Home » Archived » EGL Development Tools » Cannot use GET with FROM clause within FOREACH
Cannot use GET with FROM clause within FOREACH [message #810818] Thu, 01 March 2012 10:40 Go to next message
Version: 0.8.0.v201202280901-1Co-FjuJ6QMNSP3ynscd8h8C
DedicatedService
Eclipse 3.7.1
Generation Language: Java, JavaScript
Error:
IWN.VAL.6510.e 36/28
The FOREACH SQL I/O statement does not allow the FROM option to be specified more than once.
ds SQLDataSource? {@Resource{uri="binding:SomeValidBinding"}};
function ...
  rs SQLResultSet?;
  open rs from ds using(someParameter) with #sql{
    select * from someTable where someField = ?
  someRecord1 SOMERECORD;
  forEach (someRecord1 from rs)
    someOtherRecord1 SOMEOTHERRECORD { id=someRecord1.ID };
    get someOtherRecord1 from ds; <-- ERROR occurs here
  end
end
Is this illegal syntax?
Re: Cannot use GET with FROM clause within FOREACH [message #810837 is a reply to message #810818] Thu, 01 March 2012 10:57 Go to previous messageGo to next message
Hi Daniel,
This is a bug in validation. Please submit a bug report at "https: //bugs.eclipse .org/bugs/enter_bug.cgi?product=EDT" (remove the spaces, this forum isn't allowing me to post hyperlinks).
For now you can work around this by putting the code in another function and invoking the function inside the forEach block.
-Justin
Re: Cannot use GET with FROM clause within FOREACH [message #810921 is a reply to message #810837] Thu, 01 March 2012 12:32 Go to previous message
Will submit the bug. Thanks for the quick reply, Justin!
Previous Topic:Forward & onprerender function in EDT
Next Topic:Dojo Widget Error in Using Handler
Current Time: Sun Jun 22 11:55:59 EDT 2025
Powered by FUDForum. Page generated in 0.04989 seconds
