Re: BIRT bar chart report shutting down weblogic server [message #805434 is a reply to message #804544] |
Thu, 23 February 2012 19:11 |
Take a look at this link:
http://wiki.eclipse.org/BIRT/FAQ/Charts2.2#Charts_not_rendering_on_Unix_systems
Jason
On 2/22/2012 2:01 PM, Shaju J wrote:
> Hello,
> We have a BIRT report with bar chart in it running fine in multiple app
> server environments. In one of our server, (Solaris - Weblogic 10.3), if
> I try to bring up this report, it kills the application server. We have
> narrowed down this to a variable set in the environment where we are
> starting Weblogic.
> DISPLAY=localhost:10.0.
> If we remove this env variable, everything seems to be fine.
> The only error message I can see is
> "X connection to localhost:10.0 broken (explicit kill or server shutdown)."
> This is a product which will be installed at multiple client locations
> and I may not be able to tell them to take out the DISPLAY variable. Is
> there any setting in BIRT which I can use to fix this issue?
> Any help is much appreciated!
FUDForum. Page generated in 0.04251 seconds
