Home » Language IDEs » C / C++ IDE (CDT) » Error: Project cannot be created
Error: Project cannot be created [message #97389] Thu, 25 March 2004 17:42
--------------050905050400060304050400
Content-Type: text/plain; charset=us-ascii; format=flowed
I'm very new to eclipse... I'm a first time user!
I am trying to set up a standard make project using folders linked to an
existing clearcase source tree. From a window, I set into the clearcase
view. From the same window, I launch eclipse 2.1.2 (with cdt1.2.1). I
start to create the new project. In the "c/make project" dialog, I enter
the name of the project, then uncheck "use default location", and enter
the "location" to the vob directory. For example, vob/x/sys. Then click
"finish". About 12 minutes later I get an error message: "Project cannot
be created. Errors occurred while refreshing resources with the local
file system." I've attached a file of crash log.
I am able to create a small project, using one of the directories in the
/vob. As I said, the vob I'm using is very large, so I wouldn't be
surprise to find that I running out of resources.
I tried increasing the stack size in the JVM, but not sure I doing this
correctly. I'm using a 2gig RAM, dual processor XEON's. Here's the
command I used to increase the stack size:
>./eclipse -data ~/e-projects/2.1/ -vm /usr/java/j2re1.4.2_01/bin/java
-vmargs -Xmx256m
Also, I've read there's a classPerm area(?), but so far I haven't
understood how to increase this size.
The clearcase plugin I'm using is from:
http://sourceforge.net/projects/eclipse-ccase/
I also tried the "stable" eclipse version 3.0, and see the same problem.
Any help or ideas are greatly appreciated!
Frank
Content-Type: application/x-java-vm;
name=".log"
Content-Disposition: inline;
filename=".log"
IVNFU1NJT04gTWFyIDI1LCAyMDA0IDE0OjQ1OjAwLjg3OSAtLS0tLS0tLS0t LS0tLS0tLS0t
LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KamF2YS52ZXJzaW9uPTEuNC4y XzAxCmphdmEu
dmVuZG9yPVN1biBNaWNyb3N5c3RlbXMgSW5jLgpCb290TG9hZGVyIGNvbnN0 YW50czogT1M9
bGludXgsIEFSQ0g9eDg2LCBXUz1ndGssIE5MPWVuX1VTCkNvbW1hbmQtbGlu ZSBhcmd1bWVu
dHM6IC1vcyBsaW51eCAtd3MgZ3RrIC1hcmNoIHg4NiAtZGF0YSAvdXNlcnMv ZnBhcnJvdHQv
ZS1wcm9qZWN0cy8yLjEvIC1pbnN0YWxsIGZpbGU6L2VjbGlwc2UvMi4xLjIv ZWNsaXBzZS8K
IUVOVFJZIG9yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzIDQgNTY3IE1hciAy NSwgMjAwNCAx
NDo0NTowMC44ODEKIU1FU1NBR0UgUHJvYmxlbXMgb2NjdXJyZWQgd2hpbGUg cmVzdG9yaW5n
IHRoZSB3b3Jrc3BhY2UuCiFTVUJFTlRSWSAxIG9yZy5lY2xpcHNlLmNvcmUu cmVzb3VyY2Vz
IDQgNTY3IE1hciAyNSwgMjAwNCAxNDo0NTowMC44ODEKIU1FU1NBR0UgVGhl IHByb2plY3Qg
ZGVzY3JpcHRpb24gZmlsZSAoLnByb2plY3QpIGZvciBhZGRwYXRoIGlzIG1p c3NpbmcuICBU
aGlzIGZpbGUgY29udGFpbnMgaW1wb3J0YW50IGluZm9ybWF0aW9uIGFib3V0 IHRoZSBwcm9q
ZWN0LiAgVGhlIHByb2plY3Qgd2lsbCBub3QgZnVuY3Rpb24gcHJvcGVybHkg dW50aWwgdGhp
cyBmaWxlIGlzIHJlc3RvcmVkLgohU1VCRU5UUlkgMSBvcmcuZWNsaXBzZS5j b3JlLnJlc291
cmNlcyA0IDU2NyBNYXIgMjUsIDIwMDQgMTQ6NDU6MDAuODgxCiFNRVNTQUdF IFRoZSBwcm9q
ZWN0IGRlc2NyaXB0aW9uIGZpbGUgKC5wcm9qZWN0KSBmb3IgaXAgaXMgbWlz c2luZy4gIFRo
aXMgZmlsZSBjb250YWlucyBpbXBvcnRhbnQgaW5mb3JtYXRpb24gYWJvdXQg dGhlIHByb2pl
Y3QuICBUaGUgcHJvamVjdCB3aWxsIG5vdCBmdW5jdGlvbiBwcm9wZXJseSB1 bnRpbCB0aGlz
IGZpbGUgaXMgcmVzdG9yZWQuCiFTRVNTSU9OIE1hciAyNSwgMjAwNCAxNTow MzowNC43OTgg
LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t CmphdmEudmVy
c2lvbj0xLjQuMl8wMQpqYXZhLnZlbmRvcj1TdW4gTWljcm9zeXN0ZW1zIElu Yy4KQm9vdExv
YWRlciBjb25zdGFudHM6IE9TPWxpbnV4LCBBUkNIPXg4NiwgV1M9Z3RrLCBO TD1lbl9VUwpD
b21tYW5kLWxpbmUgYXJndW1lbnRzOiAtb3MgbGludXggLXdzIGd0ayAtYXJj aCB4ODYgLWRh
dGEgL3VzZXJzL2ZwYXJyb3R0L2UtcHJvamVjdHMvMi4xLyAtaW5zdGFsbCBm aWxlOi9lY2xp
cHNlLzIuMS4yL2VjbGlwc2UvCiFFTlRSWSBvcmcuZWNsaXBzZS5jZHQudWkg NCA0IE1hciAy
NSwgMjAwNCAxNTowMzowNC43OTgKIU1FU1NBR0UgRXJyb3IKIVNUQUNLIDEK b3JnLmVjbGlw
c2UuY29yZS5pbnRlcm5hbC5yZXNvdXJjZXMuUmVzb3VyY2VFeGNlcHRpb246 IEVycm9ycyBv
Y2N1cnJlZCB3aGlsZSByZWZyZXNoaW5nIHJlc291cmNlcyB3aXRoIHRoZSBs b2NhbCBmaWxl
IHN5c3RlbS4KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwubG9jYWxz dG9yZS5GaWxl
U3lzdGVtUmVzb3VyY2VNYW5hZ2VyLnJlZnJlc2hSZXNvdXJjZShGaWxlU3lz dGVtUmVzb3Vy
Y2VNYW5hZ2VyLmphdmE6NTE2KQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRl cm5hbC5sb2Nh
bHN0b3JlLkZpbGVTeXN0ZW1SZXNvdXJjZU1hbmFnZXIucmVmcmVzaChGaWxl U3lzdGVtUmVz
b3VyY2VNYW5hZ2VyLmphdmE6NDk5KQoJYXQgb3JnLmVjbGlwc2UuY29yZS5p bnRlcm5hbC5y
ZXNvdXJjZXMuUmVzb3VyY2UucmVmcmVzaExvY2FsKFJlc291cmNlLmphdmE6 MTE1MSkKCWF0
IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVzb3VyY2VzLlByb2plY3Qu b3BlbihQcm9q
ZWN0LmphdmE6Njk4KQoJYXQgb3JnLmVjbGlwc2UuY2R0LmNvcmUuQ0NvcmVQ bHVnaW4uY3Jl
YXRlQ1Byb2plY3QoQ0NvcmVQbHVnaW4uamF2YTo1NTgpCglhdCBvcmcuZWNs aXBzZS5jZHQu
dWkud2l6YXJkcy5OZXdDUHJvamVjdFdpemFyZC5jcmVhdGVOZXdQcm9qZWN0 KE5ld0NQcm9q
ZWN0V2l6YXJkLmphdmE6MjkzKQoJYXQgb3JnLmVjbGlwc2UuY2R0LnVpLndp emFyZHMuTmV3
Q1Byb2plY3RXaXphcmQuZG9SdW4oTmV3Q1Byb2plY3RXaXphcmQuamF2YToy NTIpCglhdCBv
cmcuZWNsaXBzZS5jZHQubWFrZS51aS53aXphcmRzLk5ld01ha2VQcm9qZWN0 V2l6YXJkLmRv
UnVuKE5ld01ha2VQcm9qZWN0V2l6YXJkLmphdmE6NDApCglhdCBvcmcuZWNs aXBzZS5jZHQu
dWkud2l6YXJkcy5OZXdDUHJvamVjdFdpemFyZCQxLnJ1bihOZXdDUHJvamVj dFdpemFyZC5q
YXZhOjIxMykKCWF0IG9yZy5lY2xpcHNlLnVpLmFjdGlvbnMuV29ya3NwYWNl TW9kaWZ5RGVs
ZWdhdGluZ09wZXJhdGlvbi5leGVjdXRlKFdvcmtzcGFjZU1vZGlmeURlbGVn YXRpbmdPcGVy
YXRpb24uamF2YTo0NSkKCWF0IG9yZy5lY2xpcHNlLnVpLmFjdGlvbnMuV29y a3NwYWNlTW9k
aWZ5T3BlcmF0aW9uJDEucnVuKFdvcmtzcGFjZU1vZGlmeU9wZXJhdGlvbi5q YXZhOjcxKQoJ
YXQgb3JnLmVjbGlwc2UuY29yZS5pbnRlcm5hbC5yZXNvdXJjZXMuV29ya3Nw YWNlLnJ1bihX
b3Jrc3BhY2UuamF2YToxNTk1KQoJYXQgb3JnLmVjbGlwc2UudWkuYWN0aW9u cy5Xb3Jrc3Bh
Y2VNb2RpZnlPcGVyYXRpb24ucnVuKFdvcmtzcGFjZU1vZGlmeU9wZXJhdGlv bi5qYXZhOjg1
KQoJYXQgb3JnLmVjbGlwc2UuamZhY2Uub3BlcmF0aW9uLk1vZGFsQ29udGV4 dC5ydW5JbkN1
cnJlbnRUaHJlYWQoTW9kYWxDb250ZXh0LmphdmE6MzAyKQoJYXQgb3JnLmVj bGlwc2UuamZh
Y2Uub3BlcmF0aW9uLk1vZGFsQ29udGV4dC5ydW4oTW9kYWxDb250ZXh0Lmph dmE6MjUyKQoJ
YXQgb3JnLmVjbGlwc2UuamZhY2Uud2l6YXJkLldpemFyZERpYWxvZy5ydW4o V2l6YXJkRGlh
bG9nLmphdmE6NzU4KQoJYXQgb3JnLmVjbGlwc2UuY2R0LnVpLndpemFyZHMu TmV3Q1Byb2pl
Y3RXaXphcmQuaW52b2tlUnVubmFibGUoTmV3Q1Byb2plY3RXaXphcmQuamF2 YToyMzEpCglh
dCBvcmcuZWNsaXBzZS5jZHQudWkud2l6YXJkcy5OZXdDUHJvamVjdFdpemFy ZC5wZXJmb3Jt
RmluaXNoKE5ld0NQcm9qZWN0V2l6YXJkLmphdmE6MTU0KQoJYXQgb3JnLmVj bGlwc2UuamZh
Y2Uud2l6YXJkLldpemFyZERpYWxvZy5maW5pc2hQcmVzc2VkKFdpemFyZERp YWxvZy5qYXZh
OjYwOCkKCWF0IG9yZy5lY2xpcHNlLmpmYWNlLndpemFyZC5XaXphcmREaWFs b2cuYnV0dG9u
UHJlc3NlZChXaXphcmREaWFsb2cuamF2YTozMjEpCglhdCBvcmcuZWNsaXBz ZS5qZmFjZS5k
aWFsb2dzLkRpYWxvZyQxLndpZGdldFNlbGVjdGVkKERpYWxvZy5qYXZhOjQy MykKCWF0IG9y
Zy5lY2xpcHNlLnN3dC53aWRnZXRzLlR5cGVkTGlzdGVuZXIuaGFuZGxlRXZl bnQoVHlwZWRM
aXN0ZW5lci5qYXZhOjg5KQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMu RXZlbnRUYWJs
ZS5zZW5kRXZlbnQoRXZlbnRUYWJsZS5qYXZhOjgxKQoJYXQgb3JnLmVjbGlw c2Uuc3d0Lndp
ZGdldHMuV2lkZ2V0LnNlbmRFdmVudChXaWRnZXQuamF2YTo5MjMpCglhdCBv cmcuZWNsaXBz
ZS5zd3Qud2lkZ2V0cy5EaXNwbGF5LnJ1bkRlZmVycmVkRXZlbnRzKERpc3Bs YXkuamF2YTox
ODQ3KQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRGlzcGxheS5yZWFk QW5kRGlzcGF0
Y2goRGlzcGxheS5qYXZhOjE2MzkpCglhdCBvcmcuZWNsaXBzZS5qZmFjZS53 aW5kb3cuV2lu
ZG93LnJ1bkV2ZW50TG9vcChXaW5kb3cuamF2YTo1ODMpCglhdCBvcmcuZWNs aXBzZS5qZmFj
ZS53aW5kb3cuV2luZG93Lm9wZW4oV2luZG93LmphdmE6NTYzKQoJYXQgb3Jn LmVjbGlwc2Uu
dWkuYWN0aW9ucy5OZXdQcm9qZWN0QWN0aW9uLnJ1bihOZXdQcm9qZWN0QWN0 aW9uLmphdmE6
MTA3KQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLkFjdGlvbi5ydW5X aXRoRXZlbnQo
QWN0aW9uLmphdmE6ODQyKQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYWN0aW9u LkFjdGlvbkNv
bnRyaWJ1dGlvbkl0ZW0uaGFuZGxlV2lkZ2V0U2VsZWN0aW9uKEFjdGlvbkNv bnRyaWJ1dGlv
bkl0ZW0uamF2YTo0NTYpCglhdCBvcmcuZWNsaXBzZS5qZmFjZS5hY3Rpb24u QWN0aW9uQ29u
dHJpYnV0aW9uSXRlbS5oYW5kbGVXaWRnZXRFdmVudChBY3Rpb25Db250cmli dXRpb25JdGVt
LmphdmE6NDAzKQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLkFjdGlv bkNvbnRyaWJ1
dGlvbkl0ZW0uYWNjZXNzJDAoQWN0aW9uQ29udHJpYnV0aW9uSXRlbS5qYXZh OjM5NykKCWF0
IG9yZy5lY2xpcHNlLmpmYWNlLmFjdGlvbi5BY3Rpb25Db250cmlidXRpb25J dGVtJEFjdGlv
bkxpc3RlbmVyLmhhbmRsZUV2ZW50KEFjdGlvbkNvbnRyaWJ1dGlvbkl0ZW0u amF2YTo3MikK
CWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkV2ZW50VGFibGUuc2VuZEV2 ZW50KEV2ZW50
VGFibGUuamF2YTo4MSkKCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLldp ZGdldC5zZW5k
RXZlbnQoV2lkZ2V0LmphdmE6OTIzKQoJYXQgb3JnLmVjbGlwc2Uuc3d0Lndp ZGdldHMuRGlz
cGxheS5ydW5EZWZlcnJlZEV2ZW50cyhEaXNwbGF5LmphdmE6MTg0NykKCWF0 IG9yZy5lY2xp
cHNlLnN3dC53aWRnZXRzLkRpc3BsYXkucmVhZEFuZERpc3BhdGNoKERpc3Bs YXkuamF2YTox
NjM5KQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNoLnJ1 bkV2ZW50TG9v
cChXb3JrYmVuY2guamF2YToxNDAyKQoJYXQgb3JnLmVjbGlwc2UudWkuaW50 ZXJuYWwuV29y
a2JlbmNoLnJ1bihXb3JrYmVuY2guamF2YToxMzg1KQoJYXQgb3JnLmVjbGlw c2UuY29yZS5p
bnRlcm5hbC5ib290LkludGVybmFsQm9vdExvYWRlci5ydW4oSW50ZXJuYWxC b290TG9hZGVy
LmphdmE6ODU4KQoJYXQgb3JnLmVjbGlwc2UuY29yZS5ib290LkJvb3RMb2Fk ZXIucnVuKEJv
b3RMb2FkZXIuamF2YTo0NjEpCglhdCBzdW4ucmVmbGVjdC5OYXRpdmVNZXRo b2RBY2Nlc3Nv
ckltcGwuaW52b2tlMChOYXRpdmUgTWV0aG9kKQoJYXQgc3VuLnJlZmxlY3Qu TmF0aXZlTWV0
aG9kQWNjZXNzb3JJbXBsLmludm9rZShVbmtub3duIFNvdXJjZSkKCWF0IHN1 bi5yZWZsZWN0
LkRlbGVnYXRpbmdNZXRob2RBY2Nlc3NvckltcGwuaW52b2tlKFVua25vd24g U291cmNlKQoJ
YXQgamF2YS5sYW5nLnJlZmxlY3QuTWV0aG9kLmludm9rZShVbmtub3duIFNv dXJjZSkKCWF0
IG9yZy5lY2xpcHNlLmNvcmUubGF1bmNoZXIuTWFpbi5iYXNpY1J1bihNYWlu LmphdmE6Mjkx
KQoJYXQgb3JnLmVjbGlwc2UuY29yZS5sYXVuY2hlci5NYWluLnJ1bihNYWlu LmphdmE6NzQ3
KQoJYXQgb3JnLmVjbGlwc2UuY29yZS5sYXVuY2hlci5NYWluLm1haW4oTWFp bi5qYXZhOjU4
MykKIUVOVFJZIG9yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzIDQgMjcxIE1h ciAyNSwgMjAw
NCAxNTowMzowNC44MDEKIU1FU1NBR0UgRXJyb3JzIG9jY3VycmVkIHdoaWxl IHJlZnJlc2hp
bmcgcmVzb3VyY2VzIHdpdGggdGhlIGxvY2FsIGZpbGUgc3lzdGVtLgohU1VC RU5UUlkgMSBv
cmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcyA0IDI3OCBNYXIgMjUsIDIwMDQg MTU6MDM6MDQu
ODAxCiFNRVNTQUdFIGZ0cHNydmNtZC55c3JjLmE5YjRlNDg3LjNlN2YxMWQx LmI5MzMuMDA6
MDE6ODA6ODE6ZGQ6NWMgaXMgYW4gaW52YWxpZCByZXNvdXJjZSBuYW1lLgoh U1VCRU5UUlkg
MSBvcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcyA0IDI3OCBNYXIgMjUsIDIw MDQgMTU6MDM6
MDQuODAxCiFNRVNTQUdFIGZpbmRtZXJnZS5sb2cuMTEtMDgtMDAuMTE6MzU6 NDggaXMgYW4g
aW52YWxpZCByZXNvdXJjZSBuYW1lLgohU1VCRU5UUlkgMSBvcmcuZWNsaXBz ZS5jb3JlLnJl
c291cmNlcyA0IDI3OCBNYXIgMjUsIDIwMDQgMTU6MDM6MDQuODAxCiFNRVNT QUdFIGV4ZWNf
ZGVidWdfaWdtcF9zbm9vcC5oLjkzMTMzMzlkLjMyMDkxMWQ0LmFmOTUuMDA6 MDE6ODA6ODE6
ZWM6YjcgaXMgYW4gaW52YWxpZCByZXNvdXJjZSBuYW1lLgohU1VCRU5UUlkg MSBvcmcuZWNs
aXBzZS5jb3JlLnJlc291cmNlcyA0IDI3OCBNYXIgMjUsIDIwMDQgMTU6MDM6 MDQuODAyCiFN
RVNTQUdFIHdzX3JwX2NsaWVudC5jLjJmZTU0MjA1LmEwMDQxMWQ0LmFlMzgu MDA6MDE6ODA6
OWE6ZGU6MGQgaXMgYW4gaW52YWxpZCByZXNvdXJjZSBuYW1lLgohU1VCRU5U UlkgMSBvcmcu
ZWNsaXBzZS5jb3JlLnJlc291cmNlcyA0IDI3OCBNYXIgMjUsIDIwMDQgMTU6 MDM6MDQuODAy
CiFNRVNTQUdFIGl0YWNfaW50Lm8uMGRjMzMzN2EuOTk3MzExZDMuYjcwOC4w MDowMTo4MDo5
Yjo1MTo4MiBpcyBhbiBpbnZhbGlkIHJlc291cmNlIG5hbWUuCg==
--------------050905050400060304050400--
Previous Topic:Word plug-in view in 3.0M6
Next Topic:No "New Make Properties" in C/C++ prefs
Current Time: Thu Nov 06 15:17:43 EST 2025
Powered by FUDForum. Page generated in 0.02610 seconds
