Home » Archived » DSDP » Device Information Database
Re: Device Information Database [message #8928 is a reply to message #8908] |
Mon, 21 August 2006 09:17 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hello Sebastian,
could you elaborate a little bit what kind of use you'd want to make
from an integrated device information database?
My feeling is that for device platforms outside the mobile java
space, the hardware is perhaps just too different to fit into a
generic scheme for such device information, such that a tooling
could make use of it.
In case I'm right, the MTJ project might be the right place for
discussing this. Or does anybody know about a similar public available
database for hardware other than Java platforms?
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Sebastian Sickelmann wrote:
> Hi
> First of all, sorry for the crosspost. But i have a question in which
> project device information access should be managed.
> My first idea was the dsdp-tm project, but looking through the use cases
> and the newsgroup of dsdp-tm astonished me a bit. Non of the
> sub-projects in dsdp addresses device information that is fundamental
> for multi-device development(at least at JavaME-Development).
> I think about an abstraction of accessing multiple device-information
> databases like (J2ME-Polish-Device-Database, WURFL, J2ME-Device-Database
> , see
> http://en.wikibooks.org/wiki/Programming:J2ME:MIDP_Device_Da tabases for
> more.)
> Possible there can be an abstraction, that all(or may be some)
> mobile-phone manufactors can contribute data to.
> Kind regards
> Sebastian
Re: Device Information Database [message #8950 is a reply to message #8928] |
Mon, 21 August 2006 09:55 |
Sebastian Sickelmann Messages: 26 Registered: July 2009 |
Hello Martin
OK, The ideas comes as a think about a contribution for MTJ and how this
contribution should access the availiable device informations. And i
think it is not a good way that a part of MTJ accesses a device database
directly without any defined standard interface. But where to place the
definition of that interface? Maybe it is an Java independent topic. But
i have the same problem to see the need of an device information
database outside of MTJ. I am not yet very familiar with development of
- Windows Mobile
- PalmOS
- BREW
- native Symbian OS.
But i can imagine that developers for other devices than JavaME having
comparable needs for a device database.
Has the device a camera, and can it be accessed?
Does the device support alpha-transparancy?
Does it natively support bluethooth?
If not, than i looking forward to get more experience in programming
those devices and will continue the discussion in MTJ-Newsgroup only.
Are here some developers who have the need of a device information database?
Hope to hear that there is no need for an device information database
for mobile devicess outside JavaME.
Kind regard
Sebastian
< http://dict.leo.org/ende?lp=ende&p=/gQPU.&search=exp erience>
Martin Oberhuber schrieb:
> Hello Sebastian,
> Martin Oberhuber
>> Hi
>> , see
>> more.)
>> Kind regards
>> Sebastian
Re: Device Information Database [message #569803 is a reply to message #8908] |
Hello Sebastian,
Martin Oberhuber
> Hi
> , see
> more.)
> Kind regards
> Sebastian
Re: Device Information Database [message #569825 is a reply to message #8928] |
Hello Martin
- Windows Mobile
- PalmOS
- BREW
Kind regard
Sebastian
> Hello Sebastian,
> Martin Oberhuber
>> Hi
>> , see
>> more.)
>> Kind regards
>> Sebastian
Current Time: Fri Apr 26 20:15:29 GMT 2024
Powered by FUDForum. Page generated in 0.03498 seconds
