Re: change font from mydsl [message #801612 is a reply to message #801425] |
Sat, 18 February 2012 17:35 |
Installing / delivering the custom font is not Xtext Specific. So you may find a better answer in an RCP Forum or in the Eclipse Help
Never the less the For the Xtext Editor uses can be configured through the IHighlightingConfiguration
~Christian
Twitter : @chrdietrich
Re: change font from mydsl [message #801617 is a reply to message #801612] |
Sat, 18 February 2012 17:45 |
Phil R Messages: 99 Registered: September 2011 |
Member |
I know that default eclipse plugin development uses an extension for themes and set font definition with xml,
it should be programmatically to avoid the requirement to install the font.
I found that xtext has a LanguageRootPreferencePage, could I do anything with it?
[Updated on: Sat, 18 February 2012 17:46] Report message to a moderator
FUDForum. Page generated in 0.03183 seconds
