Home » Modeling » EMF » Why EObject NOT Concrete Type?
Why EObject NOT Concrete Type? [message #791695] Mon, 06 February 2012 01:26 Go to next message
HI, I created an EMF model base on a schema without namespace. There are
two complex types one name 'foo' and the other is 'bar', Element
contains an attribute 'id' whose tpe is 'xsd:ID'. Element contains an
attribute 'foo' whose type is 'xsd:IDREF' and an ecore annotation
'ecore:reference='foo'.
In generated Ecore model, Bar's attribute 'foo' contains the following
annotations.
source ...
reference...
kind='attribute'
name='foo'
namespace='##targetNamespace'
It seems OK until now, but in generated class files. Field foo of class
Bar doesn't match my assumption.
interface Bar extend EObject{
public void setFoo(EObject xxx);
public EObject getFoo();
Why? Did I miss some important settings?
Thanks for you help!
Re: Why EObject NOT Concrete Type? [message #791711 is a reply to message #791695] Mon, 06 February 2012 01:54 Go to previous messageGo to next message
David,
Comments below.
> are two complex types one name 'foo' and the other is 'bar', Element
Should this be something more like "prefix:foo"? Keep in mind that the
value of the annotation must be a QName that resolves the same way as
when you use it to specify the type of the element in the schema itself.
> annotations.
> source ...
> reference...
> kind='attribute'
> name='foo'
> class Bar doesn't match my assumption.
So EMF didn't resolve the QName...
Probably you didn't use an appropriately qualified QName for the complex
type.
Re: Why EObject NOT Concrete Type? [message #791722 is a reply to message #791711] Mon, 06 February 2012 02:15 Go to previous message
Thank for your so quick reply. I found What's wrong, it's my fault.
Foo and Bar are schema elements. Complex type definition was enclosed by
element so the outer complex type can't reference it. It's about visible
scope.
for example.
<xs:element name="foo">
//Here, Element foo has an anonymous complex type, but it's not visible
to bar
<xs:complexType>
<xs:attribute type="xs:ID"/>
</xs:complexType>
</xs>
<xs:element name="bar">
<xs:complexType>
<xs:attribute name="foo" type="xs:IDREF" ecore:reference="???"/>
</xs:complexType>
So I move foo's type outer, and let's be a global complex type, then
bar's type can see it.
<xs:complexType name="fooType">
</xs>
<xs:element="foo" type="fooType"/>
<xs:complexType>
<xs:attribute name="foo" type="xs:IDREF" ecore:reference="fooType"/>
</xs:complexType>
Whatever, I really appreciate Ed's help. I'm full of confidence to study
EMF well when you are on the group.
On 02/06/2012 02:54 PM, Ed Merks wrote:
> David,
> Comments below.
>> annotations.
>> source ...
>> reference...
>> kind='attribute'
>> name='foo'
> type.
Previous Topic:Converting relative URIs to absolute URIs?
Next Topic:Working on huge models
Current Time: Fri Nov 07 11:26:11 EST 2025
Powered by FUDForum. Page generated in 0.04290 seconds
