| Converting relative URIs to absolute URIs? [message #790778] |
Sat, 04 February 2012 16:04  |
I have some resources in my ResourceSet with relative URIs (org.eclipse.emf.common.util.URI), eg. "images/image_a.png".
Now I need to be able to save these resources into an archive. I create an archive uri with an absolute path:
final URI uri = URI.createFileURI(file.getAbsolutePath());
String uriString = uri.toString();
final URI zipUri = URI.createURI("archive:" + uriString + "!/");
But how do I update my existing resources that only have relative paths to have the absolute archive path as root path?
I have tried:
// Create an archive uri from an absolute plain file
final URI uri = URI.createFileURI(destFile.getAbsolutePath());
// Create a resource with a relative uri
URI relativeUri = URI.createFileURI("folder/somefile.txt");
Resource resource = rs.createResource(relativeUri);
// Update the relative uri of the resource to have the absolute archive uri as base uri
String zipUriAsString = zipUri.toString();
final String itemPath = zipUriAsString + resource.getURI();
URI absUri = URI.createURI(itemPath);
resource.setURI(absUri);
// Save the resource/archive
resource.save(saveOptions);
which seems to work, but is that how emf resources are intended to be used or is there a better way to transform relative uris into absolute uris (considering that the base uri is an archive)?
| Re: Converting relative URIs to absolute URIs? [message #791016 is a reply to message #790778] |
Sun, 05 February 2012 01:07  |
Comments below.
That's generally not a good idea. Relative URIs get their meaning only
relative to an absolute URI...
So they need a path that starts with zip's URI as you have above.
> I have tried:
That's treating your destination file itself as the archive.
No, this creates an absolute URI with a relative path; that's even a
worse idea than a relative path.
That looks better.
Yep.
The path within the archive is arbitrary. You can make it whatever you
want, keeping in mind that references between the resources within the
archive will generally use relative URIs that are relative to the
archive itself. I.e., they'll use .. and path segments that will
navigate within the path structure you've induced in the archive. For
references outside the archive, they'll use whatever URI is on the
actual resource, which generally should always be an absolute URI...
FUDForum. Page generated in 0.05819 seconds
