Home » Eclipse Projects » EclipseLink » Validation to DDL constraint
Validation to DDL constraint [message #795060] Thu, 09 February 2012 21:31 Go to next message
Hi all. Im new on Eclipselink (come from Hibernate). If i use the hibernate jsr 303 implementation, constraints like @NotNull or @Size will be translated to ddl schema during database creation or i will need to write this constraints in a @Column to?
thanks...
Re: Validation to DDL constraint [message #795725 is a reply to message #795060] Fri, 10 February 2012 16:23 Go to previous messageGo to next message
EclipseLink's DDL generation uses JPA annotations and xml, so you will need to put constraints and sizes within the @Column annotations.
Re: Validation to DDL constraint [message #795774 is a reply to message #795725] Fri, 10 February 2012 18:01 Go to previous message
Thanks @Chris Delahunt.
As Hibernate can use the Validation API to create database schema, I only wanna sure that Eclipselink do it or no!
But no problem! I will write the database constraints in JPA too!
Att,
Eduardo Frazão
Previous Topic:org.eclipse.persistence.exceptions.ValidationException
Next Topic:Relative Path to JDBC-Url
Current Time: Thu Nov 13 00:37:49 EST 2025
Powered by FUDForum. Page generated in 0.07967 seconds
