Home » Eclipse Projects » Eclipse Platform » IResource.copy()
IResource.copy() [message #97121] Sat, 19 July 2003 12:00 Go to next message
I am trying to copy a selected Resource to another location inside the
project. I always get an error message, claiming that the directory, where
I would like to copy the Resource to (it is a file), does not exist. I
thought, that the copy also creates the directory. It does not seem like.
Any help therefor? I think this should be pretty easy anyway, but I cannot
make it.
See the coding from my run Method:
IPath targetPath = null;
IPath srcPath = null;
IPath projectPath = null;
IProject project = null;
IResource[] resources = this.getSelectedResources();
/* loop over given resources and determine the path and the
corresponding project */
for (int i = 0; i < resources.length; i++) {
IResource resource = resources[i];
/* determine path of the resource and the project */
srcPath = resource.getProjectRelativePath();
project = resource.getProject();
projectPath = project.getFullPath();
/* build targetPath */
targetPath = new Path(projectPath + "/tmp/" + srcPath);
try {
resource.copy(targetPath, true, null);
} catch (Exception ex) {
System.out.println(ex.getMessage());
Any help is greatly appreciated.
Re: IResource.copy() [message #97168 is a reply to message #97121] Sat, 19 July 2003 14:47 Go to previous messageGo to next message
So you should create the directory first ...
Markus M. May wrote:
> Hello,
> make it.
> try {
Re: IResource.copy() [message #97226 is a reply to message #97168] Sat, 19 July 2003 17:39 Go to previous messageGo to next message
I thought so. Now i am creating an IFolder and create the directory with
this handler. Anyway, the directory is still not created. I believe that I
have somewhere a deep misunderstanding of this stuff.
Here is now my new coding:
targetPath = new Path("tmp/" + srcPath);
try {
String targetFolder = targetPath.toFile().getParent();
IFolder folder = resource.getProject().getFolder(targetFolder);
folder.create(true, true, null);
resource.copy(folder.getLocation(), true, null);
what i am trying to do is to copy .java files from there original file to
another directory "tmp/..." in the project. are there any hints or
examples on how to do something like this?
regards
> > Hello,
> > make it.
> > try {
Re: IResource.copy() [message #97626 is a reply to message #97226] Tue, 22 July 2003 15:31 Go to previous message
Originally posted by: John_Arthorne.oti.com_
This part is wrong:
The "targetFolder" variable is holding a fully qualified file system
path for the folder. Then you pass this to getFolder, which expects a
project-relative path. You should instead use:
IContainer folder = resource.getParent();
Presumably it is possible that the parent's parent doesn't exist either,
so you probably need a recursive parent creation method... something
like this:
protected void create(IResource resource) throws CoreException {
if (resource.exists())
return;
create(resource.getParent());
switch (resource.getType()) {
case IResource.FOLDER :
((IFolder) resource).create(IResource.NONE, true, null);
break;
case IResource.PROJECT :
((IProject) resource).create(getMonitor());
((IProject) resource).open(getMonitor());
break;
> try {
> regards
>>>Hello,
>>>make it.
>>> try {
Previous Topic:Re: How to get an IDocument from an IResource? Need to translate lineNo to Char_start
Next Topic:Exporting features
Current Time: Wed Oct 15 20:39:02 EDT 2025
Powered by FUDForum. Page generated in 0.03250 seconds
