Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Problem using generated hibernate mapping file
Problem using generated hibernate mapping file [message #94611] |
Tue, 28 August 2007 11:27 |
Daniel Gerlach Messages: 36 Registered: July 2009 |
Member |
i want to use a self-generated mapping file because i have to change it a
litte.
My problem is that teneo don't find this file. I activated the
PersistenceOptions.USE_MAPPING_FILE,"true") and set the Properties in the
HbDataStore. My hibernate.hbm.xml is in the root of the classpath.
I also tried it with
PersistenceOptions.PERSISTENCE_XML,"absolutePath or relativePath ");
Both doesn't work.
I use teneo 0.8 and eclipse3.3. The hibernate.hbm.xml file was generated
with:
String mappingString =
HbHelper.INSTANCE.generateMapping(ePackages,persistenceOptio ns);
My code for the DataStore-initialization:
final String dataStoreName = "bpel20";
final HbDataStore dataStore = (HbDataStore) HbHelper.INSTANCE
.createRegisterDataStore(dataStoreName);
Properties hibernateProperties = new Properties();
hibernateProperties.setProperty(Environment.DRIVER,
"org.postgresql.Driver");
hibernateProperties.setProperty(Environment.USER, "postgres");
hibernateProperties.setProperty(Environment.URL,
"jdbc:postgresql://127.0.0.1:5432/bpel20");
hibernateProperties.setProperty(Environment.PASS, "XXXXX");
hibernateProperties.setProperty(Environment.DIALECT,
"org.hibernate.dialect.PostgreSQLDialect");
dataStore.setHibernateProperties(hibernateProperties);
Properties persistenceOptions = new Properties();
persistenceOptions.setProperty(PersistenceOptions.INHERITANC E_MAPPING,
"JOINED");
PersistenceOptions.FETCH_CONTAINMENT_EAGERLY,true");
persistenceOptions.setProperty(PersistenceOptions.SET_CASCAD E_ALL_ON_CONTAINMENT,
"true");
persistenceOptions.setProperty(PersistenceOptions.USE_MAPPIN G_FILE,
"true");
persistenceOptions.setProperty(PersistenceOptions.PERSISTENC E_XML,
dataStore.setPersistenceProperties(persistenceOptions);
dataStore.initialize();
With kind regards
Daniel Gerlach
Re: Problem using generated hibernate mapping file [message #94661 is a reply to message #94611] |
Tue, 28 August 2007 12:44 |
Hi Daniel,
Are you using the latest build (there was a bug a few builds back which caused the issue you are
describing?
You can also check if the hibernate.hbm.xml is really copied to the build/output folder?
gr. Martin
Daniel Gerlach wrote:
> Hello,
> a litte.
> the HbDataStore. My hibernate.hbm.xml is in the root of the classpath.
> Both doesn't work.
> with:
> "JOINED");
> "true");
> "true");
> With kind regards
> Daniel Gerlach
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Problem using generated hibernate mapping file [message #609566 is a reply to message #94611] |
Hi Daniel,
describing?
gr. Martin
> Hello,
> a litte.
> Both doesn't work.
> with:
> "JOINED");
> "true");
> "true");
> With kind regards
> Daniel Gerlach
The Netherlands
Current Time: Fri Apr 26 13:59:02 GMT 2024
Powered by FUDForum. Page generated in 0.02676 seconds
