Home » Newcomers » Newcomers » Removing Plugins
Removing Plugins [message #93620] Wed, 10 August 2005 02:47 Go to next message
How do I remove plugins?
I've searched over the preference menu, and tried help. But I can't
find any reference to it
Re: Removing Plugins [message #93649 is a reply to message #93620] Wed, 10 August 2005 05:21 Go to previous messageGo to next message
It depends on how you have installed these plug-ins?
If you just unzipped them and simply copied them in to eclipse home
directory, you need to delete them from
/plugins and /features manually.
Jason
Re: Removing Plugins [message #93766 is a reply to message #93649] Wed, 10 August 2005 15:18 Go to previous messageGo to next message
No I installed them through Help/Software Updates menu
But I guess you can just remove them manually anyway?
Re: Removing Plugins [message #93796 is a reply to message #93766] Wed, 10 August 2005 20:32 Go to previous messageGo to next message
In that case, you may find the plug-ins you have installed through
Help->Software Updates->Manage Configuration
where you can uninstall them.
Jason
Re: Removing Plugins [message #93841 is a reply to message #93796] Thu, 11 August 2005 02:26 Go to previous messageGo to next message
That was my problem, it wasn't there ('it' was the Tomcat Plugin from
Sysdeo), but there was still the Tomcat menu.
I was wanting to load up wtp and use its ability to operate with Tomcat.
I tried the manual stuff but failed. In the end it was easier to blow
the complete eclipse configuration away and install the wtp all-in-one tar.
Thanks for your help anyway
Re: Removing Plugins [message #94109 is a reply to message #93649] Fri, 12 August 2005 02:01 Go to previous messageGo to next message
It turns out that there is a gotcha with this.
within your workspace there is a directory .metadata/.plugins, and in
there are a whole load of configuration parameters that get carried
forward into any new configuration of eclipse that you have. Those
related to the plugins that you have used also need to be removed.
I have just been struggling for a few days with tomcat parameters that
my project continually was trying to use that were no longer relevant
(because I had removed the tomcat configuration and replaced it with
another one).
Re: Removing Plugins [message #94293 is a reply to message #94109] Fri, 12 August 2005 07:53 Go to previous messageGo to next message
> another one).
After you manually removed the plug-ins, have you ever try to start up
eclipse with the -clean parameter?
Re: Removing Plugins [message #94483 is a reply to message #94293] Fri, 12 August 2005 16:39 Go to previous message
>> another one).
Yes - but it didn't clean out those parameters.
Previous Topic:Eclipse Remote Debugging Source Not Found
Next Topic:Eclipse Update Problem
Current Time: Sun Nov 09 11:47:25 EST 2025
Powered by FUDForum. Page generated in 0.15608 seconds
