Re: Generate an a .adapter file [message #94040 is a reply to message #93435] |
Fri, 23 March 2007 14:43 |
Originally posted by: cindyjin.ca.ibm.com
Hi Johan:
You can use the GLA model which is an EMF model created in
org.eclipse.tptp.platform.models plugin You can use
org.eclipse.hyades.logging.adapter.model.internal.adapter.Ad apterFactory
to create the .adapter file. Right now this model is defined as
internal . I discussed with the owner of the model. He suggested that
you can use this model,but there is no guaranteed backward compatibility
in the future, since it is internal APIS. You can open a bugzilla
against GLA component, request programmatically generate .adapter file.
Also if you don't want to use the internal APIs you can write an xml
parser to generate the file because the .adapter is XML file indeed.
Hope this can help you.
Cindy
Johan Andersson wrote:
> Hi
> I been trying to generate a .adapter file programmatically (for a
> plugin-project extension) but both the
> AdaptorModelWizard and AdaptorModelWizardNewFileCreationPage
> are internal along with all the logic to create a adapter (foramtter,
> extractor outputter etc). Is there any open API's for creating own .adapter
> file ? Found the GLA API's but they assumes that you already have an adaper
> configurations file, the one i would like compose and generate
> programmatically (not thru the GUI).
> Im using eclipse 3.2, TPTP 4.2.1
> Brgds Johan
Re: Generate an a .adapter file [message #94280 is a reply to message #94040] |
Tue, 27 March 2007 14:47 |
Johan Messages: 12 Registered: July 2009 |
Thank you Cindy.
My soulution to this was to use the OptionTemplateSection -Class
public class StaticAdapterTemplate extends OptionTemplateSection
In the updateModel method i used following code to generate my plugin.xml
protected void updateModel(IProgressMonitor monitor) throws CoreException {
IPluginBase plugin = model.getPluginBase();
IPluginModelFactory factory = model.getPluginFactory();
String staticParserFullName =
templateOptions.get(KEY_PACKAGE_NAME)+"."+templateOptions.get(Constants.KEY_PARSER_CLASS_NAME);
String staticParserWrapperFullName =
templateOptions.get(KEY_PACKAGE_NAME)+"." +templateOptions.get(Constants.KEY_PARSER_WRAPPER_CLASS_NAME );
String staticParserName = templateOptions.get(Constants.KEY_PARSER_NAME);
IPluginExtension extension =
createExtension("org.eclipse.hyades.logging.parsers.logParser ", true);
IPluginElement element = factory.createElement(extension);
element.setName("parser");
element.setAttribute("id", staticParserFullName);
element.setAttribute("name", "my.package..StaticParser");
element.setAttribute("icon", "icons/log_parser_obj.gif");
element.setAttribute("description", "Static Parser v1.0");
element.setAttribute("ui_name", staticParserName);
element.setAttribute("class", staticParserWrapperFullName);
IPluginElement fieldElement = factory.createElement(element);
fieldElement.setName("field"); //$NON-NLS-1$
fieldElement.setAttribute("useBrowse", "true");
fieldElement.setAttribute("defaultValue", "");
fieldElement.setAttribute("name", "Directory");
fieldElement.setAttribute("helpContextId", "");
fieldElement.setAttribute("tooltip", "Enter the location of the log file");
fieldElement.setAttribute("id", "file_path");
fieldElement.setAttribute("browseType", "*.log");
element.add(fieldElement);
IPluginElement fieldElement2 = factory.createElement(element);
fieldElement2.setName("parserParameter"); //$NON-NLS-1$
fieldElement2.setAttribute("name", "Default");
fieldElement2.setAttribute("value",
"./adapter/"+getStringOption(Constants.KEY_ADAPTER_NAME));
element.add(fieldElement2);
extension.add(element);
plugin.add(extension);
Together with a NewPluginTemplateWizard this works fine for creating an
plugin.xml.
// Johan
"Cindy Jin" <cindyjin@ca.ibm.com> wrote in message
news:eu0p35$31s$1@utils.eclipse.org...
> Hi Johan:
> to create the .adapter file. Right now this model is defined as internal .
> I discussed with the owner of the model. He suggested that you can use
> this model,but there is no guaranteed backward compatibility in the
> future, since it is internal APIS. You can open a bugzilla against GLA
> component, request programmatically generate .adapter file. Also if you
> don't want to use the internal APIs you can write an xml parser to
> Thanks
> Cindy
>> Hi
>> .adapter file ? Found the GLA API's but they assumes that you already
>> have an adaper configurations file, the one i would like compose and
>> generate programmatically (not thru the GUI).
>> Brgds Johan
FUDForum. Page generated in 0.03766 seconds
