org.eclipse.ui.intro.universal exception during update [message #798638] |
Tue, 14 February 2012 23:17 |
Roshan S. Messages: 125 Registered: July 2009 |
I created an RCP app, and have a p2 build to release and deploy it. I deployed version 1.0.0 of my application with no problems and was able to create my update site so that I can update to versions 1.0.1 and 1.0.2.
Now I added Help contents to my RCP application and I am using the same build process but when I run an update I get the following exception:
An error occurred while collecting items to be installed
session context was:(profile=profile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact osgi.bundle,org.eclipse.ui.intro.universal,3.2.402.r36_v20100702 is a folder but the repository is an archive or remote location.
However, if I go to my update site machine and try a local update or if I build on the same machine and try an update. I am able to update successfully without any problems.
Is there any issue when trying to use a Web update site vs a local directory when you add help?
I searched around and the only information I could find was that my target platform was corrupt, but that can't be true because if I use a local update site I have no problem running the update.
Does anyone have any ideas?
Roshan
FUDForum. Page generated in 0.03342 seconds
