Re: My projects look strange after updating eclipse [message #792923 is a reply to message #792862] |
Tue, 07 February 2012 15:14 |
On 2/7/2012 7:01 AM, Andreas Lindmark wrote:
> I am working on a project with another person, and he can see all his
> projects as normal (he has the same plugin). One thing the mercurial
> plugin adds is the black icon, but otherwise the problem seems to have
> little to do with the plugin and everthing to do with eclipse itself.
What icons bother you? Are you sure it's not Mercurial? What you're
specifically complaining about is usually imposed by the version-control
plug-in you're consuming.
The yellow "cylinder" decoration (what this is called by Eclipse docs)
at the bottom right means "this file (or folder) is under source-code
control." The black decoration with a star in it means that the file has
changed since last committed.
http://www.javahotchocolate.com/notes/eclipse.html#icons
FUDForum. Page generated in 0.08825 seconds
