Home » Archived » Test and Performance Tools Platform (TPTP) » Unit testing eclipse plugins
Unit testing eclipse plugins [message #92525] Wed, 14 February 2007 12:12 Go to next message
I don't know if this is the right forum to ask this question, but...
How can I use JUnit for testing eclipse plugins, especially extension
points.
I have an RCP application, for which I have defined a few extension
points. I want to test my extension point parsing code. Since extensions
are specified in the plugin.xml file and the junit project is not a
plugin project, how will junit read the plugin xml.
Any examples/samples or pointers to resources that describes this
process would be really helpful.
Anand
____________________________________________________________ _________________________
Anand Narasimhan
anandn@cisco.com
Re: Unit testing eclipse plugins [message #92680 is a reply to message #92525] Sun, 18 February 2007 16:20 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Anand,
The best place to ask this question would be eclipse.platform unless
you're looking for the TPTP support for plug-in testing.
Standard PDE gives you ability to run your JUnit test cases in Plug-in
environment. Try "Run As->JUnit Plugin Test" - it lets you launch your
RCP headless and execute test cases, eg. access extension points, or
access workspace.
Jacek
Anand Narasimhan napisał(a):
> points.
> Thanks
> Anand
Re: Unit testing eclipse plugins [message #96081 is a reply to message #92680] Tue, 17 April 2007 07:15 Go to previous message
Hi Anand,
TPTP provide analogous support for JUnit plug-in tests called the TPTP
JUnit Plug-in test. See
http://help.eclipse.org/help32/topic/org.eclipse.hyades.test .doc.user/concepts/cintro.htm
for more information.
From your JUnit plug-in test code, you can access the OSGi and PDE APIs
for accessing your plug-in's manifests and extensions/extension points.
Paul
"Jacek Pospychala" <jacek.pospychala@pl.ibm.com> wrote in message
news:erafua$1uk$1@utils.eclipse.org...
> Anand,
> environment. Try "Run As->JUnit Plugin Test" - it lets you launch your RCP
> headless and execute test cases, eg. access extension points, or access
> workspace.
> Jacek
> Anand Narasimhan napisal(a):
>> points.
>> Any examples/samples or pointers to resources that describes this process
>> Thanks
>> Anand
Previous Topic:Line Coverage for TPTP Unittests
Next Topic:testing outside eclipse
Current Time: Sun Nov 09 13:10:33 EST 2025
Powered by FUDForum. Page generated in 0.03852 seconds
