Home » Modeling » M2T (model-to-text transformation) » [XPand2] setting local variables
[XPand2] setting local variables [message #805869] Fri, 24 February 2012 03:36 Go to next message
I want to set a local variable to another value, for example:
«LET false AS itemFound»
«FOREACH ... AS ...»
«IF ...»
 «REM»do sth and set the variable itemFound to true«ENDREM»
 itemFound = true
«ENDIF»
«ENDFOREACH»
«ENDLET»
How can I do this?
[Updated on: Fri, 24 February 2012 04:06] by Moderator
Re: [XPand2] setting local variables [message #805893 is a reply to message #805869] Fri, 24 February 2012 04:09 Go to previous message
The LET statement binds the result of an expression to a variable. There is no concept in Xpand to define variables, and usually it is not needed.
Anyway, to come around this you could use the elementprops extensions from stdlib.
extension org::eclipse::xtend::util::stdlib::elementprops;
«this.setProperty("itemFound", false)»
«IF ...»
  «this.setProperty("itemFound", true)»
You should always ask yourself: Do I really need this? I do not know your usecase, but it is likely that you could come around your issue with a smarter use of extension functions for your template. I have programmed so many templates, and don't have a real need for local variables in 99%. Also I avoid to use LET in favor of extension functions whenever applicable.
~Karsten
Previous Topic:[acceleo] best way to pass extra data from Java to template ?
Next Topic:[Acceleo] Errors running builder 'Acceleo Builder'
Current Time: Wed Jul 30 19:18:59 EDT 2025
Powered by FUDForum. Page generated in 0.28417 seconds
