Some duvids about GMF model format [message #790965] |
Sat, 04 February 2012 23:04  |
I have two diferents GMF editor but the format of the generated model are diferents,
for example, with the GMF editor 1 the format generated is:
<contents xsi:type="XXX" name="NAME_X" id="ID" .../>
<contents xsi:type="YYY" name="NAME_Y" ...>
<xxxs xxx_name="X" xxxType="//@contents.0/>
</contents>
and the GMF editor 2 the format generated is like:
<XXX name="NAME_X" id="ID" .../>
<YYY name="NAME_Y" ...>
<xxxs xxx_name="X">
</YYY>
The first editor was made by a third person e the second was made by myself. My duvid is why in the first appear <contents xsi:type ... > and in the second not? Another duvid is, how I can change the references in the second format to became as the first (using //@contents.0 .. and not just a inner node)?
Re: Some duvids about GMF model format [message #791434 is a reply to message #791041] |
Sun, 05 February 2012 15:30  |
Did you see the the part where I explained when and why there is an
xsi:type?
On 05/02/2012 8:00 AM, Ed Merks wrote:
> Comments below.
>> are diferents,
> So this is an instance of XXX contained by something that has a
> "contents" containment reference.
>> </contents>
> This is an instance of XXX right at the root of the resource.
>> <xxxs xxx_name="X">
>> </YYY>
> At the root, the type name is used as an element name. Anywhere below
> that, the name of the containment reference is used as the element
> name and if the object is not of the type of the containment reference
> but rather a derived type, then that information needs to be in the
> XML as well, via the xsi:/xmi:type.
>> inner node)?
> Embed the objects in whatever has that "contents" reference or
> something else with such a "contents" reference.
FUDForum. Page generated in 0.05928 seconds
