Unable to build the Greenpages sample [message #804146] |
Wed, 22 February 2012 08:56 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I've been trying to build both the Greenpages 2.4.0.RELEASE and the 2.5.0 that I found at GitHub. Both fails on an unresolved dependency.
The 'mvn package' executed under the solution directory ends with:
[ERROR] Failed to execute goal com.springsource.bundlor:com.springsource.bundlor.maven:1.0.0.M2:transform (bundlor) on project greenpages.parent-solution: Execution bundlor of goal com.springsource.bundlor:com.springsource.bundlor.maven:1.0.0.M2:transform failed: Plugin com.springsource.bundlor:com.springsource.bundlor.maven:1.0.0.M2 or one of its dependencies could not be resolved: The following artifacts could not be resolved: com.springsource.util:com.springsource.util.osgi:jar:1.5.0.BUILD-SNAPSHOT, com.springsource.util:com.springsource.util.io:jar:1.5.0.BUILD-SNAPSHOT, com.springsource.util:com.springsource.util.math:jar:1.5.0.BUILD-SNAPSHOT: Failure to find com.springsource.util:com.springsource.util.osgi:jar:1.5.0.BUILD-SNAPSHOT in http://repository.springsource.com/maven/bundles/release was cached in the local repository, resolution will not be reattempted until the update interval of com.springsource.repository.bundles.release has elapsed or updates are forced -> [Help 1]
What can I do do get passed this?
Re: Unable to build the Greenpages sample [message #805404 is a reply to message #804745] |
Thu, 23 February 2012 18:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I followed your advice and erased the local Maven cache. Unfortunately it didn't help. After a very long sequence of downloads it fails on the same error. Apparently three bundles are missing:
I would really like to get this sample working so advice on how to proceed would be greatly appreciated.
Re: Unable to build the Greenpages sample [message #807400 is a reply to message #805548] |
Sun, 26 February 2012 11:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
The original message contained this piece of info:
"Plugin com.springsource.bundlor:com.springsource.bundlor.maven:1.0.0.M2 or one of its dependencies could not be resolved"
so I though, perhaps this M2 has been surpassed by something more stable? And sure enough, there's now a 1.0.0.RELEASE. So the first step I took was to change the 'solution/parent/pom.xml' to reflect that and then I tried again. Not quite there yet.
Now the error was different, indicating the the bundlor didn't provide a 'transform' command. Reading the docs, I concluded that the one and only command was now 'bundlor' so I changed 'transform' into 'bundlor' (in the same file) and then I tried again. Are we there yet? Nope!
The entry for maven-surefile-plugin points directly into the .m2/repository and assumes the presence of a 3.0.0.M6 version of the org.springframework.instrument. That assumption is incorrect. The downloaded version is 3.0.5.RELEASE. I fixed that and tried again. More problems. The tests fail on a missing LogFactory and then ends because the target/classes directory is missing.
At this point I gave up and concluded that I lack the knowledge to do productive trial and error in this domain. Someone with more knowledge than I needs to give this sample some love and care. It seems to be in bad need for it.
FUDForum. Page generated in 0.04466 seconds
