Home » Modeling » OCL » Problem with Xtext based OCL and accessing inherited properties
Problem with Xtext based OCL and accessing inherited properties [message #799075] Wed, 15 February 2012 07:14 Go to next message
I found a weird behavior with the Xtext based OCL editors (including console) related to properties inherited from multiple classes:
I made this model example of 4 classes A,B,C and D to demonstrate:
module _'My.ecore'
package my : my = 'http://my.me/'
	class A
		attribute name : String[1] { ordered };
	class B
		attribute type : String[1] { ordered };
	class C extends B, A
		attribute required : Boolean[1] { ordered };
	class D
		attribute main : Boolean[1] { ordered };
		invariant myinv:
			main implies property.name <> '' and property.type <> '';
		property property : C[1] { ordered };
I got an error in the editor: unresolved property 'name' for 'My.ecore::my::C', but there is a property 'name' in type C it is inherited from A. The other inherited property 'type' works just fine.
The same happens if I try to use the Xtext OCL console from the context D: self.property.name:
My.xmi:
<?xml version="1.0" encoding="ASCII"?>
<my:D xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:my="http://my.me/" xsi:schemaLocation="http://my.me/ My.ecore">
  <property type="Type1" name="Name1"/>
</my:D>
Evaluating:
self
Results:
D false
Evaluating:
self.property.name
Results:
Parsing failure
null
Unresolved property 'name' for 'My.ecore::my::C'
Evaluating:
self.property.type
Results:
'Type1'
On the other hand from the old OCL console it works fine:
Evaluating:
self
Results:
D false
Evaluating:
self.property.name
Results:
'Name1'
Evaluating:
self.property.type
Results:
'Type1'
What is interesting that if I change the inheritance order of the class C to:
class C extends A, B
It will work file - both properties ('name' and 'type') are resolved just fine.
I don't know if it is a bug or I'm missing something?
Filip
EDIT: added test project.
  • Attachment: ocltest.zip
    (Size: 4.76KB, Downloaded 302 times)
[Updated on: Wed, 15 February 2012 07:16] by Moderator
Re: Problem with Xtext based OCL and accessing inherited properties [message #799255 is a reply to message #799075] Wed, 15 February 2012 11:58 Go to previous message
Hi Filip
Sorry; it's a bug in the Indigo Pivot release; lookups of secondary
bases fails.
Works fine in the Juno M5 release.
Ed Willink
On 15/02/2012 12:14, Filip Krikava wrote:
> module _'My.ecore'
> class A
> class B
> class D
> invariant myinv:
> My.xmi:
> </my:D>
> Evaluating:
> self
> Results:
> D false
> Evaluating:
> self.property.name
> Results:
> Parsing failure
> null
> Evaluating:
> self.property.type
> Results:
> 'Type1'
> Evaluating:
> self
> Results:
> D false
> Evaluating:
> self.property.name
> Results:
> 'Name1'
> Evaluating:
> self.property.type
> Results:
> 'Type1'
> class C to:
> just fine.
> Thanks
> Filip
Previous Topic:Getting the OCL File
Next Topic:[OCLInEcore] Cannot find operation
Current Time: Fri Nov 07 15:31:20 EST 2025
Powered by FUDForum. Page generated in 0.03433 seconds
