| Home » Eclipse Projects » Remote Application Platform (RAP) » Popup menu doesn't work on ToolBar in CTabFolder top-right
 Goto Forum:|
| Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92547] | Tue, 10 June 2008 10:59  |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------060209060902080300010005
 Hi all,
 I've created a ToolBar with only one ToolItem of type SWT.DROP_DOWN,
 then I've set the ToolBar as the top-right component of a CTabFolder
 using setTopRight(...).
 In the widgetSelected event of the ToolItem I show a modal popup menu.
 When I click on the drop down arrow of ToolItem, the browser (both IE7
 and Firefox2.0) dumps a javascript error.
 It's a bug or there's another method to show popup menu from ToolItem?
 I attach the code snippet and the output from IE7 and Firefox2.0
 Enrico
 Content-Type: application/octet-stream;
 name="CTabFolder_setTopRight_ToolBar.zip"
 Content-Disposition: attachment;
 filename="CTabFolder_setTopRight_ToolBar.zip"
 UEsDBBQAAAAIANODyjhdIC71aAIAAGQHAAAQAAAAY29kZV9zbmlwcGV0LnR4 dJ1V32/aMBB+
 r9T/4dqHymhVxHiYJk1Io6NoSIwgyIa0l8ngAyw5dhQbKNr6v8+OQ35As9Ge ULAvd9/n+3yx
 wVqyXQi+BC4NLFOkBr8PSQt+X19BbisuqYA+14mgB2DQBYn745y0PpWRsw0K AdpH+Blh1QAd
 aDQPaiuZJu17sL+Pbfv40G6fRY3oQW0NcUADLkQ+bVXjytGXiC4GSjBMwaxy +tJH9D3M5lEQ
 hROfXiYNDcZg+HufU7iIWfmUcTh+rOS4ULe4CJ8MuQ0l3jYAdi4H7JSA0V7V AE/3IFJKPFBX
 o1nkBPNB7iwYvobT4c9wHPVG8CdzDEa9qEa5yhhVMuXrjSEO7H+kvqqVrb6g PbqzfM/cn4aT
 X/1wPq6z1TRzabUaTyMpYzMUuDRcyRHXBqXdQEdZeHuMJsY68yYt7XO4wzTl DEt3pcF3ijPY
 c7ZG46GQkQLzcYe2/9FDnhhfEcCAoaFcQLebldqbTsM55OHn9g3lFmKvVTbJ VW6OzhSOj/oW
 LhKfts25xVV9BzzV5vYCps6bmCrNOsOlkqyR6mXv1MpN5VogpHYE3XzT18Wp 0AQ3Ue6ASoxf
 tZ8ShxE83UP2f4B3frBB19dNQEmNdUJTtECtwKjjgZaY15UUZ6eVWlLXRzbb Lcg+DxalOf4H
 13whkJh0i6+j22+4VY/cxAHXbslKI7Ofwt2dBV6XwK16b561tEVggT3uWU8y B0PNcmOTbMo/
 jAVaICaNm/R8fdVUM/NL9annaQ3T52p49YIQ/jqo3xoqQXl0lVoRuNF1rTJp Tr/wl+QAq8cl
 GlRWnKLZphLa9m3+5i9QSwMEFAAAAAgAXIPKOGS3j6PiAAAAkwEAABMAAABm aXJlZm94Ml9v
 dXRwdXQudHh0dZCxTgNBDET7SPmHVUQRmpUQoQmiQhFQUIBA1OZuuCza292z vXfw9ziQ6hTa
 8fiNPbe5xtalrA4jxUoK90kjScOhqGNIyUmwXS6Wi5fvgh1z5q07g9uT2Jor nAtYA+Rgydx5
 NDEUgZdJ/W5E0lcN0UuVgtT+CveU2hhStz6/HoktZHA3br76jKFC1HfQhyRK qYH5zesFehza
 8UnBa7farNwfbOpPsN5Ca5hHStSBZ8Sp922wLwWGmS6uDDTXNie0y4M2fPka fJMZxwj/Eavs
 72J+p/hUYTdawv+lWL21x7yTH1BLAwQUAAAACAChg8o4B1V9mOUAAACXAQAA DgAAAGllN19v
 dXRwdXQudHh0dZAxT8QwDIX3Sv0P1i13LJEQxwJiQggYGEBCzKExISh12thu +cn8DFy4qbqb
 orw8f895t0VzACoCOPmsXhC+/OS5q2kQqMhDIcartmmbLWnOW/iB5SxQbIrs pgQlRhQpi6nU
 6LDLaWB0PIu7m5DkVVJ2rDwghT/hwVPIieLu7Hry1WJGuIH16AuOiizO2I/E 4qlD85vXMcrh
 0dYnwbqDzX4D/7C5P8J6S8EwT558xLoizr0Lyf7JaJj5/NJAa21/RLtYtPHb aXJdqXiIcB9Z
 +fM+l3efnxVtR0s4XYoVrD2uO2mbX1BLAQIUABQAAAAIANODyjhdIC71aAIA AGQHAAAQAAAA
 AAAAAAAAIAAAAAAAAABjb2RlX3NuaXBwZXQudHh0UEsBAhQAFAAAAAgAXIPK OGS3j6PiAAAA
 kwEAABMAAAAAAAAAAAAgAAAAlgIAAGZpcmVmb3gyX291dHB1dC50eHRQSwEC FAAUAAAACACh
 g8o4B1V9mOUAAACXAQAADgAAAAAAAAAAACAAAACpAwAAaWU3X291dHB1dC50 eHRQSwUGAAAA
 AAMAAwC7AAAAugQAAAAA
 --------------060209060902080300010005--
| Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92873 is a reply to message #92547] | Wed, 11 June 2008 11:31   |  |
| Eclipse User  |  |  |  |  | Originally posted by: ifurnadjiev.innoopract.com
 Hi Enrico,
 first of all I can't find these too classes WFToolBar/WFToolItem, that's
 why I reworked your snippet based on ToolBar/ToolItem (see the snippet
 bellow). Hope that it's working for you.
 final ToolBar tftb = new ToolBar(tf, SWT.HORIZONTAL | SWT.FLAT);
 tf.setTopRight(tftb);
 final ToolItem tfti1 = new ToolItem(tftb, SWT.DROP_DOWN);
 tfti1.setText("Tool");
 tfti1.addSelectionListener(new SelectionAdapter() {
 public void widgetSelected(SelectionEvent e) {
 if( e.detail == SWT.ARROW ) {
 Menu m = new Menu( tftb.getShell(), SWT.POP_UP );
 MenuItem mi1 = new MenuItem(m, SWT.NONE);
 mi1.setText("First");
 MenuItem mi2 = new MenuItem(m, SWT.NONE);
 mi2.setText("Second");
 Point point = new Point( e.x, e.y );
 m.setLocation( point );
 m.setVisible( true );
 Best,
 Ivan
 Enrico Zanaga wrote:
 > Hi all,
 > Enrico
| Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92887 is a reply to message #92873] | Wed, 11 June 2008 11:54   |  |
| Eclipse User  |  |  |  |  | Hi Ivan,
 sorry, it's my mistake.
 However the reworked code doesn't work for me, but it's working for you?
 If yes, can you tell me what version (RAP, Eclipse) are you using, please?
 I try the code in 1.1M3 and 1.1RC3 without success...
 Enrico
 Ivan Furnadjiev ha scritto:
 > Hi Enrico,
 >        @Override
 > Best,
 > Ivan
 >> Hi all,
 >> Thanks,
 >> Enrico
| Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92901 is a reply to message #92887] | Wed, 11 June 2008 12:19   |  |
 Hi Enrico,
 I run it against 1.1RC3 in FF 2.0.0.14, IE7 and Safari 3.1.1 on Windows
 XP SP3.
 What kind of problems do you have - JavaScript error? Did you use the
 exact snippet from my previous post?
 Best,
 Ivan
 > Hi Ivan,
 > please?
 > Enrico
 >> Hi Enrico,
 >> that's why I reworked your snippet based on ToolBar/ToolItem (see the
 >> snippet bellow). Hope that it's working for you.
 >>        @Override
 >> Best,
 >> Ivan
 >>> Hi all,
 >>> IE7 and Firefox2.0) dumps a javascript error.
 >>> Thanks,
 >>> Enrico
| Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92916 is a reply to message #92901] | Wed, 11 June 2008 12:57   |  |
 running your snippet in IE7, I get the following javascript error:
 Could not evaluate javascript response:
 'null' è nullo o non è un oggetto
 org.eclipse.swt.EventUtil.suspendEventHandling();var req =
 org.eclipse.swt.Request.getInstance();req.setRequestCounter( "3" );var
 wm = org.eclipse.swt.WidgetManager.getInstance();wm.dispose( "w15"
 );wm.dispose( "w14" );wm.dispose( "w13"
 );qx.ui.core.Widget.flushGlobalQueues();org.eclipse.swt.Even tUtil.resumeEventHandling();
 Maybe a qooxdoo problem?
 In Jetty/Eclipse console nothing happen...
 Enrico
 > Hi Enrico,
 > XP SP3.
 > Best,
 > Ivan
 >> Hi Ivan,
 >> please?
 >> Thanks,
 >> Enrico
 >>> Hi Enrico,
 >>>        @Override
 >>> Best,
 >>> Ivan
 >>>> Hi all,
 >>>> Thanks,
 >>>> Enrico
| Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93004 is a reply to message #92916] | Thu, 12 June 2008 03:07   |  |
 Hi Enrico,
 please attach your complete file to have a look at it.
 Ivan
 > Hi Ivan,
 > Enrico
 >> Hi Enrico,
 >> Windows XP SP3.
 >> Best,
 >> Ivan
 >>> Hi Ivan,
 >>> you?
 >>> please?
 >>> Thanks,
 >>> Enrico
 >>>> Hi Enrico,
 >>>> the snippet bellow). Hope that it's working for you.
 >>>>        @Override
 >>>> Best,
 >>>> Ivan
 >>>>> Hi all,
 >>>>> menu.
 >>>>> ToolItem?
 >>>>> Thanks,
 >>>>> Enrico
| Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93105 is a reply to message #93045] | Thu, 12 June 2008 08:19  |  |
 it works! Many thanks!
 The code in widgetSelected comes from an old version of SWT, and it
 continues to work in SWT 3.3 e 3.4 (RCP mode).
 Because my application runs both in RCP and RAP the sources are shared,
 except a little compatibility library.
 I tested the code in both two modes and it works, so this is the final
 solution.
 Enrico
 > Hi Enrico,
 > here is the reworked complete code... please test it. You don't need
 > this in widgetSelected:
 > while (!m.isDisposed() && m.getVisible()) {
 >  if (!d.readAndDispatch())
 >    d.sleep();
 > m.dispose();
 > Hope this will help.
 > Best,
 > Ivan
 >> Hi Ivan,
 >> I've attached the class I use to reproduce the problem.
 >> Thanks,
 >> Enrico
 >>> Hi Enrico,
 >>> Thanks,
 >>> Ivan
 >>>> Hi Ivan,
 >>>> );var wm = org.eclipse.swt.WidgetManager.getInstance();wm.dispose(
 >>>> "w15" );wm.dispose( "w14" );wm.dispose( "w13"
 >>>> Thanks,
 >>>> Enrico
 >>>>> Hi Enrico,
 >>>>> Windows XP SP3.
 >>>>> the exact snippet from my previous post?
 >>>>> Best,
 >>>>> Ivan
 >>>>>> Hi Ivan,
 >>>>>> for you?
 >>>>>> please?
 >>>>>> Thanks,
 >>>>>> Enrico
 >>>>>>> Hi Enrico,
 >>>>>>>        @Override
 >>>>>>> Best,
 >>>>>>> Ivan
 >>>>>>>> Hi all,
 >>>>>>>> SWT.DROP_DOWN,
 >>>>>>>> CTabFolder
 >>>>>>>> menu.
 >>>>>>>> (both IE7 and Firefox2.0) dumps a javascript error.
 >>>>>>>> ToolItem?
 >>>>>>>> Thanks,
 >>>>>>>> Enrico
 Current Time: Fri Oct 31 10:35:50 EDT 2025
 Powered by FUDForum . Page generated in 0.04181 seconds |
