Home » Language IDEs » PHP Development Tools (PDT) » Determine object file from other files
Determine object file from other files [message #92024] Mon, 26 January 2009 10:41
Español:
Hola el problema que tengo es con la ultima version de pdt en el asistente
de codigo. En la version anterior (pdt 1.0) tenia una opcion dentro php -
editor - asistente de codigo - opciones . Llamada 'determine object type
from other files' la cual estoy tratando de marcar en la nueva version
(pdt 2.0) y no la encuentro. Necesito saber si esa opcion definitivamente
es obsoleta o la van a incluir debido a que algunas atributos de objectos
que intento llamar no los encuentro por que la clase de la que vienen no
esta incluida en ese archivo o relativamente incluido dentro del script.
English:
Hi the problem I have is with the latest version of PDT in the wizard
code. In the previous version (PDT 1.0) have an option within [php -
editor - assistant code - options]. Named 'determine object type from
other files' which I am trying to make the new version (2.0 PDT) and not
the meeting. What if that option is obsolete or definitely going to be
included because some attributes of objects that do not try to call the
meeting that the coming of the class is not included in that file or
fairly included in the script.
Previous Topic:XDebug JIT fails ... somewhere
Next Topic:PDT / XDebug / TPTP Profiling
Current Time: Sun Nov 09 11:29:48 EST 2025
Powered by FUDForum. Page generated in 0.03271 seconds
