Home » Modeling » TMF (Xtext) » Parsing block expressions vs. scope
| Parsing block expressions vs. scope [message #804417] |
Wed, 22 February 2012 10:50  |
Hi!
I have a parsing problem for a DSL like:
Block blc1 extends blc2 {
blc2.feat
Block blc2 {
Attribute feat
So where's the problem? blc2 is referenced from blc1 (and defined after blc1). If I want to reference on blc2.feat and write something like
blc2.
then the next item after '.' which is parsed is '}' with error "mismatched input '}' expecting ID". If I complete the statement manually (with feat), everything is OK. But I want to have a content proposal for the attributes in blc1 and they don't show up, since scoping somehow doesn't work or the block within '{' and '}' isn't consumed as a whole expression.
If I'm defining blc2 before blc1, everything works fine!
Where do I have to hook in the XText objects in order to consume block expressions at the whole? Do I need something like a specified (infinite) lookahead?
Edit:
If I write something like
blc2.|
sometext
then scoping together with giving me the correct proposals (here the feature feat) works fine (| is the cursor position).
Edit2:
If I add to my grammar an artificial hidden() with an ANY_ELEMENT* option, then it works fine again (comapre suggestion http://www.eclipse.org/forums/index.php/mv/msg/296175/804284/#msg_804284). But it's a hack inside the grammar definition and does not reflect the language as it should be.
[Updated on: Wed, 22 February 2012 11:20] by Moderator
| Re: Parsing block expressions vs. scope [message #806399 is a reply to message #805413] |
Fri, 24 February 2012 18:20   |
I have a hard time following what you are trying to express.
As an example, this expression:
> IID : SID [ INT ]
reads IID is a datatype starting with a SID, followed by a reference !?!
(i.e. a pointer) to an INT using an ID to locate the INT. That just does
not make sense. typos ?
To make it more convenient - use the feature "name" as the identity of
referenceable elements, and reference them by qualified name (i.e. ID).
Then it works out of the box.
If you then need to reference things based on something else - then you
need to think about the scoping of that (same file, across files, across
projects/bundles etc.).
Are you using the default terminals? If so, there is an ID already that
overlaps with your SID, IID, etc. If you need ID to be something
different than the default, just override it (redeclare it in your grammar).
Hope that helps for starters.
- henrik
On 2012-23-02 19:38, Alex G wrote:
> I found out the answer! Took me hours!!!
> My part of grammar:
> terminal SID : ('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
> IID : SID [ INT ]
> SIDone: SID;
> SIDtwo: '(' SID ')';
> SIDthree: SID;
> IIDone : IID
> IIDtwo : IID
> and I had some rules which had a dependence on these data types, like
> RuleOne: name = SIDone ...
> RuleFoo: name = [RuleOne | SIDone] ...
> RuleBar: name = SIDtwo ...
> RuleFortyTwo: name = IIDtwo ...
> I wanted to be flexible with these data types - now I learned my lesson ^^.
> Is the only way to be flexible for later when grammer changes (like the
> data types for names above), to create rules and not data types like
> IID : SID ([ INT ])?
> SIDone: id=SID;
> SIDtwo: id='(' SID ')';
> SIDthree: id=SID;
> IIDone : id=IID
> IIDtwo : id=IID
> and modify the QualifiedNameProbider for RuleOne, RuleFoo etc. to get
> the names from SIDone, SIDtwo etc? The problem in this case is, that I
> have then two identical simple names, what I wanted to avoid and
> therefore created these data types.
> And what will happen with the data type "IID"? There could be collision
> with the terminal SID - the parser will not know, how to distinguish a
> SID from an IID? Can I somehow avoid it and leave IID as a data type
> without introducing type check in the scope or qualified name classes?
| Re: Parsing block expressions vs. scope [message #806427 is a reply to message #806399] |
Fri, 24 February 2012 19:21   |
Hi again!
Indeed I thought that I have found out the error, but I didn't (after further hours of searching for a "bug"). I've created a small version of the problem shown in the first post. The main problem is, I think, that I reference a reference, which isn't referenced anymore while editing the model, s.t. I can't reference it while editing, but when editing is finished (and the reference written manually without content assist), the model parses well. Here the code:
Grammar:
grammar org.xtext.example.abc.ABC with org.eclipse.xtext.common.Terminals
generate aBC "http://www.xtext.org/example/abc/ABC"
ABCLanguage: (D += ItemDefinition)*;
ItemDefinition:
"Item" name=ID
(inheritance ?= ":" inherits=Inherits)?
body=ItemBody;
ItemBody:
body?="{"
( WD += WorkingDefinition |
ID += ItemDefinition AI += AbstractItem
Inherits:
defrefs += DefinitionReference ("," defrefs+= DefinitionReference)*;
DefinitionReference:
(name=ID hasName?="<-")?
ref = [ItemDefinition | ID];
WorkingDefinition:
"Working" name=ID;
AbstractItem:
"AbstractItem" id=ID "holds" ref=[ItemDefinition | ID];
What do I want to express with this grammar? Models like:
Item aaa111 : aaa222 {
Item aaa444 : aaa222 {} AbstractItem Id holds aaa222
Item aaa222 {
So, Item aaa111 references to aaa222. In Item aaa111 we have Item aaa444 which wants to reference to the reference aaa222 (not directly to the Item aaa222 outside the scope(!)). After it I added a small part of grammar "AbstractItem ..." which was necessary to show up the error, that is going on.
Here my scope (XTend):
class ABCScopeProvider extends AbstractDeclarativeScopeProvider {
override IScope getScope(EObject context, EReference reference) {
println("")
println("scope_" + reference.EContainingClass.name +
"_" + reference.name +
"(" + context.eClass.name + ", ..)"
super.getScope(context,reference);
def IScope scope_DefinitionReference_ref(ItemDefinition item, EReference eRef) {
Literals::DEFINITION_REFERENCE__REF!=null // assertion
val parent = item.eContainer
switch (parent) {
ItemBody : {
val parentMod = parent.eContainer as ItemDefinition
Scopes::scopeFor(parent.AI, scope_DefinitionReference_ref(parentMod, eRef))
ABCLanguage : {
Scopes::scopeFor(parent.d)
default : {
IScope::NULLSCOPE
and here my qualified name:
public class ABCQualifiedNameProvider extends SimpleNameProvider {
// copied from DefaultDeclarativeQualifiedNameProvider and changed by
// (1) simple names instead of fully qualified names
// (2) scoping issues with constraining parent and child views (set parent scopes to IScope.NULLSCOPE)
// compare getFullyQualifiedName methods
private PolymorphicDispatcher<QualifiedName> qualifiedName = new PolymorphicDispatcher<QualifiedName>("qualifiedName",1,1,Collections.singletonList(this), PolymorphicDispatcher.NullErrorHandler.<QualifiedName>get())
protected QualifiedName handleNoSuchMethod(Object... params) {
return null;
private Function<EObject, String> resolver = SimpleAttributeResolver.newResolver(String.class, "name");
protected Function<EObject, String> getResolver() {
return resolver;
@Inject
private IQualifiedNameConverter converter = new IQualifiedNameConverter.DefaultImpl();
public QualifiedName getFullyQualifiedName(final EObject obj) {
EObject temp = obj;
QualifiedName qualifiedNameFromDispatcher = qualifiedName.invoke(temp);
if (qualifiedNameFromDispatcher!=null)
return qualifiedNameFromDispatcher;
String name = getResolver().apply(temp);
if (Strings.isEmpty(name))
return null;
QualifiedName qualifiedNameFromConverter = converter.toQualifiedName(name);
return qualifiedNameFromConverter;
QualifiedName qualifiedName(DefinitionReference defref) {
String name = null;
QualifiedName qname = null;
if(defref.isHasName()) {
name = defref.getName();
qname = converter.toQualifiedName(name);
} else {
// qname = getFullyQualifiedName(defref.getRef()); // can call lazy links
List<INode> nodes = NodeModelUtils.findNodesForFeature(defref, ABCPackage.Literals.DEFINITION_REFERENCE__REF);
INode first = null;
if(nodes.size()>=1) {
first = nodes.get(0);
name = NodeModelUtils.getTokenText(first);
return qname;
If I define the Item aaa222 before (above) Item aaa111, everythink works fine. If I define it as in the code above (meaning after Item aaa222, then I get lost the reference to aaa222 when writing the following:
Item aaa333 : |
Item aaa222 {}
where | indicates the cursor. The reference aaa222 is underlined, since the Item aaa222 couldn't be parsed correctly.
I hope this can help to show up the problem and thank you for some help in advance.
| Re: Parsing block expressions vs. scope [message #807279 is a reply to message #806427] |
Sun, 26 February 2012 02:04  |
I think I have found what is happening here (looks like a bug):
The error could be somewhere in the AbstractDeclarativeScopeProvider or lexing/parsing:
If I remove the "scope_..." method everything works fine - meaning I can refer by clicking on F3 on the reference aaa222 to its definition.
But If I add the customized scope, the call "parent.getD()" only gives me the item aaa111, since somehow the object aaa222 isn't created (or its name)?
If I disable the "scope_..." method and add
val parent = EcoreUtil2::getContainerOfType(context, typeof(ABCLanguage))
println(parent.d)
int the "getScope" method, I only see the item "aaa111" to be referencable as well, although aaa222 is referencable when disabling the customized scope.
By the way, in order to reproduce this effect it is enough to change AbstractItem to:
AbstractItem: {AbstractItem}
"AbstractItem" ;//id=ID;// "holds";// ref=[ItemDefinition | ID];
or
AbstractItem:
"AbstractItem" id=ID;// "holds";// ref=[ItemDefinition | ID];
Can someone explain me what is happening here?
It could be also the reason that the qualified names are computed too late: I checked that sometimes EObjects do have null names but are referencable, because the customized qualified names are called after creating the EObject. Could this be the reason?
Current Time: Sun Nov 02 21:33:45 EST 2025
Powered by FUDForum. Page generated in 0.05504 seconds
