Re: migrate from 3.7 to 3.8 [message #881837 is a reply to message #881793] |
Tue, 05 June 2012 10:45 |
Bruno Koeferli Messages: 11 Registered: January 2012 |
hi adrien
yes, you have to replace the existing Texts class with a new class extending "org.eclipse.scout.rt.shared.services.common.text.AbstractDynamicNlsTextProviderService".
f.e. the following Texts.java
package com.foo.shared;
public class Texts extends ScoutTexts{
public static final String RESOURCE_BUNDLE_NAME = "resources.texts.Texts";//$NON-NLS-1$
private static Texts instance=new Texts();
public static Texts getInstance(){
return instance;
public static String get(String key,String ... messageArguments){
return getInstance().getText(key,messageArguments);
protected Texts(){
registerResourceBundle(RESOURCE_BUNDLE_NAME,Texts.class);
... will end up in TextProviderService.java
package com.foo.shared.services.common.text;
public class TextProviderService extends AbstractDynamicNlsTextProviderService {
protected String getDynamicNlsBaseName() {
return "resources.texts.Texts";
... and the corresponding service registration in the plugin.xml.
/bruno
[Updated on: Tue, 05 June 2012 11:00] Report message to a moderator
Re: migrate from 3.7 to 3.8 [message #881924 is a reply to message #881837] |
Tue, 05 June 2012 14:02 |
adrien teulade Messages: 14 Registered: June 2012 |
Thanks for your help Bruno but when i launch my server and my client I have an error with the IdApplication and I don't understand where it comes (I'm beginner with Scout SDK)
Moreover, the bug report solve errors which are caused by Nls class but there is another type of error.
In fact, the import org.eclipse.scout.rt.shared.services.common.security.SimplePrincipal; is unknown ...
I use this import to solve the problem but I don't know if it's a good decision.
import org.eclipse.scout.rt.common.security.SimplePrincipal;
[Updated on: Tue, 05 June 2012 14:23] Report message to a moderator
Re: migrate from 3.7 to 3.8 [message #882290 is a reply to message #881974] |
Wed, 06 June 2012 07:43 |
I'm going to try this !
but I totally destroy my Scout project so I've to build another one.
Edit : I try to validate my *.product and now the server work (there was one plugins missing) but no plug-in add for the client.
Now I have only one error when I launch my client :
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.<init>(ModelServiceImpl.java:92)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:442)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:182)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:554)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.minicrm.ui.swt.application.Application.startSecure(Application.java:51)
at org.eclipse.minicrm.ui.swt.application.Application$1.run(Application.java:37)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.eclipse.minicrm.ui.swt.application.Application.start(Application.java:34)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Does It is possible that I make a mistake when registering the new Service in plugin.xml ?
I show you my plugin.xml
[size=1]<?xml version="1.0" encoding="UTF-8"?>
<plugin>
<extension point="org.eclipse.scout.service.services">
<proxy class="org.eclipse.minicrm.shared.services.outline.IStandardOutlineService" factory="org.eclipse.scout.rt.client.services.ClientProxyServiceFactory"/>
<service class="org.eclipse.minicrm.shared.TextProviderService" factory="org.eclipse.scout.service.DefaultServiceFactory" ranking="100" />
<proxy class="org.eclipse.minicrm.shared.services.process.ICompanyProcessService" factory="org.eclipse.scout.rt.client.services.ClientProxyServiceFactory"/>
</extension>
</extension>
</plugin>[/size]
[Updated on: Wed, 06 June 2012 08:16] Report message to a moderator
Re: migrate from 3.7 to 3.8 [message #883337 is a reply to message #806609] |
Fri, 08 June 2012 10:10 |
Now I resolved all my problems with eclipse and scout I have a new error :
!ENTRY org.eclipse.equinox.http.jetty 4 0 2012-06-08 14:10:30.640
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841 [3]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.jetty.http; version="[8.0.0,9.0.0)"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2012-06-08 14:10:30.643
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841.jar was not resolved.
!ENTRY org.eclipse.osgi 2 0 2012-06-08 14:10:30.661
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-06-08 14:10:30.661
!MESSAGE Bundle update@plugins/org.eclipse.scout.rt.jdbc.derby_10.5.3.201205300618.jar was not resolved.
!SUBENTRY 2 org.eclipse.scout.rt.jdbc.derby 2 0 2012-06-08 14:10:30.661
!MESSAGE Missing imported package org.apache.derby.jdbc_0.0.0.
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.662
!MESSAGE Missing imported package org.eclipse.jetty.util_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.io.nio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.http_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.session_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.ssl_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.663
!MESSAGE Missing imported package org.eclipse.jetty.io.bio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.util.log_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.handler_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.util.component_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.664
!MESSAGE Missing imported package org.eclipse.jetty.servlet_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.nio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.bio_[8.0.0,9.0.0).
!ENTRY org.eclipse.osgi 2 0 2012-06-08 14:10:30.675
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-06-08 14:10:30.675
!MESSAGE Bundle org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841 [3] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.675
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.676
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.677
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.678
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-06-08 14:10:30.678
!MESSAGE Bundle org.eclipse.scout.rt.jdbc.derby_10.5.3.201205300618 [18] was not resolved.
!SUBENTRY 2 org.eclipse.scout.rt.jdbc.derby 2 0 2012-06-08 14:10:30.678
!MESSAGE Bundle eclipse.org.minicrm.server_1.0.0.qualifier [32] was not resolved.
!SUBENTRY 2 eclipse.org.minicrm.server 2 0 2012-06-08 14:10:30.679
!MESSAGE Missing required bundle org.eclipse.scout.rt.jdbc.derby_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2012-06-08 14:10:30.696
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-06-08 14:10:30.697
!SUBENTRY 2 org.eclipse.scout.rt.jdbc.derby 2 0 2012-06-08 14:10:30.697
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.697
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.698
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.699
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.700
!ENTRY org.eclipse.osgi 2 0 2012-06-08 14:10:30.707
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-06-08 14:10:30.707
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.707
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.708
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-06-08 14:10:30.709
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-06-08 14:10:30.709
!SUBENTRY 2 org.eclipse.scout.rt.jdbc.derby 2 0 2012-06-08 14:10:30.709
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-06-08 14:10:30.710
!SUBENTRY 2 eclipse.org.minicrm.server 2 0 2012-06-08 14:10:30.710
!MESSAGE Missing required bundle org.eclipse.scout.rt.jdbc.derby_0.0.0.java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
I'm working on it .... if someone have an idea ...
A question the service I have to registered in plugin.xml where do I have to registered it ? In Which plugin.xml do I have to add it ? client ? server ? swing ? swt ? all of them ?
Thanks in advance for your answer
[Updated on: Fri, 08 June 2012 12:13] Report message to a moderator
Re: migrate from 3.7 to 3.8 [message #883465 is a reply to message #883446] |
Fri, 08 June 2012 15:30 |
I find THE solution for the DB access : when you click on Add required plug-in eclipse add two plug-ins which create a conflict
org.apache.derby.jdbc_1082.fragment and le org.apache.derby.jdbc_1053.fragment you simply have to keep org.apache.derby.jdbc_1082.fragment and suppress org.apache.derby.jdbc_1053.fragment
[Updated on: Fri, 08 June 2012 15:31] Report message to a moderator
FUDForum. Page generated in 0.04836 seconds
