Home » Newcomers » Newcomers » C++ Plug in for eclipse indigo on Mac X 10.7
Re: C++ Plug in for eclipse indigo on Mac X 10.7 [message #800767 is a reply to message #800758] |
Fri, 17 February 2012 13:19 |
On 2012.02.17 6:06, Hicks incoming wrote:
> Should I re-install eclipse because I need to use a platform called
> spoofax on it as well and I need it to be running properly to install
> the spoofax plug in.
If you're going to the trouble of re-installing Eclipse, why not install
Eclipse IDE for C/C++ Developers to start with? You'll get exactly the
right stuff for C/C++ development and you can add, as has been the topic
of discussion in this thread.
Best of luck.
Re: C++ Plug in for eclipse indigo on Mac X 10.7 [message #800906 is a reply to message #800896] |
Fri, 17 February 2012 17:09 |
On 2/17/2012 9:50 AM, Hicks incoming wrote:
> If I reinstall it with the C++ version, will I be able to install Java
> plugins, or is there a version that will run C, C++ Java, php, html,
> ASP. ? I need all of these for my course?
Yes, but you'll run into the same uncertainties. Eventually, you'll want
to continue asking for a hand here if Help -> Install New Software isn't
working for you. Best practice is NOT to download anything and try to
put it in the dropins folder. That's old school (although I'm pretty
sure there are still plug-ins that are distributed that way).
I maintain several Eclipse installations as I wouldn't be tempted to mix
C/C++ development with Java. The Eclipse IDE for Java EE Developers will
have all the web stuff and more than you could want for web development.
To that you could add PHP, for example.
It's hard to see why you'd ever be tempted to mix C/C++ with Java, but
hey, I don't know and I have tunnel vision.
Many like to do it all in one Eclipse; others, including me, prefer
separate Eclipses. For example, I won't mix Android with JEE
development, so I keep separate Eclipses, separate workspaces, etc., but
that's how I roll.
As for ASP (bite thy tongue!), I don't know that I've heard of doing
that in Eclipse. If I had to do it, and somehow decided not to slash my
wrists beforehand, I'd probably just use VisualStudio, which I know from
having used it to be a pretty damn good IDE. (It's just the wrong altar
to worship at.)
Best of luck,
Russ
Re: C++ Plug in for eclipse indigo on Mac X 10.7 [message #802922 is a reply to message #802828] |
Mon, 20 February 2012 17:04 |
On 2/20/2012 7:08 AM, Hicks incoming wrote:
> The only reason I wanted C++ , php and Java in the same eclipse package,
> was I just thought it would be easier/save space that way. If you think
> it would be better to start again using separate IDEs for different
> programs,I'll go with that. I'm not going to argue with you (you know
> more than me). I was always going to use Visual Basic for ASP, don't
> know why I put that in there?
You'll find just as many who like to dump it all into the same Eclipse
as those of us who keep it separate. It's probably more religious than real.
Current Time: Sat Apr 27 00:27:44 GMT 2024
Powered by FUDForum. Page generated in 0.09845 seconds
