Home » Archived » Test and Performance Tools Platform (TPTP) » Posting on behalf of Rakesh Sagar
Posting on behalf of Rakesh Sagar [message #94818] Tue, 03 April 2007 15:47 Go to next message
Hi Ali
Thank you for the replyl. I am following the following steps to execute the
testcase.
I am following the steps metioned in the tutorial for AGR.
< http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html>
Assuming that testsuite is created inside the plugin project,
1 I clicked the recording button to record a test case.
I clicked the artificial wait time button to increase the wait time since
one of the causes of failure was like finish button was disabled.
2. Select the project as java project with java perspective.Here I have
used AspectJ project as well as pageflow project(as javaproject and java
perspective.)as the project which I want to execute.
3. I named the project and clicked finish.
4. I then clicked terminate button on the recording panel.
5. I deleted the java project.
I then opened the testcase page of the test suite and chosing a command I
clicked the playback button.
The entire action was replayed. I then opened the behaviour page and
clicked the add child button to add a child.
6. I saved the child by selecting file-> save. Then I chose run->run under
the open page I then selected test ->new. I created a new test and selected
plugin projectname->test-resource->testsuite highlighting the test suite and
chosing local deployment i nthe right panel.
7. finally I click run.
8.The outcome could be
the entire sequence of steps is played in most of cases resulting in
test.execution file stating the result.
The result is pass for a simple java project.but in all other cases it
fails.even if I decide to put a simple java file I get test result as
failed.
the attached file error.doc contains the relevent stacktrace as well as the
screen shots for your perusal.
Could the memory leakage or less memory be the cause of failure. I am using
a work station with 2GB ram. also for the virtual machine I have provided
512Mb as max memory.
Thanks in advance
Thanks and Regards
Re: Posting on behalf of Rakesh Sagar [message #94834 is a reply to message #94818] Tue, 03 April 2007 15:51 Go to previous message
Two suggestion:
1) Don't use the artificial wait times. Some of the wait time periods are
longer than 30 seconds, and it is causing time-outs
2) Your macro is way too long, break it down into multiple test cases.
It'll be much easier to tell what is causing the failure if your macro is
short. For example you can create the following test cases:
CreateProject (create the projects needed)
CreateArtifacts (create the packages and the required classes)
ModifyFileContent (modify the content of your file)
Ali Mehregani
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:euub0t$jur$1@build.eclipse.org...
> Hi Ali
> the testcase.
> under the open page I then selected test ->new. I created a new test and
> selected plugin projectname->test-resource->testsuite highlighting the
> test suite and chosing local deployment i nthe right panel.
> failed.
> the screen shots for your perusal.
> using a work station with 2GB ram. also for the virtual machine I have
> provided 512Mb as max memory.
> Thanks in advance
> Thanks and Regards
Previous Topic:Problems with Code Coverage
Next Topic:Posting on behalf on Navid Mehregani
Current Time: Sat Nov 01 16:28:39 EDT 2025
Powered by FUDForum. Page generated in 0.28533 seconds
