JpoxStoreException:Exception when determining refers to [message #92125] |
Tue, 31 July 2007 02:44 |
Originally posted by: danceslower.sina.com
Hi,all
I have created a complicated model with EMF and this model is integrated
with another model, which means one model have reference to another
model.Then I use teneo jpox to map ecore to data table successfully.
However, when I tried to manipulate this model and make persistence of
it, an exception was throw out when initialize jpoxdatastore.Here is the
exception:
Exception in thread "main" org.eclipse.emf.teneo.jpox.JpoxStoreException:
refers to
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.createRefersToMap(J poxDataStore.java:783)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.initialize(JpoxData Store.java:244)
at com.ibm.crl.bo.tops.util.TestTeneoBom.main(TestTeneoBom.java :45)
at
org.eclipse.emf.teneo.util.StoreUtil.getEStructuralFeature(S toreUtil.java:353)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore$ReferenceTo.<init>(JpoxDataStore.java:1030)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.createRefersToFromF ield(JpoxDataStore.java:868)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.createRefersToMap(J poxDataStore.java:769)
... 2 more
the strange thing is when a model is independent and not related to another
one, everything goes quite well.
Where is problem is, is it related to the interation between two models?
Re: JpoxStoreException:Exception when determining refers to [message #92141 is a reply to message #92125] |
Tue, 31 July 2007 12:02 |
How do you initialize the datastore?
You can debug and see why the eclass (the parameter to the StoreUtil.getEStructuralFeature method)
is null). This method is called from JpoxDataStore and the eclass is found using a class (see the
source code), is there anything special there?
gr. Martin
wangyan wrote:
> Hi,all
> exception:
> refers to
> at
> at
> at
> at
> at
> at
> ... 2 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: JpoxStoreException:Exception when determining refers to [message #609381 is a reply to message #92125] |
gr. Martin
wangyan wrote:
> Hi,all
> exception:
> refers to
> at
> at
> at
> at
> at
> at
> ... 2 more
The Netherlands
FUDForum. Page generated in 0.03143 seconds
