| JDK of Eclipse building [message #91788] |
Fri, 11 July 2003 10:59   |
Eclipse User  |
Can anybody tell me, if eclipse is
buildung with JDK 1.3.1 or with JDK 1.4?
Thanks a lot.
Best Regards,
Thomas
| Re: JDK of Eclipse building [message #92490 is a reply to message #92460] |
Sat, 12 July 2003 07:18    |
Eclipse User  |
Originally posted by: purplehayz.earthlink.net
Really?  I just spent some quality time playing with the launching plugin,
and it looks like that's used for building (based upon the design as I
understand it - since I was working with system properties and, on MacOS X,
they differ between 1.3 and 1.4, I know the launcher launches the desired
version).  The information required to use a JRE is the whole directory
she-bang for a JRE, so I'd be really surprised if its not run in a separate
thread by Eclipse....
It would be hard to make a 1.4 compatible build using a 1.3 compiler, since
1.4 didn't necessarily exist "back then."
Can someone working on the compiler interface answer this question?
Thanks and have fun! - Bob
On 7/12/03 2:27 AM, in article MPG.1979c8d5828f4b809897ff@news.eclipse.org,
"Jon Skeet" <skeet@pobox.com> wrote:
> Darin Swanson <Darin_Swanson@us.ibm.com> wrote:
>> Thomas you can configure the Eclipse compiler to compile against either 1.3
>> or 1.4.
> Just to clarify - it doesn't really build "against" either 1.3 or 1.4,
> ie it doesn't use the 1.3 or 1.4 compiler. It still uses the internal
> compiler either way, but compiles to be *compatible* with 1.3 or 1.4
> (ie some of the compiler bugs are reproduced, assertions are in 1.4,
> etc).
Bob Hays, Computer Geek
http://www.alephnaught.com
"Once you've outsourced something to some big IT company, you can write it
off as a source of competitive advantage."
-- Gary Hamel
| Re: JDK of Eclipse building [message #92718 is a reply to message #92490] |
Sun, 13 July 2003 04:11    |
Eclipse User  |
> version).
Oh Eclipse itself will certainly run in whatever JRE you tell it to,
and will also launch your application for run/debug in whatever JRE you
tell it to (separate decision). That doesn't mean it uses the JDK's
compiler, which I believe is what the OP was asking.
The compiler uses the JRE's library to compile against, but it doesn't
use a JDK's compiler - so you could actually use Eclipse without having
a JDK installed, as far as I know.
Jon Skeet - <skeet@pobox.com>
http://www.pobox.com/~skeet/
If replying to the group, please do not mail me too
| Re: JDK of Eclipse building [message #94859 is a reply to message #94554] |
Wed, 16 July 2003 10:18   |
Eclipse User  |
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Wed, 16 Jul 2003 06:53:39 +0000 (UTC), th.huebner@sap.com (Thomas
Hübner) a écrit :
>Or with other words: Which compiler (JDK) do you use for your nightly
>build?
We don't use javac. We use the Eclipse compiler inside an ant javac
task.
Olivier
FUDForum. Page generated in 0.06379 seconds
