Re: Installing Eclipes second time [message #800122 is a reply to message #800047] |
Thu, 16 February 2012 18:04 |
On 2/16/2012 9:16 AM, Gaurav Panta wrote:
> can anyone guide me how to fix this issue that i have facing to install
> eclipes second time I have my java is installed in "c:\java"
My advice would be to download a proper JDK or (at least) JRE from Sun
rather than the C:\Windows\SYSTEM32\javaw.exe.
I would also ensure that the bittedness of the JRE you do use match that
of the Eclipse you downloaded, i.e.: 32 for 32 or 64 for 64.
Hope this helps.
Re: Installing Eclipes second time [message #800236 is a reply to message #800225] |
Thu, 16 February 2012 21:07 |
On 2/16/2012 1:54 PM, Gaurav Panta wrote:
> wait but to make eclipes work coz i have have the same error every time
> i try to run eclipes
If you come to this forum, you should take our advice.
C:\Windows\SYSTEM32\javaw.exe is not a proper JRE for running Eclipse
even though you've put it into eclipse.ini. Please download a JRE of the
proper bittedness from http://java.sun.com, install it, then tell
Eclipse where it is via what's in http://wiki.eclipse.org/Eclipse.ini .
Then come back if you have further questions.
FUDForum. Page generated in 0.08906 seconds
