Home » Eclipse Projects » Rich Client Platform (RCP) » Advanced perspective layout(How to define little advanced perspective layout declaratively?)
Advanced perspective layout [message #807560] Sun, 26 February 2012 17:37 Go to next message
Libor Jelinek is currently offline Libor JelinekFriend
Hello dear forum members,
I would like to ask you to help with setting up little advanced perspective layout. May blog posts and articles are discouraging from hard-coded perspective layout in IPerspectiveFactory.
I would like to achieve this layout:
index.php/fa/7302/0/
But I am getting:
index.php/fa/7301/0/
Here is excerpt of main plugin's plugin.xml:
   <extension
         point="org.eclipse.ui.perspectives">
      <perspective
            name="Default perspective"
            class="com.virtage.plexflow.ui.DefaultPerspective"
            id="com.virtage.plexflow.ui.defaultPerspective"
            fixed="false">
      </perspective>
   </extension>
   <extension
         point="org.eclipse.ui.perspectiveExtensions">
      <perspectiveExtension
            targetID="com.virtage.plexflow.ui.defaultPerspective">
         <view
               closeable="false"
               id="org.eclipse.ui.views.ProgressView"
               minimized="false"
               ratio="0.8"
               relationship="bottom"
               relative="org.eclipse.ui.editorss"
               visible="true">
         </view>
      </perspectiveExtension>
   </extension>
From additonal plugin I am trying to contribute to the left pane:
   <extension
         <view
               id="com.virtage.plexflow.ui.explorer.PlacesView"
               minimized="false"
               ratio="0.25"
               relationship="left"
               relative="org.eclipse.ui.editorss">
         </view>
   </extension>
Please, how to define <perspectiveExtensions> and <view> to create what is figured on second image?
Thanks.
Libor
[Updated on: Sun, 26 February 2012 17:40]
Report message to a moderator
Re: Advanced perspective layout [message #808443 is a reply to message #807560] Mon, 27 February 2012 19:52 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
I would advise you to create your perspective in your IPerspectiveFactory. Add and position what you want to include in your main perspective correctly.
perspectiveExtensions is for views coming from secondary plugins so they can position themselves correctly in an existing perspective.
PW
Previous Topic:how to load external xml file without using eclipse registry
Next Topic:Key binding for simple action
Current Time: Fri Apr 26 10:38:56 GMT 2024
Powered by FUDForum. Page generated in 0.02817 seconds
