| can't find IDgroup.new [message #809811] |
Wed, 29 February 2012 04:38  |
hi there. I've got a strange bug on one of my views, that raises a "java.lang.IllegalArgumentException: can't find IDgroup.new"
each time i right-click or interact with one of my views that contains a common navigator (cnf tree etc). the full stacktrace does not mention at all any of our custom classes, and if I drill down in debug the call stack, no code of ours that can suggest me any fix for that.
I never did a contribution named "group.new", but I can see that is declared in
ICommonMenuConstant.class (jface embedded classes) at line:
public static final String GROUP_NEW = "group.new"; //$NON-NLS-1$
and phisically added in a class (always from jface, not mine at all) called "NewActionProvider"
with line:
menu.insertAfter(ICommonMenuConstants.GROUP_NEW, submenu);
after this line some plugin (can't see in debug which one, shows as an eclipse core error). raises the error.
I'm porting my workspace from an Europa version to an Indigo one, and the error was there before since ages, but wasn't blocking. Now that I got some tweaks to make everything work with Indigo, I fear that this can be the cause of many other minor bugs I've got.
Has any other encountered this "group.new" issue on their common navigator framework plugin contributions?
I'd really like to get rid of this sickness I'm stuck with since too long.
Full stacktrace here:
!ENTRY org.eclipse.ui.navigator 4 0 2012-02-29 10:25:33.041
!MESSAGE can't find IDgroup.new
!STACK 0
at org.eclipse.jface.action.ContributionManager.insertAfter(ContributionManager.java:334)
at org.eclipse.ui.internal.navigator.resources.actions.NewActionProvider.fillContextMenu(NewActionProvider.java:123)
at org.eclipse.ui.navigator.NavigatorActionService$2.run(NavigatorActionService.java:221)
at org.eclipse.ui.navigator.NavigatorActionService.addCommonActionProviderMenu(NavigatorActionService.java:216)
at org.eclipse.ui.navigator.NavigatorActionService.fillContextMenu(NavigatorActionService.java:173)
at org.eclipse.ui.navigator.CommonNavigatorManager.fillContextMenu(CommonNavigatorManager.java:260)
at org.eclipse.ui.navigator.CommonNavigatorManager$4.menuAboutToShow(CommonNavigatorManager.java:275)
at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:342)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:473)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:469)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:495)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:247)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:4881)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4557)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:256)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4206)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3748)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
| Re: can't find IDgroup.new [message #809817 is a reply to message #809814] |
Wed, 29 February 2012 04:45  |
what is the relation to GMF?
It's what I wish to understand, actually...
well I've got a series of views generated from an ecore model, and contributions to other gmf-unrelated views are strongly bound to each other. But apart from that I used to find good suggestions on plugin issues and model driven generation in this group some years ago.
[Updated on: Wed, 29 February 2012 04:50] by Moderator
FUDForum. Page generated in 0.03540 seconds
