>>>Daniel
>>>>>Hello,
>>>>>to study some of the Eclipse source code, while analyzing its
>>>>>architecture. After downloading the latest version, i found that the
>>>>>source code, such as in the the following folder is stored in a zipped
>>>>>file.
>>>>>Daniel
Current Time: Fri Apr 26 15:59:16 GMT 2024
Powered by FUDForum. Page generated in 0.09646 seconds
