Home » Modeling » OCL » [OCLInEcore] Cannot find operation
| [OCLInEcore] Cannot find operation [message #794209] |
Wed, 08 February 2012 21:44  |
I have defined a operation with an argument in my ecore file, and when I call that operation in my eol file (to create a Metric rule in the gmfmap) this error occur:
!ENTRY Kaos.diagram 4 0 2012-02-09 02:36:23.408
!MESSAGE Expression problem:Cannot find operation (Test(Integer)) for the type (KAOS)body:self.Test(1)
!STACK 0
org.eclipse.ocl.SemanticException: Cannot find operation (Test(Integer)) for the type (KAOS)
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:352)
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:322)
at org.eclipse.ocl.internal.helper.HelperUtil.checkForErrors(HelperUtil.java:518)
at org.eclipse.ocl.internal.helper.HelperUtil.parseQuery(HelperUtil.java:165)
at org.eclipse.ocl.internal.helper.OCLHelperImpl.createQuery(OCLHelperImpl.java:176)
at org.eclipse.ocl.ecore.OCLHelperImpl.createQuery(OCLHelperImpl.java:90)
at KAOSStandard.diagram.expressions.KAOSStandardOCLFactory$Expression.<init>(KAOSStandardOCLFactory.java:113)
at KAOSStandard.diagram.expressions.KAOSStandardOCLFactory.getExpression(KAOSStandardOCLFactory.java:73)
at KAOSStandard.diagram.expressions.KAOSStandardOCLFactory.getExpression(KAOSStandardOCLFactory.java:57)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider.calcNLG(KAOSStandardMetricProvider.java:346)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider.calculateSemanticElementMetrics(KAOSStandardMetricProvider.java:147)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider$1.run(KAOSStandardMetricProvider.java:122)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider.calculateMetrics(KAOSStandardMetricProvider.java:116)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider$ResultView.setInput(KAOSStandardMetricProvider.java:386)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider$ResultView.createPartControl(KAOSStandardMetricProvider.java:482)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:534)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:662)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:570)
at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:568)
at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:272)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:981)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2714)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:3023)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:3004)
at org.eclipse.ui.internal.WorkbenchWindow$20.runWithException(WorkbenchWindow.java:2290)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3938)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3615)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
I've tried removing the argument from the operation and, with no arguments the operation is found. Does anyone know what may cause this problem? Thanks in advance.
| Re: [OCLInEcore] Cannot find operation [message #794643 is a reply to message #794357] |
Thu, 09 February 2012 09:33   |
I use the eol file to automatic create Metric Rules in the gmfmap. Actually to this problem I think the use of the eol file is not important, if instead of declaring the Metric Rule in the eol file I manually create it in the gmfmap the same error occur.
The operations in my emf file are stated like this (it's from the emf file that i generate the gmf editor)
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="i + 1")
!ordered op Integer Test(!ordered Integer[1] i);
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="1")
!ordered op Integer Test1();
If the problem is the incompatibility between the OCL used by the GMF Tooling and the OCLInEcore maybe by changing from the Pivot to the Traditional OCL could resolve this.
Edward Willink wrote on Thu, 09 February 2012 02:29
OCLinEcore supports editing of embedded OCL within Ecore; the editor
uses the new Pivot model; the subsequent usage may use either
traditional Ecore or Pivot model implementation depending what version
you have installed and/or what delegate execption point mappings you have.
So is it possible to change from Pivot to traditional OCL? If so, do you know how to do that?
Meanwhile I have installed the Juno eclipse but the same error happen. I'm using Eclipse Version: Indigo Service Release 1 Build id: 20110916-0149, GMF Tooling 2.4.1.201111211005, Epsilon 0.9.1.201110062346, Emfatic 0.3.0.200810132307.
[Updated on: Thu, 09 February 2012 09:45] by Moderator
| Re: [OCLInEcore] Cannot find operation [message #794765 is a reply to message #794643] |
Thu, 09 February 2012 12:18   |
Hi Patricia
Thanks. I thought you'd given me enough details to understand what seems
wrong, but actually I'm confused.
!ordered op void Test(!ordered EBigInteger[1] i);
is not in a language that I recognise. Is it Emfatic?
It would appear that there is doubt as to whether "1" is an EBigInteger.
I would expect the Pivot to be better here since it is fully polymorphic
between Integer/Long/BigInteger, whereas the Ecore support for
BigInteger is a bit selective.
You can easily change Pivot to non-Pivot by changing
to
http://www.eclipse.org/emf/2002/Ecore/OCL.
If you have the SDK loaded you could instead modify the delegate
registration extension points and so avoid editing files.
Ed Willink
On 09/02/2012 14:33, Patricia Espada wrote:
> !ordered op void Test();
>> version you have installed and/or what delegate execption point
>> mappings you have.
> Best regards,
| Re: [OCLInEcore] Cannot find operation [message #794823 is a reply to message #794765] |
Thu, 09 February 2012 13:39   |
I've endeavoured to check this and it works fine with the pivot model.
Your error is actually coming from a non-pivot parse. Have you tried
EInt or EInteger rather than EBigInteger?
Please post your EMF file.
Ed Willink
On 09/02/2012 17:18, Ed Willink wrote:
> Hi Patricia
> seems wrong, but actually I'm confused.
> EBigInteger. I would expect the Pivot to be better here since it is
> fully polymorphic between Integer/Long/BigInteger, whereas the Ecore
> support for BigInteger is a bit selective.
> to
> Regards
> Ed Willink
>>> mappings you have.
>> Best regards,
| Re: [OCLInEcore] Cannot find operation [message #794869 is a reply to message #794823] |
Thu, 09 February 2012 15:13   |
I've tried changing from Pivot to the Tradition OCL and nothing changed, as the same for using EInt or Integer (it seems the emfatic doesn't recognize EInteger) instead of EBigInteger. Here is my EMF file:
@gmf(foo="bar")
@Ecore(invocationDelegates="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot", settingDelegates="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot", validationDelegates="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot")
@namespace(uri="kaos", prefix="kaos")
package KAOSStandard;
@gmf.diagram(foo="bar")
class KAOS {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG())->size()")
!ordered op Integer NLG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG() and n.oclAsType(Goal).GNA() > 0)->size()")
!ordered op Integer NLGWA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.NLGWA() / self.NLG()", pre_nlgGZ="self.NLG() > 0")
!ordered op Double PLGWA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG() and n.oclAsType(Goal).GNO() > 0)->size()")
!ordered op Integer NLGWO();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.NLGWO() / self.NLG()", pre_nlgGZ="self.NLG() > 0")
!ordered op Double PLGWO();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Obstacle) and n.oclAsType(Obstacle).ILO())->size()")
!ordered op Integer NLO();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Obstacle) and n.oclAsType(Obstacle).ILO() and n.oclAsType(Obstacle).OS()->size() > 0)->size()")
!ordered op Integer NLOWS();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.NLOWS() / self.NLO()", pre_nloGZ="self.NLO() > 0")
!ordered op Double PLOWS();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG() and n.oclAsType(Goal).GNOp() > 0)->size()")
!ordered op Integer NLGWOp();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.NLGWOp() / self.NLG()", pre_nlgGZ="self.NLG() > 0")
!ordered op Double PLGWOp();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode))->size()")
!ordered op Integer NOp();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode) and n.oclAsType(OperationNode).OpNA() > 0)->size()")
!ordered op Integer NOpWA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.NOpWA() / self.NOp()", pre_nopGZ="self.NLG() > 0")
!ordered op Double POpWA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->iterate(n : Nodes ; min : Integer = - 1 | let aux : Integer = n.oclAsType(Agent).ANLG() in if min = - 1 then aux else min.min(aux) endif)")
!ordered op Integer MinNLGWA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->iterate(n : Nodes ; max : Integer = - 1 | let aux : Integer = n.oclAsType(Agent).ANLG() in if max = - 1 then aux else max.max(aux) endif)")
!ordered op Integer MaxNLGWA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->size()")
!ordered op Integer NA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.NLGWA() / self.NA()", pre_naGZ="self.NA() > 0")
!ordered op Double AveNLGWA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG())->iterate(n : Nodes ; min : Integer = - 1 | let aux : Integer = n.oclAsType(Goal).GNO() in if min = - 1 then aux else min.min(aux) endif)")
!ordered op Integer MinNOWLG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG())->iterate(n : Nodes ; max : Integer = - 1 | let aux : Integer = n.oclAsType(Goal).GNO() in if max = - 1 then aux else max.max(aux) endif)")
!ordered op Integer MaxNOWLG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.hasLinks->select(l : Links | l.oclIsKindOf(ConcernsLink))->collect(oclAsType(ConcernsLink).concernedByGoal)->select(g : Goal | g.ILG())->size()")
!ordered op Integer NLGC();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.NLGC() / self.NLG()", pre_nlgGZ="self.NLG() > 0")
!ordered op Double AveNOWLG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="let s : Set(Nodes) = Set{} in s->union(s1)->union(s2)")
!ordered op Nodes[*] union(!ordered Goal[*] s1, !ordered Nodes[*] s2);
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="let visit : Set(Nodes) = visited->including(g.oclAsType(Nodes)) in if g.ILG() then let obsts : Set(Obstacle) = g.goalHasObstacle->collect(obstacle)->asSet() in if obsts->notEmpty() then obsts->collect(o : Obstacle | NDR(o.oclAsType(Nodes), visit, dist->including(last + 1), last + 1))->asSet() else dist endif else union(g.goalIsAndRef->collect(andRefToOtherGoal)->union(g.goalIsOrRef->collect(orRefToOtherGoal))->asSet(), g.goalHasObstacle->collect(obstacle)->asSet())->collect(n : Nodes | NDR(n, visit, dist->including(last + 1), last + 1))->asSet() endif")
!ordered op Integer[*] GDR(!ordered Goal[1] g, !ordered Nodes[*] visited, !ordered Integer[*] dist, !ordered Integer[1] last);
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="let visit : Set(Nodes) = visited->including(o.oclAsType(Nodes)) in if o.ILO() then let goals : Set(Goal) = o.OS() in if goals->notEmpty() then goals->collect(g : Goal | NDR(g.oclAsType(Nodes), visit, dist->including(last + 1), last + 1))->asSet() else dist endif else o.OR()->collect(o : Obstacle | NDR(o.oclAsType(Nodes), visit, dist->including(last + 1), last + 1))->asSet() endif")
!ordered op Integer[*] ODR(!ordered Obstacle[1] o, !ordered Nodes[*] visited, !ordered Integer[*] dist, !ordered Integer[1] last);
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="if visited->one(aux : Nodes | aux = n) then dist else if n.oclIsKindOf(Goal) then self.GDR(n.oclAsType(Goal), visited, dist, last) else if n.oclIsKindOf(Obstacle) then self.ODR(n.oclAsType(Obstacle), visited, dist, last) else dist endif endif endif")
!ordered op Integer[*] NDR(!ordered Nodes[1] n, !ordered Nodes[*] visited, !ordered Integer[*] dist, !ordered Integer[1] last);
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.NDR(self.root.oclAsType(Nodes), Set{}, Set{0}, 0)->iterate(i : Integer ; maxD : Integer = - 1 | if maxD = - 1 then i else maxD.max(i) endif)")
!ordered op Integer MD();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.root.GSG()->size()")
!ordered op Integer RNSG();
val CompartmentNode[*] hasCompartmentNode;
val Nodes[*] hasNodes;
val Links[*] hasLinks;
ref Goal[1] root;
abstract class CompartmentNode {
attr String name;
@gmf.node(label="name", border.color="0,0,255", size="200,100", border.width="2", tool.description="Create new GoalCompartmentNode for inserting Goals, Requirements and Expectations in the diagram")
class GoalCompartmentNode extends CompartmentNode {
@gmf.compartment(layout="free")
val Goal[*] compHasGoals;
@gmf.node(label="name", border.color="0,100,0", size="200,100", border.width="2", tool.description="Create new SoftgoalCompartmentNode for inserting Softgoals in the diagram")
class SoftgoalCompartmentNode extends CompartmentNode {
val Softgoal[*] softgoalCompHasSoftgoals;
@gmf.node(label="name", border.color="255,165,0", size="200,100", border.width="2", tool.description="Create new ObstacleCompartmentNode for inserting Obstacles in the diagram")
class ObstacleCompartmentNode extends CompartmentNode {
val Obstacle[*] obstCompNodeHasObstacle;
@gmf.node(label="name", border.color="148,0,211", size="200,100", border.width="2", tool.description="Create new DomainPropertiesCompartmentNode for inserting Domain Invariants and Domain Hipothesis in the diagram")
class DomainPropertiesCompartmentNode extends CompartmentNode {
val DomainProperties[*] domProCompNodeHasDomProp;
@gmf.node(label="name", border.color="255,105,180", size="200,100", border.width="2", tool.description="Create new AgentCompartmentNode for inserting System Agents and Environment Agents in the diagram")
class AgentCompartmentNode extends CompartmentNode {
val Agent[*] agentCompHasAgent;
@gmf.node(label="name", border.color="165,42,42", size="200,100", border.width="2", tool.description="Create new ObjectCompartmentNode for creating Entities and Events in the diagram")
class ObjectCompartmentNode extends CompartmentNode {
ref Object[*] objCompHasObjects;
@gmf.node(label="name", size="200,100", border.width="2", tool.description="Create new OperationCompartmentNode for inserting Operations in the diagram")
class OperationCompartmentNode extends CompartmentNode {
ref OperationNode[*] hasOperationNodes;
@gmf.node(label="name", label.placement="external")
abstract class Nodes {
attr String name;
attr String TransformationSource;
attr String IstarActorContainer;
@gmf.node(color="0,191,255", border.color="0,191,255", size="80,50", figure="polygon", polygon.x="30 70 50 10", polygon.y="10 10 40 40", tool.description="Create new Goal")
class Goal extends Nodes {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.goalIsAndRef->isEmpty() and self.goalIsOrRef->isEmpty()")
!ordered op boolean[1] ILG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="let agents : Set(Agent) = self.GA() in if bool then agents else agents->union(self.otherGoalIsOrRef->collect(orRefToGoal)->union(self.otherGoalIsAndRef->collect(andRefToGoal))->collect(g : Goal | g.GIA(false))->asSet()) endif")
!ordered op Agent[*] GIA(!ordered Boolean[1] bool);
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="if self.oclIsKindOf(Expectation) then self.oclAsType(Expectation).EA() else if self.oclIsKindOf(Requirement) then self.oclAsType(Requirement).RA() else Set{} endif endif")
!ordered op Agent[*] GA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.GA()->union(self.GIA(true))->size()")
!ordered op Integer GNA();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.goalConcerns->collect(concernsObject)->size()")
!ordered op Integer GNO();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.goalToOperatLink->collect(operatLinkToOperationNode)->size()")
!ordered op Integer GNOp();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="let goals : Set(Goal) = self.goalIsOrRef->collect(orRefToOtherGoal)->union(self.goalIsAndRef->collect(andRefToOtherGoal))->asSet() in goals->select(g : Goal | g.ILG())->union(goals->select(g : Goal | not g.ILG())->collect(g : Goal | g.GLG()))->asSet()")
!ordered op Goal[*] GLG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="let goals : Set(Goal) = self.goalIsOrRef->collect(orRefToOtherGoal)->union(self.goalIsAndRef->collect(andRefToOtherGoal))->asSet()->union(self.goalHasObstacle->collect(obstacle)->iterate(o : Obstacle ; aux : Set(Goal) = Set{} | aux->union(o.OS()))) in if goals->isEmpty() then Set{} else goals->collect(g : Goal | goals->union(g.GSG()))->asSet() endif")
!ordered op Goal[*] GSG();
attr String formalDef;
attr String informalDef;
ref OrRefinement[*]#orRefToGoal goalIsOrRef;
ref OrRefinement[*]#orRefToOtherGoal otherGoalIsOrRef;
ref AndRefinement[*]#andRefToGoal goalIsAndRef;
ref AndRefinement[*]#andRefToOtherGoal otherGoalIsAndRef;
ref ObstructionLink[*]#obstacleToGoal goalHasObstacle;
ref SolutionLink[*]#obstacleHasSolution solutionIsGoal;
ref OperationalizationLink[*]#operatLinkToGoal goalToOperatLink;
ref ConcernsLink[*]#concernedByGoal goalConcerns;
ref DomainPropLink[*]#DomPropLinkToGoal goalHasDomProp;
@gmf.node(color="0,191,255", border.color="0,0,0", border.width="2", size="80,50", figure="polygon", polygon.x="30 70 50 10", polygon.y="10 10 40 40", tool.description="Create new Requirement")
class Requirement extends Goal {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.ReqToAgentReqLink->collect(ReqToAgentLink)->asSet()")
!ordered op Agent[*] RA();
ref AgentReqLink[+]#agentReqLinkToReq ReqToAgentReqLink;
@gmf.node(color="255,215,0", border.color="255,215,0", size="80,50", figure="polygon", polygon.x="30 70 50 10", polygon.y="10 10 40 40", tool.description="Create new Expectation")
class Expectation extends Goal {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.expToAgentExpLink->collect(expLinkToAgent)->asSet()")
!ordered op Agent[*] EA();
ref AgentExpLink[+]#agentExpLinkToExp expToAgentExpLink;
@gmf.node(color="50,205,50", border.color="50,205,50", size="40,40", figure="ellipse", tool.description="Create new Softgoal")
class Softgoal extends Goal {
@gmf.node(color="255,140,0", border.color="255,140,0", size="80,50", figure="polygon", polygon.x="10 50 70 30", polygon.y="10 10 40 40", tool.description="Create new Obstacle")
class Obstacle extends Nodes {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.obstIsParent->isEmpty()")
!ordered op boolean[1] ILO();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.obstIsRefinement->collect(obstToObstRef)->asSet()")
!ordered op Obstacle[*] OP();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.obstIsParent->collect(obstRefToObst)->asSet()")
!ordered op Obstacle[*] OR();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="let s : Set(Goal) = self.solution->collect(obstacleHasSolution)->asSet() in if visited->one(o : Obstacle | o = self) then s else self.OR()->iterate(o : Obstacle ; aux : Set(Goal) = s | aux->union(OBS(visited->including(self)))) endif")
!ordered op Goal[*] OBS(!ordered Obstacle[*] visited);
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="let s : Set(Goal) = self.solution->collect(obstacleHasSolution)->asSet() in if visited->one(o : Obstacle | o = self) then s else self.OP()->iterate(o : Obstacle ; aux : Set(Goal) = s | aux->union(OAS(visited->including(self)))) endif")
!ordered op Goal[*] OAS(!ordered Obstacle[*] visited);
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.OBS(Set{})->union(self.OAS(Set{}))")
!ordered op Goal[*] OS();
ref ObstructionLink[*]#obstacle obstacleObstruction;
ref SolutionLink[*]#obstacleSolution solution;
ref ObstacleRefinement[*]#obstRefToObst obstIsRefinement;
ref ObstacleRefinement[*]#obstToObstRef obstIsParent;
abstract class DomainProperties extends Nodes {
ref DomainPropLink[+]#goalToDomProp domPropToGoal;
@gmf.node(color="221,160,221", border.color="221,160,221", size="80,50", figure="polygon", polygon.x="10 40 70 70 10", polygon.y="20 10 20 40 40", tool.description="Create new DomainInvariant")
class DomainInvariant extends DomainProperties {
@gmf.node(color="147,112,219", border.color="147,112,219", size="80,50", figure="polygon", polygon.x="10 40 70 70 10", polygon.y="20 10 20 40 40", tool.description="Create new DomainHyphothesis")
class DomainHyphothesis extends DomainProperties {
abstract class Object extends Nodes {
ref InheritanceLink[*]#inhLinkToObject objToInhLink;
ref InheritanceLink[*]#inhLinkToOtherObj otherObjToInhLink;
ref AggregationLink[*]#aggLinkToObject objToAggLink;
ref AggregationLink[*]#aggLinkToOtherObject otherObjToAggLink;
ref CardinalityLink[*]#cardLinkToObject objToCardLink;
ref CardinalityLink[*]#cardLinkToOtherObject otherObjToCardLink;
ref MonitorsLink[*]#monLinkToObject objIsMonitored;
ref ControlsLink[*]#contLinkToObject objIsControlled;
ref ConcernsLink[*]#concernsObject objectIsConcerned;
abstract class Agent extends Object {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="if self.oclIsKindOf(EnvironmentAgent) then self.oclAsType(EnvironmentAgent).EAG() else if self.oclIsKindOf(SystemAgent) then self.oclAsType(SystemAgent).SAG() else Set{} endif endif")
!ordered op Goal[*] AG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.AG()->select(g : Goal | not g.ILG())->collect(g : Goal | g.GLG())->asSet()")
!ordered op Goal[*] AIG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.AG()->union(self.AIG())->select(g : Goal | g.ILG())")
!ordered op Goal[*] ALG();
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.ALG()->size()")
!ordered op Integer ANLG();
ref MonitorsLink[*]#monLinkToAgent agentMonitors;
ref ControlsLink[*]#contLinkToAgent agentControls;
ref PerformsLink[*]#perLinkToAgent agentPerforms;
@gmf.node(color="255,160,122", border.color="255,160,122", size="80,50", figure="polygon", polygon.x="10 20 60 70 60 20", polygon.y="25 40 40 25 10 10", tool.description="Create new SystemAgent")
class SystemAgent extends Agent {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.agentToReqLink->collect(agentReqLinkToReq)->asSet()")
!ordered op Goal[*] SAG();
ref AgentReqLink[+]#ReqToAgentLink agentToReqLink;
@gmf.node(color="255,182,193", border.color="255,182,193", size="80,50", figure="polygon", polygon.x="10 20 60 70 60 20", polygon.y="25 40 40 25 10 10", tool.description="Create new EnvironmentAgent")
class EnvironmentAgent extends Agent {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.agentToExpLink->collect(agentExpLinkToExp)->asSet()")
!ordered op Goal[*] EAG();
ref AgentExpLink[+]#expLinkToAgent agentToExpLink;
@gmf.node(color="189,183,107", border.color="189,183,107", size="80,50", figure="polygon", polygon.x="10 10 60 70 60", polygon.y="10 40 40 25 10", tool.description="Create new Event")
class Event extends Object {
attr int frequency;
@gmf.node(color="143,188,143", border.color="143,188,143", size="60,30", figure="rectangle", tool.description="Create new Entity")
class Entity extends Object {
@gmf.link(label="name", source="relationConnObject", target="objectIsConnByRelation", color="255,127,80", target.decoration="arrow", width="2", tool.description="Create new Relationship between two Objects")
class Relationship extends Object {
ref Object[1] relationConnObject;
ref Object[1] objectIsConnByRelation;
@gmf.node(color="211,211,211", border.color="211,211,211", size="60,30", figure="ellipse", tool.description="Create new OperationNode")
class OperationNode extends Nodes {
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(body="self.operationIsPerformed->collect(perLinkToAgent)->size()")
!ordered op Integer OpNA();
ref OperationalizationLink[*]#operatLinkToOperationNode operationNodeToOperatLink;
ref PerformsLink[*]#perLinkToOperationNode operationIsPerformed;
abstract class Links {
attr String name;
attr String Source;
attr String Target;
@Ecore(constraints="linkToHimself")
@gmf.link(source="orRefToGoal", target="orRefToOtherGoal", color="0,0,255", target.decoration="arrow", width="2", style="dash", tool.description="Create new OrRefinement between Goal, Requirement or Expectation")
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(linkToHimself="orRefToGoal <> orRefToOtherGoal", linkToHimself$message="'Goal ' + orRefToGoal.name + ' can not be a refinement of himself.'")
class OrRefinement extends Links {
ref Goal[1]#goalIsOrRef orRefToGoal;
ref Goal[1]#otherGoalIsOrRef orRefToOtherGoal;
@gmf.link(source="andRefToGoal", target="andRefToOtherGoal", color="0,0,255", target.decoration="arrow", width="2", tool.description="Create new AndRefinement between Goal, Requirement or Expectation")
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(linkToHimself="andRefToGoal <> andRefToOtherGoal", linkToHimself$message="'Goal ' + andRefToGoal.name + ' can not be a refinement of himself.'")
class AndRefinement extends Links {
ref Goal[1]#goalIsAndRef andRefToGoal;
ref Goal[1]#otherGoalIsAndRef andRefToOtherGoal;
@gmf.link(source="obstRefToObst", target="obstToObstRef", color="255,140,0", target.decoration="arrow", width="2", tool.description="Create new ObstacleRefinement between Obstacles")
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(linkToHimself="obstRefToObst <> obstToObstRef", linkToHimself$message="'Obstacle ' + obstRefToObst.name + ' can not be a refinement of himself.'")
class ObstacleRefinement extends Links {
ref Obstacle[1]#obstIsRefinement obstRefToObst;
ref Obstacle[1]#obstIsParent obstToObstRef;
@gmf.link(source="obstacle", target="obstacleToGoal", color="255,165,0", target.decoration="arrow", width="2", tool.description="Create new ObstructionLink between an Obstacle and a Goal, Requirement or Expectation")
class ObstructionLink extends Links {
ref Obstacle[1]#obstacleObstruction obstacle;
ref Goal[1]#goalHasObstacle obstacleToGoal;
@gmf.link(source="obstacleHasSolution", target="obstacleSolution", color="0,139,0", target.decoration="arrow", width="2", tool.description="Create new SolutionLink between an Obstacle and a Goal, Requirement or Expectation")
class SolutionLink extends Links {
ref Goal[1]#solutionIsGoal obstacleHasSolution;
ref Obstacle[1]#solution obstacleSolution;
@gmf.link(label="label", source="operatLinkToGoal", target="operatLinkToOperationNode", color="105,105,105", target.decoration="arrow", width="2", tool.description="Create new OperationalizationLink between an Operation and a Goal")
class OperationalizationLink extends Links {
readonly attr String[1] label = "Operationalization";
ref Goal[1]#goalToOperatLink operatLinkToGoal;
ref OperationNode[1]#operationNodeToOperatLink operatLinkToOperationNode;
@gmf.link(label="label", source="concernedByGoal", target="concernsObject", color="205,133,63", target.decoration="arrow", width="2", tool.description="Create new ConcernsLink between a Goal, Requirement or Expectation and an Object")
class ConcernsLink extends Links {
readonly attr String[1] label = "Concerns";
ref Goal[1]#goalConcerns concernedByGoal;
ref Object[1]#objectIsConcerned concernsObject;
@gmf.link(source="DomPropLinkToGoal", target="goalToDomProp", color="148,0,211", target.decoration="arrow", width="2", tool.description="Create new DomainPropLink between Goal, Requirement or Expectation and Domain Invariant or Domain Hipothesis")
class DomainPropLink extends Links {
ref Goal[1]#goalHasDomProp DomPropLinkToGoal;
ref DomainProperties[1]#domPropToGoal goalToDomProp;
@gmf.link(source="ReqToAgentLink", target="agentReqLinkToReq", color="233,150,122", target.decoration="arrow", width="2", tool.description="Create new AgentReqLink for connecting a System Agent to a Requirement")
class AgentReqLink extends Links {
ref SystemAgent[1]#agentToReqLink ReqToAgentLink;
ref Requirement[1]#ReqToAgentReqLink agentReqLinkToReq;
@gmf.link(source="expLinkToAgent", target="agentExpLinkToExp", color="176,48,96", target.decoration="arrow", width="2", tool.description="Create new AgentExpLink for connecting an Environment Agent to an Expectation")
class AgentExpLink extends Links {
ref EnvironmentAgent[1]#agentToExpLink expLinkToAgent;
ref Expectation[1]#expToAgentExpLink agentExpLinkToExp;
@gmf.link(source="inhLinkToObject", target="inhLinkToOtherObj", target.decoration="closedarrow", width="2", tool.description="Create new InheritanceLink between Entities")
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(linkToHimself="inhLinkToObject <> inhLinkToOtherObj", linkToHimself$message="'Object ' + inhLinkToObject.name + ' can not be a refinement of himself.'")
class InheritanceLink extends Links {
ref Object[1]#objToInhLink inhLinkToObject;
ref Object[1]#otherObjToInhLink inhLinkToOtherObj;
@gmf.link(source="aggLinkToObject", target="aggLinkToOtherObject", target.decoration="filledrhomb", width="2", tool.description="Create new AggregationLink between Entities")
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(linkToHimself="aggLinkToObject <> aggLinkToOtherObject", linkToHimself$message="'Object ' + aggLinkToObject.name + ' can not be a refinement of himself.'")
class AggregationLink extends Links {
ref Object[1]#objToAggLink aggLinkToObject;
ref Object[1]#otherObjToAggLink aggLinkToOtherObject;
@gmf.link(source="cardLinkToObject", target="cardLinkToOtherObject", width="2", tool.description="Create new CardinalityLink between Entities")
class CardinalityLink extends Links {
attr String[1] firstEnd;
attr String[1] secondEnd;
ref Object[1]#objToCardLink cardLinkToObject;
ref Object[1]#otherObjToCardLink cardLinkToOtherObject;
@gmf.link(label="label", source="monLinkToAgent", target="monLinkToObject", color="102,205,170", target.decoration="arrow", width="2", tool.description="Create new MonitorsLink between an Object and an Agent")
class MonitorsLink extends Links {
readonly attr String[1] label = "Monitors";
ref Agent[1]#agentMonitors monLinkToAgent;
ref Object[1]#objIsMonitored monLinkToObject;
@gmf.link(label="label", source="contLinkToAgent", target="contLinkToObject", color="34,139,34", target.decoration="arrow", width="2", tool.description="Create new ControlsLink between an Object and an Agent")
class ControlsLink extends Links {
readonly attr String[1] label = "Controls";
ref Agent[1]#agentControls contLinkToAgent;
ref Object[1]#objIsControlled contLinkToObject;
@gmf.link(label="label", source="perLinkToAgent", target="perLinkToOperationNode", color="0,0,0", target.decoration="arrow", width="2", tool.description="Create new PerformsLink between an Agent and an Operation")
class PerformsLink extends Links {
readonly attr String[1] label = "Performs";
ref Agent[1]#agentPerforms perLinkToAgent;
ref OperationNode[1]#operationIsPerformed perLinkToOperationNode;
@gmf.link(label="label", source="conflictBtwnGoals", target="goalHasConflict", color="205,0,0", source.decoration="arrow", target.decoration="arrow", width="2", style="dash", tool.description="Create new Conflict between Goals")
@"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"(linkToHimself="conflictBtwnGoals <> goalHasConflict", linkToHimself$message="'Goal ' + conflictBtwnGoals.name + ' can not be a refinement of himself.'")
class Conflict extends Links {
readonly attr String[1] label = "Conflict";
ref Goal[1] conflictBtwnGoals;
ref Goal[1] goalHasConflict;
and there is the error log:
!ENTRY Kaos.diagram 4 0 2012-02-09 20:11:22.221
!STACK 0
at KAOSStandard.diagram.expressions.KAOSStandardOCLFactory$Expression.<init>(KAOSStandardOCLFactory.java:114)
at KAOSStandard.diagram.expressions.KAOSStandardOCLFactory.getExpression(KAOSStandardOCLFactory.java:74)
at KAOSStandard.diagram.expressions.KAOSStandardOCLFactory.getExpression(KAOSStandardOCLFactory.java:58)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider.calcTest1(KAOSStandardMetricProvider.java:359)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider.calculateSemanticElementMetrics(KAOSStandardMetricProvider.java:148)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider$ResultView.setInput(KAOSStandardMetricProvider.java:414)
at KAOSStandard.diagram.providers.KAOSStandardMetricProvider$ResultView.createPartControl(KAOSStandardMetricProvider.java:510)
| Re: [OCLInEcore] Cannot find operation [message #794874 is a reply to message #794869] |
Thu, 09 February 2012 15:17   |
Hi Patricia
I'm afraid that is not an Ecore file. An Ecore File is an XMI file.
Please post the Ecore file.
Ed Willink
On 09/02/2012 20:13, Patricia Espada wrote:
> @gmf(foo="bar")
> class KAOS {
> endif)")
> endif)")
> : Links |
> endif endif")
> ref Goal[1] root;
> attr String name;
> attr String name;
> Set(Goal) =
> Set(Goal) =
> DomainInvariant")
> DomainHyphothesis")
> : Goal | g.ILG())")
> EnvironmentAgent")
> attr int frequency;
> OperationNode")
> attr String name;
> attr String Source;
> attr String Target;
> Expectation")
> or Expectation")
> Entities")
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> Best regards,
| Re: [OCLInEcore] Cannot find operation [message #794897 is a reply to message #794874] |
Thu, 09 February 2012 15:54   |
I'm sorry I though you said EMF file. Here it is the Ecore file:
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="KAOSStandard"
nsURI="kaos" nsPrefix="kaos">
<eAnnotations source="gmf">
<details key="foo" value="bar"/>
</eAnnotations>
<eAnnotations source="http://www.eclipse.org/emf/2002/Ecore">
<details key="invocationDelegates" value="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"/>
<details key="settingDelegates" value="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"/>
<details key="validationDelegates" value="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot"/>
</eAnnotations>
<eClassifiers xsi:type="ecore:EClass" name="KAOS">
<eAnnotations source="gmf.diagram">
</eAnnotations>
<eOperations name="Test" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<eAnnotations source="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot">
<details key="body" value="i + 1"/>
</eAnnotations>
<eParameters name="i" ordered="false" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject"/>
</eOperations>
<eOperations name="Test1" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="1"/>
</eAnnotations>
</eOperations>
<eOperations name="NLG" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG())->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="NLGWA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG() and n.oclAsType(Goal).GNA() > 0)->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="PLGWA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject">
<details key="body" value="self.NLGWA() / self.NLG()"/>
<details key="pre_nlgGZ" value="self.NLG() > 0"/>
</eAnnotations>
</eOperations>
<eOperations name="NLGWO" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG() and n.oclAsType(Goal).GNO() > 0)->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="PLGWO" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject">
<details key="body" value="self.NLGWO() / self.NLG()"/>
</eAnnotations>
</eOperations>
<eOperations name="NLO" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Obstacle) and n.oclAsType(Obstacle).ILO())->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="NLOWS" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Obstacle) and n.oclAsType(Obstacle).ILO() and n.oclAsType(Obstacle).OS()->size() > 0)->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="PLOWS" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject">
<details key="body" value="self.NLOWS() / self.NLO()"/>
<details key="pre_nloGZ" value="self.NLO() > 0"/>
</eAnnotations>
</eOperations>
<eOperations name="NLGWOp" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG() and n.oclAsType(Goal).GNOp() > 0)->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="PLGWOp" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject">
<details key="body" value="self.NLGWOp() / self.NLG()"/>
</eAnnotations>
</eOperations>
<eOperations name="NOp" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode))->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="NOpWA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode) and n.oclAsType(OperationNode).OpNA() > 0)->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="POpWA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject">
<details key="body" value="self.NOpWA() / self.NOp()"/>
<details key="pre_nopGZ" value="self.NLG() > 0"/>
</eAnnotations>
</eOperations>
<eOperations name="MinNLGWA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->iterate(n : Nodes ; min : Integer = - 1 | let aux : Integer = n.oclAsType(Agent).ANLG() in if min = - 1 then aux else min.min(aux) endif)"/>
</eAnnotations>
</eOperations>
<eOperations name="MaxNLGWA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->iterate(n : Nodes ; max : Integer = - 1 | let aux : Integer = n.oclAsType(Agent).ANLG() in if max = - 1 then aux else max.max(aux) endif)"/>
</eAnnotations>
</eOperations>
<eOperations name="NA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="AveNLGWA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject">
<details key="body" value="self.NLGWA() / self.NA()"/>
<details key="pre_naGZ" value="self.NA() > 0"/>
</eAnnotations>
</eOperations>
<eOperations name="MinNOWLG" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG())->iterate(n : Nodes ; min : Integer = - 1 | let aux : Integer = n.oclAsType(Goal).GNO() in if min = - 1 then aux else min.min(aux) endif)"/>
</eAnnotations>
</eOperations>
<eOperations name="MaxNOWLG" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).ILG())->iterate(n : Nodes ; max : Integer = - 1 | let aux : Integer = n.oclAsType(Goal).GNO() in if max = - 1 then aux else max.max(aux) endif)"/>
</eAnnotations>
</eOperations>
<eOperations name="NLGC" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.hasLinks->select(l : Links | l.oclIsKindOf(ConcernsLink))->collect(oclAsType(ConcernsLink).concernedByGoal)->select(g : Goal | g.ILG())->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="AveNOWLG" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject">
<details key="body" value="self.NLGC() / self.NLG()"/>
</eAnnotations>
</eOperations>
<eOperations name="union" ordered="false" upperBound="-1" eType="#//Nodes">
<details key="body" value="let s : Set(Nodes) = Set{} in s->union(s1)->union(s2)"/>
</eAnnotations>
<eParameters name="s1" ordered="false" upperBound="-1" eType="#//Goal"/>
<eParameters name="s2" ordered="false" upperBound="-1" eType="#//Nodes"/>
</eOperations>
<eOperations name="GDR" ordered="false" upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="let visit : Set(Nodes) = visited->including(g.oclAsType(Nodes)) in if g.ILG() then let obsts : Set(Obstacle) = g.goalHasObstacle->collect(obstacle)->asSet() in if obsts->notEmpty() then obsts->collect(o : Obstacle | NDR(o.oclAsType(Nodes), visit, dist->including(last + 1), last + 1))->asSet() else dist endif else union(g.goalIsAndRef->collect(andRefToOtherGoal)->union(g.goalIsOrRef->collect(orRefToOtherGoal))->asSet(), g.goalHasObstacle->collect(obstacle)->asSet())->collect(n : Nodes | NDR(n, visit, dist->including(last + 1), last + 1))->asSet() endif"/>
</eAnnotations>
<eParameters name="g" ordered="false" lowerBound="1" eType="#//Goal"/>
<eParameters name="visited" ordered="false" upperBound="-1" eType="#//Nodes"/>
<eParameters name="dist" ordered="false" upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject"/>
<eParameters name="last" ordered="false" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject"/>
</eOperations>
<eOperations name="ODR" ordered="false" upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="let visit : Set(Nodes) = visited->including(o.oclAsType(Nodes)) in if o.ILO() then let goals : Set(Goal) = o.OS() in if goals->notEmpty() then goals->collect(g : Goal | NDR(g.oclAsType(Nodes), visit, dist->including(last + 1), last + 1))->asSet() else dist endif else o.OR()->collect(o : Obstacle | NDR(o.oclAsType(Nodes), visit, dist->including(last + 1), last + 1))->asSet() endif"/>
</eAnnotations>
<eParameters name="o" ordered="false" lowerBound="1" eType="#//Obstacle"/>
</eOperations>
<eOperations name="NDR" ordered="false" upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="if visited->one(aux : Nodes | aux = n) then dist else if n.oclIsKindOf(Goal) then self.GDR(n.oclAsType(Goal), visited, dist, last) else if n.oclIsKindOf(Obstacle) then self.ODR(n.oclAsType(Obstacle), visited, dist, last) else dist endif endif endif"/>
</eAnnotations>
<eParameters name="n" ordered="false" lowerBound="1" eType="#//Nodes"/>
</eOperations>
<eOperations name="MD" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.NDR(self.root.oclAsType(Nodes), Set{}, Set{0}, 0)->iterate(i : Integer ; maxD : Integer = - 1 | if maxD = - 1 then i else maxD.max(i) endif)"/>
</eAnnotations>
</eOperations>
<eOperations name="RNSG" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.root.GSG()->size()"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="hasCompartmentNode" upperBound="-1"
eType="#//CompartmentNode" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="hasNodes" upperBound="-1"
eType="#//Nodes" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="hasLinks" upperBound="-1"
eType="#//Links" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="root" lowerBound="1" eType="#//Goal"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CompartmentNode" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="GoalCompartmentNode" eSuperTypes="#//CompartmentNode">
<eAnnotations source="gmf.node">
<details key="label" value="name"/>
<details key="border.color" value="0,0,255"/>
<details key="size" value="200,100"/>
<details key="border.width" value="2"/>
<details key="tool.description" value="Create new GoalCompartmentNode for inserting Goals, Requirements and Expectations in the diagram"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="compHasGoals" upperBound="-1"
eType="#//Goal" containment="true">
<eAnnotations source="gmf.compartment">
<details key="layout" value="free"/>
</eAnnotations>
</eStructuralFeatures>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="SoftgoalCompartmentNode" eSuperTypes="#//CompartmentNode">
<details key="border.color" value="0,100,0"/>
<details key="tool.description" value="Create new SoftgoalCompartmentNode for inserting Softgoals in the diagram"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="softgoalCompHasSoftgoals"
upperBound="-1" eType="#//Softgoal" containment="true">
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ObstacleCompartmentNode" eSuperTypes="#//CompartmentNode">
<details key="border.color" value="255,165,0"/>
<details key="tool.description" value="Create new ObstacleCompartmentNode for inserting Obstacles in the diagram"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="obstCompNodeHasObstacle"
upperBound="-1" eType="#//Obstacle" containment="true">
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DomainPropertiesCompartmentNode" eSuperTypes="#//CompartmentNode">
<details key="border.color" value="148,0,211"/>
<details key="tool.description" value="Create new DomainPropertiesCompartmentNode for inserting Domain Invariants and Domain Hipothesis in the diagram"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="domProCompNodeHasDomProp"
upperBound="-1" eType="#//DomainProperties" containment="true">
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AgentCompartmentNode" eSuperTypes="#//CompartmentNode">
<details key="border.color" value="255,105,180"/>
<details key="tool.description" value="Create new AgentCompartmentNode for inserting System Agents and Environment Agents in the diagram"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="agentCompHasAgent" upperBound="-1"
eType="#//Agent" containment="true">
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ObjectCompartmentNode" eSuperTypes="#//CompartmentNode">
<details key="border.color" value="165,42,42"/>
<details key="tool.description" value="Create new ObjectCompartmentNode for creating Entities and Events in the diagram"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="objCompHasObjects" upperBound="-1"
eType="#//Object">
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="OperationCompartmentNode" eSuperTypes="#//CompartmentNode">
<details key="tool.description" value="Create new OperationCompartmentNode for inserting Operations in the diagram"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="hasOperationNodes" upperBound="-1"
eType="#//OperationNode">
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Nodes" abstract="true">
<details key="label.placement" value="external"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="TransformationSource" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="IstarActorContainer" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Goal" eSuperTypes="#//Nodes">
<details key="color" value="0,191,255"/>
<details key="border.color" value="0,191,255"/>
<details key="size" value="80,50"/>
<details key="figure" value="polygon"/>
<details key="polygon.x" value="30 70 50 10"/>
<details key="polygon.y" value="10 10 40 40"/>
<details key="tool.description" value="Create new Goal"/>
</eAnnotations>
<eOperations name="ILG" ordered="false" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean">
<details key="body" value="self.goalIsAndRef->isEmpty() and self.goalIsOrRef->isEmpty()"/>
</eAnnotations>
</eOperations>
<eOperations name="GIA" ordered="false" upperBound="-1" eType="#//Agent">
<details key="body" value="let agents : Set(Agent) = self.GA() in if bool then agents else agents->union(self.otherGoalIsOrRef->collect(orRefToGoal)->union(self.otherGoalIsAndRef->collect(andRefToGoal))->collect(g : Goal | g.GIA(false))->asSet()) endif"/>
</eAnnotations>
<eParameters name="bool" ordered="false" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBooleanObject"/>
</eOperations>
<eOperations name="GA" ordered="false" upperBound="-1" eType="#//Agent">
<details key="body" value="if self.oclIsKindOf(Expectation) then self.oclAsType(Expectation).EA() else if self.oclIsKindOf(Requirement) then self.oclAsType(Requirement).RA() else Set{} endif endif"/>
</eAnnotations>
</eOperations>
<eOperations name="GNA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.GA()->union(self.GIA(true))->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="GNO" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.goalConcerns->collect(concernsObject)->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="GNOp" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.goalToOperatLink->collect(operatLinkToOperationNode)->size()"/>
</eAnnotations>
</eOperations>
<eOperations name="GLG" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="let goals : Set(Goal) = self.goalIsOrRef->collect(orRefToOtherGoal)->union(self.goalIsAndRef->collect(andRefToOtherGoal))->asSet() in goals->select(g : Goal | g.ILG())->union(goals->select(g : Goal | not g.ILG())->collect(g : Goal | g.GLG()))->asSet()"/>
</eAnnotations>
</eOperations>
<eOperations name="GSG" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="let goals : Set(Goal) = self.goalIsOrRef->collect(orRefToOtherGoal)->union(self.goalIsAndRef->collect(andRefToOtherGoal))->asSet()->union(self.goalHasObstacle->collect(obstacle)->iterate(o : Obstacle ; aux : Set(Goal) = Set{} | aux->union(o.OS()))) in if goals->isEmpty() then Set{} else goals->collect(g : Goal | goals->union(g.GSG()))->asSet() endif"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="formalDef" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="informalDef" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="goalIsOrRef" upperBound="-1"
eType="#//OrRefinement" eOpposite="#//OrRefinement/orRefToGoal"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="otherGoalIsOrRef" upperBound="-1"
eType="#//OrRefinement" eOpposite="#//OrRefinement/orRefToOtherGoal"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="goalIsAndRef" upperBound="-1"
eType="#//AndRefinement" eOpposite="#//AndRefinement/andRefToGoal"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="otherGoalIsAndRef" upperBound="-1"
eType="#//AndRefinement" eOpposite="#//AndRefinement/andRefToOtherGoal"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="goalHasObstacle" upperBound="-1"
eType="#//ObstructionLink" eOpposite="#//ObstructionLink/obstacleToGoal"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="solutionIsGoal" upperBound="-1"
eType="#//SolutionLink" eOpposite="#//SolutionLink/obstacleHasSolution"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="goalToOperatLink" upperBound="-1"
eType="#//OperationalizationLink" eOpposite="#//OperationalizationLink/operatLinkToGoal"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="goalConcerns" upperBound="-1"
eType="#//ConcernsLink" eOpposite="#//ConcernsLink/concernedByGoal"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="goalHasDomProp" upperBound="-1"
eType="#//DomainPropLink" eOpposite="#//DomainPropLink/DomPropLinkToGoal"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Requirement" eSuperTypes="#//Goal">
<details key="border.color" value="0,0,0"/>
<details key="tool.description" value="Create new Requirement"/>
</eAnnotations>
<eOperations name="RA" ordered="false" upperBound="-1" eType="#//Agent">
<details key="body" value="self.ReqToAgentReqLink->collect(ReqToAgentLink)->asSet()"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="ReqToAgentReqLink" lowerBound="1"
upperBound="-1" eType="#//AgentReqLink" eOpposite="#//AgentReqLink/agentReqLinkToReq"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Expectation" eSuperTypes="#//Goal">
<details key="color" value="255,215,0"/>
<details key="border.color" value="255,215,0"/>
<details key="tool.description" value="Create new Expectation"/>
</eAnnotations>
<eOperations name="EA" ordered="false" upperBound="-1" eType="#//Agent">
<details key="body" value="self.expToAgentExpLink->collect(expLinkToAgent)->asSet()"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="expToAgentExpLink" lowerBound="1"
upperBound="-1" eType="#//AgentExpLink" eOpposite="#//AgentExpLink/agentExpLinkToExp"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Softgoal" eSuperTypes="#//Goal">
<details key="color" value="50,205,50"/>
<details key="border.color" value="50,205,50"/>
<details key="size" value="40,40"/>
<details key="figure" value="ellipse"/>
<details key="tool.description" value="Create new Softgoal"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Obstacle" eSuperTypes="#//Nodes">
<details key="color" value="255,140,0"/>
<details key="border.color" value="255,140,0"/>
<details key="polygon.x" value="10 50 70 30"/>
<details key="tool.description" value="Create new Obstacle"/>
</eAnnotations>
<eOperations name="ILO" ordered="false" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean">
<details key="body" value="self.obstIsParent->isEmpty()"/>
</eAnnotations>
</eOperations>
<eOperations name="OP" ordered="false" upperBound="-1" eType="#//Obstacle">
<details key="body" value="self.obstIsRefinement->collect(obstToObstRef)->asSet()"/>
</eAnnotations>
</eOperations>
<eOperations name="OR" ordered="false" upperBound="-1" eType="#//Obstacle">
<details key="body" value="self.obstIsParent->collect(obstRefToObst)->asSet()"/>
</eAnnotations>
</eOperations>
<eOperations name="OBS" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="let s : Set(Goal) = self.solution->collect(obstacleHasSolution)->asSet() in if visited->one(o : Obstacle | o = self) then s else self.OR()->iterate(o : Obstacle ; aux : Set(Goal) = s | aux->union(OBS(visited->including(self)))) endif"/>
</eAnnotations>
<eParameters name="visited" ordered="false" upperBound="-1" eType="#//Obstacle"/>
</eOperations>
<eOperations name="OAS" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="let s : Set(Goal) = self.solution->collect(obstacleHasSolution)->asSet() in if visited->one(o : Obstacle | o = self) then s else self.OP()->iterate(o : Obstacle ; aux : Set(Goal) = s | aux->union(OAS(visited->including(self)))) endif"/>
</eAnnotations>
</eOperations>
<eOperations name="OS" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="self.OBS(Set{})->union(self.OAS(Set{}))"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="obstacleObstruction" upperBound="-1"
eType="#//ObstructionLink" eOpposite="#//ObstructionLink/obstacle"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="solution" upperBound="-1"
eType="#//SolutionLink" eOpposite="#//SolutionLink/obstacleSolution"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="obstIsRefinement" upperBound="-1"
eType="#//ObstacleRefinement" eOpposite="#//ObstacleRefinement/obstRefToObst"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="obstIsParent" upperBound="-1"
eType="#//ObstacleRefinement" eOpposite="#//ObstacleRefinement/obstToObstRef"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DomainProperties" abstract="true" eSuperTypes="#//Nodes">
<eStructuralFeatures xsi:type="ecore:EReference" name="domPropToGoal" lowerBound="1"
upperBound="-1" eType="#//DomainPropLink" eOpposite="#//DomainPropLink/goalToDomProp"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DomainInvariant" eSuperTypes="#//DomainProperties">
<details key="color" value="221,160,221"/>
<details key="border.color" value="221,160,221"/>
<details key="polygon.x" value="10 40 70 70 10"/>
<details key="polygon.y" value="20 10 20 40 40"/>
<details key="tool.description" value="Create new DomainInvariant"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DomainHyphothesis" eSuperTypes="#//DomainProperties">
<details key="color" value="147,112,219"/>
<details key="border.color" value="147,112,219"/>
<details key="tool.description" value="Create new DomainHyphothesis"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Object" abstract="true" eSuperTypes="#//Nodes">
<eStructuralFeatures xsi:type="ecore:EReference" name="objToInhLink" upperBound="-1"
eType="#//InheritanceLink" eOpposite="#//InheritanceLink/inhLinkToObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="otherObjToInhLink" upperBound="-1"
eType="#//InheritanceLink" eOpposite="#//InheritanceLink/inhLinkToOtherObj"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="objToAggLink" upperBound="-1"
eType="#//AggregationLink" eOpposite="#//AggregationLink/aggLinkToObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="otherObjToAggLink" upperBound="-1"
eType="#//AggregationLink" eOpposite="#//AggregationLink/aggLinkToOtherObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="objToCardLink" upperBound="-1"
eType="#//CardinalityLink" eOpposite="#//CardinalityLink/cardLinkToObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="otherObjToCardLink" upperBound="-1"
eType="#//CardinalityLink" eOpposite="#//CardinalityLink/cardLinkToOtherObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="objIsMonitored" upperBound="-1"
eType="#//MonitorsLink" eOpposite="#//MonitorsLink/monLinkToObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="objIsControlled" upperBound="-1"
eType="#//ControlsLink" eOpposite="#//ControlsLink/contLinkToObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="objectIsConcerned" upperBound="-1"
eType="#//ConcernsLink" eOpposite="#//ConcernsLink/concernsObject"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Agent" abstract="true" eSuperTypes="#//Object">
<eOperations name="AG" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="if self.oclIsKindOf(EnvironmentAgent) then self.oclAsType(EnvironmentAgent).EAG() else if self.oclIsKindOf(SystemAgent) then self.oclAsType(SystemAgent).SAG() else Set{} endif endif"/>
</eAnnotations>
</eOperations>
<eOperations name="AIG" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="self.AG()->select(g : Goal | not g.ILG())->collect(g : Goal | g.GLG())->asSet()"/>
</eAnnotations>
</eOperations>
<eOperations name="ALG" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="self.AG()->union(self.AIG())->select(g : Goal | g.ILG())"/>
</eAnnotations>
</eOperations>
<eOperations name="ANLG" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.ALG()->size()"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="agentMonitors" upperBound="-1"
eType="#//MonitorsLink" eOpposite="#//MonitorsLink/monLinkToAgent"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="agentControls" upperBound="-1"
eType="#//ControlsLink" eOpposite="#//ControlsLink/contLinkToAgent"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="agentPerforms" upperBound="-1"
eType="#//PerformsLink" eOpposite="#//PerformsLink/perLinkToAgent"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="SystemAgent" eSuperTypes="#//Agent">
<details key="color" value="255,160,122"/>
<details key="border.color" value="255,160,122"/>
<details key="polygon.x" value="10 20 60 70 60 20"/>
<details key="polygon.y" value="25 40 40 25 10 10"/>
<details key="tool.description" value="Create new SystemAgent"/>
</eAnnotations>
<eOperations name="SAG" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="self.agentToReqLink->collect(agentReqLinkToReq)->asSet()"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="agentToReqLink" lowerBound="1"
upperBound="-1" eType="#//AgentReqLink" eOpposite="#//AgentReqLink/ReqToAgentLink"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EnvironmentAgent" eSuperTypes="#//Agent">
<details key="color" value="255,182,193"/>
<details key="border.color" value="255,182,193"/>
<details key="tool.description" value="Create new EnvironmentAgent"/>
</eAnnotations>
<eOperations name="EAG" ordered="false" upperBound="-1" eType="#//Goal">
<details key="body" value="self.agentToExpLink->collect(agentExpLinkToExp)->asSet()"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="agentToExpLink" lowerBound="1"
upperBound="-1" eType="#//AgentExpLink" eOpposite="#//AgentExpLink/expLinkToAgent"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Event" eSuperTypes="#//Object">
<details key="color" value="189,183,107"/>
<details key="border.color" value="189,183,107"/>
<details key="polygon.x" value="10 10 60 70 60"/>
<details key="polygon.y" value="10 40 40 25 10"/>
<details key="tool.description" value="Create new Event"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="frequency" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Entity" eSuperTypes="#//Object">
<details key="color" value="143,188,143"/>
<details key="border.color" value="143,188,143"/>
<details key="size" value="60,30"/>
<details key="figure" value="rectangle"/>
<details key="tool.description" value="Create new Entity"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Relationship" eSuperTypes="#//Object">
<eAnnotations source="gmf.link">
<details key="source" value="relationConnObject"/>
<details key="target" value="objectIsConnByRelation"/>
<details key="color" value="255,127,80"/>
<details key="target.decoration" value="arrow"/>
<details key="width" value="2"/>
<details key="tool.description" value="Create new Relationship between two Objects"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="relationConnObject" lowerBound="1"
eType="#//Object"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="objectIsConnByRelation"
lowerBound="1" eType="#//Object"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="OperationNode" eSuperTypes="#//Nodes">
<details key="color" value="211,211,211"/>
<details key="border.color" value="211,211,211"/>
<details key="tool.description" value="Create new OperationNode"/>
</eAnnotations>
<eOperations name="OpNA" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject">
<details key="body" value="self.operationIsPerformed->collect(perLinkToAgent)->size()"/>
</eAnnotations>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="operationNodeToOperatLink"
upperBound="-1" eType="#//OperationalizationLink" eOpposite="#//OperationalizationLink/operatLinkToOperationNode"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="operationIsPerformed" upperBound="-1"
eType="#//PerformsLink" eOpposite="#//PerformsLink/perLinkToOperationNode"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Links" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Source" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Target" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="OrRefinement" eSuperTypes="#//Links">
<details key="constraints" value="linkToHimself"/>
</eAnnotations>
<details key="source" value="orRefToGoal"/>
<details key="target" value="orRefToOtherGoal"/>
<details key="color" value="0,0,255"/>
<details key="style" value="dash"/>
<details key="tool.description" value="Create new OrRefinement between Goal, Requirement or Expectation"/>
</eAnnotations>
<details key="linkToHimself" value="orRefToGoal <> orRefToOtherGoal"/>
<details key="linkToHimself$message" value="'Goal ' + orRefToGoal.name + ' can not be a refinement of himself.'"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="orRefToGoal" lowerBound="1"
eType="#//Goal" eOpposite="#//Goal/goalIsOrRef"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="orRefToOtherGoal" lowerBound="1"
eType="#//Goal" eOpposite="#//Goal/otherGoalIsOrRef"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AndRefinement" eSuperTypes="#//Links">
</eAnnotations>
<details key="source" value="andRefToGoal"/>
<details key="target" value="andRefToOtherGoal"/>
<details key="tool.description" value="Create new AndRefinement between Goal, Requirement or Expectation"/>
</eAnnotations>
<details key="linkToHimself" value="andRefToGoal <> andRefToOtherGoal"/>
<details key="linkToHimself$message" value="'Goal ' + andRefToGoal.name + ' can not be a refinement of himself.'"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="andRefToGoal" lowerBound="1"
eType="#//Goal" eOpposite="#//Goal/goalIsAndRef"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="andRefToOtherGoal" lowerBound="1"
eType="#//Goal" eOpposite="#//Goal/otherGoalIsAndRef"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ObstacleRefinement" eSuperTypes="#//Links">
</eAnnotations>
<details key="source" value="obstRefToObst"/>
<details key="target" value="obstToObstRef"/>
<details key="tool.description" value="Create new ObstacleRefinement between Obstacles"/>
</eAnnotations>
<details key="linkToHimself" value="obstRefToObst <> obstToObstRef"/>
<details key="linkToHimself$message" value="'Obstacle ' + obstRefToObst.name + ' can not be a refinement of himself.'"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="obstRefToObst" lowerBound="1"
eType="#//Obstacle" eOpposite="#//Obstacle/obstIsRefinement"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="obstToObstRef" lowerBound="1"
eType="#//Obstacle" eOpposite="#//Obstacle/obstIsParent"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ObstructionLink" eSuperTypes="#//Links">
<eAnn
[Updated on: Thu, 09 February 2012 18:07] by Moderator
| Re: [OCLInEcore] Cannot find operation [message #797642 is a reply to message #796257] |
Mon, 13 February 2012 13:40   |
I've installed the Eclipse Modeling SR2 RC3 EPP from the link you've send me, and add the GMF plugin, Emfatic and Epsilon interim version. Now I can call the operations I had defined in the ecore in the OCLConsole. The problem now is when I try to create the GMF editor I get new error's:
Description Resource Path Location Type
T_KAOS_ecore__KAOSStandard__Goal cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
IP_OrRefinement_orRefToGoal cannot be resolved OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
valueFactory cannot be resolved OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
The constructor ExecutorOperation(String, EcoreExecutorType, int, KAOSBodies._union_body_, EcoreExecutorType, EcoreExecutorType) is undefined KAOSStandardTables.java /Test/src/KAOSStandard line 486 Java Problem
P_Nodes_name cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
valueFactory cannot be resolved ConflictBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
_EIntegerObject cannot be resolved or is not a field KAOSStandardTables.java /Test/src/KAOSStandard line 483 Java Problem
S_Goal_ cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
S_Goal_ cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
standardLibrary cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
O_String__add_ cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
standardLibrary cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
P_OrRefinement_orRefToGoal cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
_EIntegerObject cannot be resolved or is not a field KAOSStandardTables.java /Test/src/KAOSStandard line 429 Java Problem
T_KAOS_ecore__KAOSStandard__Goal cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
P_Conflict_conflictBtwnGoals cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
_EBooleanObject cannot be resolved or is not a field KAOSStandardTables.java /Test/src/KAOSStandard line 407 Java Problem
IP_Nodes_name cannot be resolved OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
T_String cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
_EIntegerObject cannot be resolved or is not a field KAOSStandardTables.java /Test/src/KAOSStandard line 468 Java Problem
IP_Nodes_name cannot be resolved ConflictBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
P_Nodes_name cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
_EIntegerObject cannot be resolved or is not a field KAOSStandardTables.java /Test/src/KAOSStandard line 445 Java Problem
T_String cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
O_String__add_ cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
T_String cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
S__can_not___ cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
IP_Conflict_conflictBtwnGoals cannot be resolved ConflictBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
T_String cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
S_Goal_ cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
valueFactory cannot be resolved OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 79 Java Problem
standardLibrary cannot be resolved to a variable OrRefinementBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
valueFactory cannot be resolved ConflictBodies.java /Test/src/KAOSStandard/bodies line 79 Java Problem
S_Goal_ cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
T_String cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
O_String__add_ cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
S__can_not___ cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
T_String cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
O_String__add_ cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
standardLibrary cannot be resolved to a variable ConflictBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
_TT cannot be resolved or is not a field KAOSImpl.java /Test/src/KAOSStandard/impl line 253 Java Problem
IP_ObstacleRefinement_obstRefToObst cannot be resolved ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
T_KAOS_ecore__KAOSStandard__Obstacle cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
valueFactory cannot be resolved ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
S_Obstacle___ cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
standardLibrary cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
O_String__add_ cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
P_ObstacleRefinement_obstRefToObst cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
IP_Nodes_name cannot be resolved ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
T_String cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
P_Nodes_name cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
T_String cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
O_String__add_ cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
S__can_not___ cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
S_Obstacle___ cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
T_String cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
standardLibrary cannot be resolved to a variable ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
valueFactory cannot be resolved ObstacleRefinementBodies.java /Test/src/KAOSStandard/bodies line 79 Java Problem
standardLibrary cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
S_Object_ cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
T_String cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
O_String__add_ cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
valueFactory cannot be resolved InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 79 Java Problem
S_Object_ cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
O_String__add_ cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
standardLibrary cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
IP_InheritanceLink_inhLinkToObject cannot be resolved InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
P_InheritanceLink_inhLinkToObject cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
T_KAOS_ecore__KAOSStandard__Object cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
T_String cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
IP_Nodes_name cannot be resolved InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
valueFactory cannot be resolved InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
P_Nodes_name cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
T_String cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
S__can_not___ cannot be resolved to a variable InheritanceLinkBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
S_Object_ cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
valueFactory cannot be resolved AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
P_Nodes_name cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
T_String cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
IP_Nodes_name cannot be resolved AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
P_AggregationLink_aggLinkToObject cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
T_KAOS_ecore__KAOSStandard__Object cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
IP_AggregationLink_aggLinkToObject cannot be resolved AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
T_String cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
O_String__add_ cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
standardLibrary cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
valueFactory cannot be resolved AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 79 Java Problem
S_Object_ cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
T_String cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
O_String__add_ cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
standardLibrary cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
AbstractOperation cannot be resolved to a type KAOSBodies.java /Test/src/KAOSStandard/bodies line 1236 Java Problem
The method evaluate(DomainEvaluator, DomainCallExp, Value, Value...) in the type LibraryOperation is not applicable for the arguments (DomainEvaluator, DomainCollectionType, Value, Value, Value, Value, IntegerValue) KAOSBodies.java /Test/src/KAOSStandard/bodies line 570 Java Problem
The method evaluate(DomainEvaluator, DomainCallExp, Value, Value...) in the type LibraryOperation is not applicable for the arguments (DomainEvaluator, DomainCollectionType, Value, Value, Value, Value, Value) KAOSBodies.java /Test/src/KAOSStandard/bodies line 490 Java Problem
The method evaluate(DomainEvaluator, DomainCallExp, Value, Value...) in the type LibraryOperation is not applicable for the arguments (DomainEvaluator, DomainCollectionType, Value, Value, Value, Value, Value) KAOSBodies.java /Test/src/KAOSStandard/bodies line 345 Java Problem
AbstractOperation cannot be resolved to a type KAOSBodies.java /Test/src/KAOSStandard/bodies line 178 Java Problem
The import AbstractTernaryOperation cannot be resolved KAOSBodies.java /Test/src/KAOSStandard/bodies line 13 Java Problem
The import AbstractOperation cannot be resolved KAOSBodies.java /Test/src/KAOSStandard/bodies line 12 Java Problem
valueFactory cannot be resolved AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 79 Java Problem
standardLibrary cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
O_String__add_ cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 80 Java Problem
T_String cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
standardLibrary cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
O_String__add_ cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 77 Java Problem
T_String cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
S_Goal_ cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 78 Java Problem
The method evaluate(DomainEvaluator, DomainCallExp, Value, Value...) in the type LibraryOperation is not applicable for the arguments (DomainEvaluator, DomainCollectionType, Value, Value, Value, Value, Value) KAOSBodies.java /Test/src/KAOSStandard/bodies line 2518 Java Problem
AbstractTernaryOperation cannot be resolved to a type KAOSBodies.java /Test/src/KAOSStandard/bodies line 2944 Java Problem
The method evaluate(DomainEvaluator, DomainCallExp, Value, Value...) in the type LibraryOperation is not applicable for the arguments (DomainEvaluator, DomainCollectionType, Value, Value, Value, Value, Value) KAOSBodies.java /Test/src/KAOSStandard/bodies line 1323 Java Problem
S__can_not___ cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
The method evaluate(DomainEvaluator, DomainCallExp, Value, Value...) in the type LibraryOperation is not applicable for the arguments (DomainEvaluator, DomainCollectionType, Value, Value, Value, Value, Value) KAOSBodies.java /Test/src/KAOSStandard/bodies line 1343 Java Problem
AbstractOperation cannot be resolved to a type KAOSBodies.java /Test/src/KAOSStandard/bodies line 2337 Java Problem
The method evaluate(DomainEvaluator, DomainCallExp, Value, Value...) in the type LibraryOperation is not applicable for the arguments (DomainEvaluator, DomainCollectionType, Value, Value, Value, Value, Value) KAOSBodies.java /Test/src/KAOSStandard/bodies line 2453 Java Problem
S__can_not___ cannot be resolved to a variable AggregationLinkBodies.java /Test/src/KAOSStandard/bodies line 81 Java Problem
P_Nodes_name cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
T_String cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
S_Goal_ cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
valueFactory cannot be resolved AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 76 Java Problem
T_KAOS_ecore__KAOSStandard__Goal cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
IP_AndRefinement_andRefToGoal cannot be resolved AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
IP_Nodes_name cannot be resolved AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 74 Java Problem
P_AndRefinement_andRefToGoal cannot be resolved to a variable AndRefinementBodies.java /Test/src/KAOSStandard/bodies line 72 Java Problem
With this I cannot see if in this installation the GMF editor accepts the call of operations with arguments in the Metric Rule.
Because I couldn't figure the solution to the above problem, I've tried with a brand new installation of the Eclipse Indigo SR1 3.7.1. There a add the GMF plugin, OCL SR2 RC3 (from the link you send me), Emfatic, and Epsilon interim version. In this new installation I manage to get the operations working in the OCLConsole. With that working I generate the GMF editor and add a Metric Rule that calls the Test operation. I run a new eclipse instance and when ask to show the metrics (in Edit->Metrics) the same error is throw: Cannot find operation (Test(Integer)) for the type (KAOS). I've tried change from OCL/Pivot to OCL but I didn't work either.
| Re: [OCLInEcore] Cannot find operation [message #797649 is a reply to message #797642] |
Mon, 13 February 2012 13:49   |
The Bodies are produced by the new direct OCL to Java code generator.
We don't want this extra confusion while debugging your current problem
so insert
<genAnnotations source="http://www.eclipse.org/OCL/GenModel">
<details key="Use Delegates" value="true"/>
</genAnnotations>
just before
<foreignModel>...</foreignModel>
<genPackages prefix="...
to disable it in your genmodel. Then re-genmodel, and for good measure
delete the "bodies" package, and ...Tables.java file.
Ed
On 13/02/2012 18:41, Patricia Espada wrote:
> get new error's:
> Java Problem
> Java Problem
> 486 Java Problem
> Java Problem
> Problem
> Java Problem
> Java Problem
> Java Problem
> Java Problem
> Problem
> Java Problem
> Java Problem
> Problem
> Java Problem
> Problem
> Java Problem
> Problem
> Java Problem
> Java Problem
> Java Problem
> Java Problem
> Java Problem
> Java Problem
> Java Problem
> Java Problem
> Java Problem
> Java Problem
> 72 Java Problem
> 76 Java Problem
> 77 Java Problem
> 77 Java Problem
> 72 Java Problem
> 74 Java Problem
> 74 Java Problem
> 81 Java Problem
> 80 Java Problem
> 81 Java Problem
> 78 Java Problem
> 78 Java Problem
> 80 Java Problem
> 77 Java Problem
> 76 Java Problem
> 78 Java Problem
> 77 Java Problem
> 78 Java Problem
> 80 Java Problem
> 80 Java Problem
> 72 Java Problem
> 72 Java Problem
> 72 Java Problem
> 74 Java Problem
> 74 Java Problem
> 81 Java Problem
> 81 Java Problem
> 76 Java Problem
> 74 Java Problem
> 74 Java Problem
> 72 Java Problem
> 72 Java Problem
> 72 Java Problem
> 81 Java Problem
> 80 Java Problem
> 80 Java Problem
> 78 Java Problem
> 78 Java Problem
> 77 Java Problem
> 77 Java Problem
> 490 Java Problem
> 345 Java Problem
> Problem
> 80 Java Problem
> 80 Java Problem
> 81 Java Problem
> 77 Java Problem
> 77 Java Problem
> 78 Java Problem
> 78 Java Problem
> 2518 Java Problem
> Problem
> 1323 Java Problem
> 81 Java Problem
> 1343 Java Problem
> 2453 Java Problem
> 81 Java Problem
> 74 Java Problem
> 74 Java Problem
> 76 Java Problem
> 72 Java Problem
> 72 Java Problem
> 72 Java Problem
> Best regards,
| Re: [OCLInEcore] Cannot find operation [message #799260 is a reply to message #799235] |
Wed, 15 February 2012 12:03   |
Hi Patricia
At last you're past the OCL issues. I'm afraid your new problem has no
hint of any OCL routines; it looks to be all GUI related, so I cannot
offer much help.
I notice a few "e4" packages; so you're probably using 4.2M5 rather than
3.8M5. Generally the e4 compatibility is extremely good, but just
possibly you've found a problem that needs attention.
The GMT tooling team has come back to life so you might see if they can
help.
Ed Willink
On 15/02/2012 16:31, Patricia Espada wrote:
> Thank you Edward, that worked, now the metrics work just fine in the
> GMF editor. On the other hand, when I run a new eclipse instance with
> the GMF editor, these errors are throw:
> java.lang.Exception: fill(MToolBar container, IContributionManager
> manager) with rogue contribution manager:
> org.eclipse.gmf.runtime.common.ui.services.action.contributionitem.AbstractContributionItemProvider$PluginMenuManager@1d64969
> at
> org.eclipse.ui.internal.CoolBarToTrimManager.fill(CoolBarToTrimManager.java:628)
> at
> org.eclipse.ui.internal.CoolBarToTrimManager.update(CoolBarToTrimManager.java:599)
> at
> org.eclipse.ui.internal.WorkbenchWindow.updateActionBars(WorkbenchWindow.java:1784)
> at
> org.eclipse.ui.internal.WWinActionBars.updateActionBars(WWinActionBars.java:113)
> at
> org.eclipse.ui.SubActionBars.updateActionBars(SubActionBars.java:611)
> at
> org.eclipse.ui.internal.e4.compatibility.ActionBars.updateActionBars(ActionBars.java:113)
> at
> org.eclipse.ui.navigator.NavigatorActionService.fillActionBars(NavigatorActionService.java:266)
> at
> org.eclipse.ui.navigator.CommonNavigatorManager$2.run(CommonNavigatorManager.java:92)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> org.eclipse.ui.navigator.CommonNavigatorManager$UpdateActionBarsJob.runInUIThread(CommonNavigatorManager.java:87)
> at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
> at
> org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3945)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3622)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:999)
> at
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:893)
> at
> org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:85)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:579)
> at
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:534)
> at
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> at
> at
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:352)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
> at
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:624)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:579)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1433)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1409)
> Do you know why this is happening?
> Best regards,
Current Time: Mon Oct 27 20:58:01 EDT 2025
Powered by FUDForum. Page generated in 0.06317 seconds
