Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling RCP applications - Heap Analysis
Profiling RCP applications - Heap Analysis [message #95105] |
Mon, 09 April 2007 08:17 |
Originally posted by: james.ja.mweb.co.za
Hi All,
I would like to use TPTP to do heap analysis on an RCP application. I am
quite confident that my installation is according to instructions, because
there are a lot of good posts that have dealt with some of the pitfalls (if
I do "Test Availability" from the monitor tab, I get success).
I am using release versions of Eclipse 3.2, TPTP 4.3.1, JDK 1.5.0_11
What I observe:
1. Normal (non-RCP) Java apps run fine in the old and new technology
profilers.
2. When I try to launch a JVMTI profile of an RCP, the launch waits a long
time at "Launching (78%)" and then ends with no error (turning on logging in
the AC Java Profiling plugin, generates no log entries, so it doesn't even
seem to get this far). Is this the "known timeout issue" I have seen
reference to? This result occurs consistently and I reproduce it using the
HelloWorld sample RCP app. An error that I get intermittently during this
process is "NLS unused message: ERROR_TI_MODEL_CREATION in:
org.eclipse.tptp.platform.jvmti.client.internal.messages".
3. If I create an RCP "product" from my app, then I can profile it
successfully using JVMTI from standalone (HeapProf) and from the workbench
(by referencing the launcher for the product and not the launcher for the
project).
4. When I use JVMTI, though, there is no menu that I can see to to do a
"Collect Object References" (my real objective). An alternative would be to
get a way to run "Collect Object References" while running in standalone
mode.
5. If I use IAC, and do a "Collect Object References", I get only entries
for some of the classes in my main application plugin (my business logic is
in separate plugins, and no classes from these are included - my filtering
is on the default and my classes are in packages com.domain.* ).
I have searched for any references to this, and was not successful, but I am
hoping that someone has got this to work. I am happy to get any Object
Reference analysis, whether it is using the IAC or JVMTI based profilers.
Many thanks for any help.
James
Re: Profiling RCP applications - Heap Analysis [message #95168 is a reply to message #95105] |
Tue, 10 April 2007 06:02 |
Asaf Yaffe Messages: 333 Registered: July 2009 |
James,
> Hi All,
With the version you're using, I recommend using the "old" (JVMPI) Heap
Profiler and not the new one. In TPTP 4.3.x, the JVMTI Heap Analysis
feature does not provide any additional benefits. If you want to use the
new profiler, please switch to Eclipse 3.3 and TPTP 4.4 (latest stable
or dev build).
> What I observe:
> profilers.
This is a known problem. Things are much better in 4.4.
> project).
> mode.
The "Collect Object Reference" feature was canceled with the release of
the (new) JVMTI profiler (but is still supported in the JVMPI profiler).
We felt that it is not very usable and are currently seeking better ways
(and resources) for implementing this in a more usable manner. See
Bugzilla 93704 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=93704) for
some related discussions.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Profiling RCP applications - Heap Analysis [message #95244 is a reply to message #95168] |
Tue, 10 April 2007 20:27 |
Hi Asaf,
Thanks that is a big help. If I use JVMPI, though, I get this issue:
for the classes in my main application plugin (my business logic is
is on the default and my classes are in packages com.domain.*, which the
filter should not exclude ).
Not sure if this description is too vague to make sense of, but have you
come across anything like that?
Best regards
James
"Asaf Yaffe" <asaf.yaffe@intel.com> wrote in message
news:evf996$4e6$1@build.eclipse.org...
> James,
>> Hi All,
>> because there are a lot of good posts that have dealt with some of the
>> pitfalls (if I do "Test Availability" from the monitor tab, I get
>> success).
> new profiler, please switch to Eclipse 3.3 and TPTP 4.4 (latest stable or
> dev build).
>> What I observe:
>> profilers.
>> long time at "Launching (78%)" and then ends with no error (turning on
>> logging in the AC Java Profiling plugin, generates no log entries, so it
>> doesn't even seem to get this far). Is this the "known timeout issue" I
>> have seen reference to? This result occurs consistently and I reproduce
>> it using the HelloWorld sample RCP app. An error that I get
>> intermittently during this process is "NLS unused message:
>> workbench (by referencing the launcher for the product and not the
>> launcher for the project).
>> to get a way to run "Collect Object References" while running in
>> standalone mode.
> HTH,
> Asaf
> Asaf Yaffe
Re: Profiling RCP applications - Heap Analysis [message #95686 is a reply to message #95259] |
Fri, 13 April 2007 06:00 |
Thanks Asaf,
That is a great help.
Which build version of the Eclipse 3.3 should I use (I see that M6 has some
plugins - like org.eclipse.core.runtime - which conflict with the older
versions in the latest TPTP 4.4 build)?
Many thanks
James
news:evi0pg$rii$1@build.eclipse.org...
> James,
>> filtering
> There are some known "filtering" issues with the JVMPI agent (see here:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=170963). I am not sure
> whether they also affect the Heap Dump functionality, and I am not
> familiar with the code that generates Heap Dumps in the JVMPI agent. Try
> to fiddle with the filter definitions (have you tried including ALL
> classes?) and see if it helps.
> Maybe someone else with more JVMPI Agent experience can help here... ?
> Asaf
> Asaf Yaffe
Re: Profiling RCP applications - Heap Analysis [message #95889 is a reply to message #95686] |
Sun, 15 April 2007 06:31 |
James,
The latest TPTP 4.4 "stable" version should be used with Eclipse 3.3 M6.
Asaf
James Nicolson wrote:
> Thanks Asaf,
> Many thanks
> James
>> James,
>>> filtering
>> Thanks,
>> Asaf
>> Asaf Yaffe
Current Time: Wed Sep 18 23:31:46 GMT 2024
Powered by FUDForum. Page generated in 0.04942 seconds
