Home » Modeling » OCL » OCLInEcore recursive operations
Re: OCLInEcore recursive operations [message #786566 is a reply to message #786296] |
Mon, 30 January 2012 15:34 |
Patricia Espada Messages: 47 Registered: November 2011 |
Member |
I'm using Eclipse Modeling Tools Version: Indigo Service Release 1 Build id: 20110916-0149.
That was a simple example I came with at the moment. My problem is in a larger scale. Anyway where it is, maybe you can see any error that I'm not seeing right.
package KAOSStandard : kaos = 'kaos'
class KAOS
property hasCompartmentNode : CompartmentNode[*] { ordered composes };
property hasNodes : Nodes[*] { ordered composes };
property hasLinks : Links[*] { ordered composes };
property root : Goal[1] { ordered };
operation modelDepth() : ecore::EIntegerObject[1]
body:
self.goalsDistanceToRoot(self.root, Set{0}, 0)->iterate(i : Integer ; m : Integer = - 1 | if m = - 1 then i else m.max(i) endif);
operation goalsDistanceToRoot(n : Nodes[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
if n.oclIsKindOf(Goal) then
self.depthOfGoal(n.oclAsType(Goal), dist, last)
else
if n.oclIsKindOf(Obstacle) then
self.depthOfObstacle(n.oclAsType(Obstacle), dist, last)
else
dist
endif
endif;
operation depthOfGoal(g : Goal[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
if g.isLeafGoal() then
self.depthOfLeafGoal(g, dist, last)
else
self.union(g.goalIsAndRef->collect(andRefToOtherGoal)->union(g.goalIsOrRef->collect(orRefToOtherGoal))->asSet(), g.goalHasObstacle->collect(obstacle)->asSet())->collect(n : Nodes | self.goalsDistanceToRoot(n, dist->including(last + 1), last + 1))->asSet()
endif;
operation union(s1 : Goal[*], s2 : Nodes[*]) : Nodes[*]
body: let s : Set(Nodes) = Set{} in s->union(s1)->union(s2);
operation depthOfLeafGoal(g : Goal[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
let s : Sequence(Obstacle) = g.goalHasObstacle->collect(obstacle) in
if s->notEmpty() then
s->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
else
dist
endif;
operation depthOfObstacle(o : Obstacle[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
if self.isLeafObstacle(o) then
self.depthOfLeafObstacle(o, dist, last)
else
self.obstacleRefinement(o)->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
endif;
operation obstacleRefinement(o : Obstacle[1]) : Obstacle[*]
body:
self.hasLinks->select(l : Links | l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = o)->collect(oclAsType(ObstacleRefinement))->collect(obstRefToObst);
operation depthOfLeafObstacle(o : Obstacle[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
let s : Sequence(Goal) = o.solution->collect(obstacleHasSolution) in
s->collect(g : Goal | self.goalsDistanceToRoot(g.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
else
dist
endif;
operation isLeafObstacle(o : Obstacle[1]) : Boolean[1]
body:
not self.hasLinks->exists(l : Links | (l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = o));
annotation _'gmf.diagram'
foo = 'bar'
abstract class Nodes
attribute name : String[?] { ordered };
attribute TransformationSource : String[?] { ordered };
attribute IstarActorContainer : String[?] { ordered };
annotation _'gmf.node'
label = 'name',
_'label.placement' = 'external'
class Goal extends Nodes
attribute formalDef : String[?] { ordered };
attribute informalDef : String[?] { ordered };
property goalIsOrRef#orRefToGoal : OrRefinement[*] { ordered };
property otherGoalIsOrRef#orRefToOtherGoal : OrRefinement[*] { ordered };
property goalIsAndRef#andRefToGoal : AndRefinement[*] { ordered };
property otherGoalIsAndRef#andRefToOtherGoal : AndRefinement[*] { ordered };
property goalHasObstacle#obstacleToGoal : ObstructionLink[*] { ordered };
property solutionIsGoal#obstacleHasSolution : SolutionLink[*] { ordered };
property goalToOperatLink#operatLinkToGoal : OperationalizationLink[*] { ordered };
property goalConcerns#concernedByGoal : ConcernsLink[*] { ordered };
property goalHasDomProp#DomPropLinkToGoal : DomainPropLink[*] { ordered };
operation isLeafGoal() : Boolean[1]
body: self.goalIsAndRef->isEmpty() and self.goalIsOrRef->isEmpty();
color = '0,191,255',
_'border.color' = '0,191,255',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '30 70 50 10',
_'polygon.y' = '10 10 40 40',
_'tool.description' = 'Create new Goal'
class Obstacle extends Nodes
property obstacleObstruction#obstacle : ObstructionLink[*] { ordered };
property solution#obstacleSolution : SolutionLink[*] { ordered };
color = '255,140,0',
_'border.color' = '255,140,0',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '10 50 70 30',
_'tool.description' = 'Create new Obstacle'
abstract class Links
attribute Source : String[?] { ordered };
attribute Target : String[?] { ordered };
class OrRefinement extends Links
invariant linkToHimself('Goal ' + orRefToGoal.name + ' can not be a refinement of himself.'):
orRefToGoal <> orRefToOtherGoal;
property orRefToGoal#goalIsOrRef : Goal[1] { ordered };
property orRefToOtherGoal#otherGoalIsOrRef : Goal[1] { ordered };
annotation _'gmf.link'
source = 'orRefToGoal',
target = 'orRefToOtherGoal',
color = '0,0,255',
_'target.decoration' = 'arrow',
width = '2',
style = 'dash',
_'tool.description' = 'Create new OrRefinement between Goal, Requirement or Expectation'
class AndRefinement extends Links
invariant linkToHimself('Goal ' + andRefToGoal.name + ' can not be a refinement of himself.'):
andRefToGoal <> andRefToOtherGoal;
property andRefToGoal#goalIsAndRef : Goal[1] { ordered };
property andRefToOtherGoal#otherGoalIsAndRef : Goal[1] { ordered };
source = 'andRefToGoal',
target = 'andRefToOtherGoal',
color = '0,0,255',
width = '2',
_'tool.description' = 'Create new AndRefinement between Goal, Requirement or Expectation'
class ObstacleRefinement extends Links
invariant linkToHimself('Obstacle ' + obstRefToObst.name + ' can not be a refinement of himself.'):
obstRefToObst <> obstToObstRef;
property obstRefToObst : Obstacle[1] { ordered };
property obstToObstRef : Obstacle[1] { ordered };
source = 'obstRefToObst',
target = 'obstToObstRef',
width = '2',
_'tool.description' = 'Create new ObstacleRefinement between Obstacles'
class ObstructionLink extends Links
property obstacle#obstacleObstruction : Obstacle[1] { ordered };
property obstacleToGoal#goalHasObstacle : Goal[1] { ordered };
source = 'obstacle',
target = 'obstacleToGoal',
color = '255,165,0',
width = '2',
_'tool.description' = 'Create new ObstructionLink between an Obstacle and a Goal, Requirement or Expectation'
class SolutionLink extends Links
property obstacleHasSolution#solutionIsGoal : Goal[1] { ordered };
property obstacleSolution#solution : Obstacle[1] { ordered };
source = 'obstacleHasSolution',
target = 'obstacleSolution',
color = '0,139,0',
width = '2',
_'tool.description' = 'Create new SolutionLink between an Obstacle and a Goal, Requirement or Expectation'
Re: OCLInEcore recursive operations [message #786632 is a reply to message #786566] |
Mon, 30 January 2012 17:00 |
Ed Willink Messages: 7655 Registered: July 2009 |
Your example has many "..." ellisions and no CompartmentNode, so I
cannot comment on what real problems exist.
Ed Willink
> class KAOS
> composes };
> body:
> m.max(i) endif);
> body:
> self.depthOfGoal(n.oclAsType(Goal), dist, last) else
> dist, last) else dist
> endif endif;
> body:
> self.depthOfLeafGoal(g, dist, last) else
> 1))->asSet() endif;
> body:
> g.goalHasObstacle->collect(obstacle) in if
> s->notEmpty() then s->collect(o : Obstacle |
> 1), last + 1))->asSet() else
> dist endif;
> body:
> self.depthOfLeafObstacle(o, dist, last) else
> 1), last + 1))->asSet() endif;
> body:
> body:
> o.solution->collect(obstacleHasSolution) in if
> s->notEmpty() then s->collect(g : Goal |
> dist endif;
> body:
> foo = 'bar'
> label = 'name',
> ordered };
> ordered };
> ordered };
> { ordered };
> ordered };
> { ordered };
> size = '80,50',
> figure = 'polygon',
> ordered };
> size = '80,50',
> figure = 'polygon',
> color = '0,0,255',
> width = '2',
> style = 'dash',
> ordered };
> color = '0,0,255',
> width = '2',
> width = '2',
> between Obstacles'
> width = '2',
> ordered };
> color = '0,139,0',
> width = '2',
Re: OCLInEcore recursive operations [message #786659 is a reply to message #786632] |
Mon, 30 January 2012 17:28 |
Member |
I though what it was more simple if a do not put the entire example. Anyway here it is:
module _'KAOS.ecore'
import ecore : 'http://www.eclipse.org/emf/2002/Ecore#/';
class KAOS
operation numLeafGoals() : ecore::EIntegerObject[?]
body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal())->size();
operation numLeafGoalsWithAgents() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfAgents() > 0)->size();
operation numLeafGoalsWithObjects() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfObjects() > 0)->size();
operation numLeafObstacles() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(Obstacle) and not self.hasLinks->exists(l : Links | (l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = n.oclAsType(Obstacle))))->size();
operation numLeafGoalsWithOperations() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfOperations() > 0)->size();
operation numOperations() : ecore::EIntegerObject[?]
body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode))->size();
operation numOperationsWithAgents() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode) and n.oclAsType(OperationNode).operationNumberOfAgents() > 0)->size();
operation numAgents() : ecore::EIntegerObject[?]
body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->size();
operation numLeafGoalsWithConcerns() : ecore::EIntegerObject[?]
body:
self.hasLinks->select(l : Links | l.oclIsKindOf(ConcernsLink) and l.oclAsType(ConcernsLink).concernedByGoal.isLeafGoal())->size();
body:
body:
if n.oclIsKindOf(Goal) then self.depthOfGoal(n.oclAsType(Goal), dist, last) else if n.oclIsKindOf(Obstacle) then self.depthOfObstacle(n.oclAsType(Obstacle), dist, last) else dist endif endif;
body:
if g.isLeafGoal() then self.depthOfLeafGoal(g, dist, last) else self.union(g.goalIsAndRef->collect(andRefToOtherGoal)->union(g.goalIsOrRef->collect(orRefToOtherGoal))->asSet(), g.goalHasObstacle->collect(obstacle)->asSet())->collect(n : Nodes | self.goalsDistanceToRoot(n, dist->including(last + 1), last + 1))->asSet() endif;
body:
let s : Sequence(Obstacle) = g.goalHasObstacle->collect(obstacle) in if s->notEmpty() then s->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() else dist endif;
body:
if self.isLeafObstacle(o) then self.depthOfLeafObstacle(o, dist, last) else self.obstacleRefinement(o)->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() endif;
body:
body:
let s : Sequence(Goal) = o.solution->collect(obstacleHasSolution) in if s->notEmpty() then s->collect(g : Goal | self.goalsDistanceToRoot(g.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() else dist endif;
body:
operation depth() : ecore::EIntegerObject[1]
body:
let s : OrderedSet(Nodes) = OrderedSet{self.root.oclAsType(Goal)} in s->iterate(n : Nodes ; i : Integer = 0 | s = s->union(n.oclAsType(Goal).goalIsAndRef->collect(andRefToOtherGoal)->asOrderedSet())->excluding(n) and i = i + 1);
operation modelDit() : ecore::EIntegerObject[1]
body:
self.hasNodes->iterate(n : Nodes ; i : Integer = 0 | if n.oclIsKindOf(Goal) and n.oclAsType(Goal).dit(self.root) > i then n.oclAsType(Goal).dit(self.root) else i endif);
foo = 'bar'
abstract class CompartmentNode
class GoalCompartmentNode extends CompartmentNode
property compHasGoals : Goal[*] { ordered composes }
annotation _'gmf.compartment'
layout = 'free'
label = 'name',
_'border.color' = '0,0,255',
size = '200,100',
_'border.width' = '2',
'Create new GoalCompartmentNode for inserting Goals, Requirements and Expectations in the diagram'
class SoftgoalCompartmentNode extends CompartmentNode
property softgoalCompHasSoftgoals : Softgoal[*] { ordered composes }
layout = 'free'
label = 'name',
_'border.color' = '0,100,0',
size = '200,100',
_'tool.description' = 'Create new SoftgoalCompartmentNode for inserting Softgoals in the diagram'
class ObstacleCompartmentNode extends CompartmentNode
property obstCompNodeHasObstacle : Obstacle[*] { ordered composes }
layout = 'free'
label = 'name',
_'border.color' = '255,165,0',
size = '200,100',
_'tool.description' = 'Create new ObstacleCompartmentNode for inserting Obstacles in the diagram'
class DomainPropertiesCompartmentNode extends CompartmentNode
property domProCompNodeHasDomProp : DomainProperties[*] { ordered composes }
layout = 'free'
label = 'name',
_'border.color' = '148,0,211',
size = '200,100',
'Create new DomainPropertiesCompartmentNode for inserting Domain Invariants and Domain Hipothesis in the diagram'
class AgentCompartmentNode extends CompartmentNode
property agentCompHasAgent : Agent[*] { ordered composes }
layout = 'free'
label = 'name',
_'border.color' = '255,105,180',
size = '200,100',
'Create new AgentCompartmentNode for inserting System Agents and Environment Agents in the diagram'
class ObjectCompartmentNode extends CompartmentNode
property objCompHasObjects : Object[*] { ordered }
layout = 'free'
label = 'name',
_'border.color' = '165,42,42',
size = '200,100',
_'tool.description' = 'Create new ObjectCompartmentNode for creating Entities and Events in the diagram'
class OperationCompartmentNode extends CompartmentNode
property hasOperationNodes : OperationNode[*] { ordered }
layout = 'free'
label = 'name',
size = '200,100',
_'tool.description' = 'Create new OperationCompartmentNode for inserting Operations in the diagram'
label = 'name',
operation goalAgents() : Agent[*]
body:
let s : Sequence(Agent) = if self.oclIsKindOf(Expectation) then self.oclAsType(Expectation).expToAgentExpLink->collect(expLinkToAgent) else if self.oclIsKindOf(Requirement) then self.oclAsType(Requirement).ReqToAgentReqLink->collect(ReqToAgentLink) else Sequence{} endif endif in s->union(self.otherGoalIsOrRef->collect(orRefToGoal)->union(self.otherGoalIsAndRef->collect(andRefToGoal))->collect(g : Goal | g.goalAgents()));
operation goalNumberOfAgents() : ecore::EIntegerObject[?]
body: self.goalAgents()->size();
operation goalNumberOfObjects() : ecore::EIntegerObject[?]
body: self.goalConcerns->collect(concernsObject)->size();
operation goalNumberOfOperations() : ecore::EIntegerObject[?]
body: self.goalToOperatLink->collect(operatLinkToOperationNode)->size();
size = '80,50',
figure = 'polygon',
class Requirement extends Goal
property ReqToAgentReqLink#agentReqLinkToReq : AgentReqLink[+] { ordered };
_'border.color' = '0,0,0',
size = '80,50',
figure = 'polygon',
_'tool.description' = 'Create new Requirement'
class Expectation extends Goal
property expToAgentExpLink#agentExpLinkToExp : AgentExpLink[+] { ordered };
color = '255,215,0',
_'border.color' = '255,215,0',
size = '80,50',
figure = 'polygon',
_'tool.description' = 'Create new Expectation'
class Softgoal extends Goal
color = '50,205,50',
_'border.color' = '50,205,50',
size = '40,40',
figure = 'ellipse',
_'tool.description' = 'Create new Softgoal'
operation obstacleNumberOfSolutions() : ecore::EIntegerObject[?]
body: self.solution->size();
size = '80,50',
figure = 'polygon',
abstract class DomainProperties extends Nodes
property domPropToGoal#goalToDomProp : DomainPropLink[+] { ordered };
class DomainInvariant extends DomainProperties
color = '221,160,221',
_'border.color' = '221,160,221',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '10 40 70 70 10',
_'polygon.y' = '20 10 20 40 40',
_'tool.description' = 'Create new DomainInvariant'
class DomainHyphothesis extends DomainProperties
color = '147,112,219',
_'border.color' = '147,112,219',
size = '80,50',
figure = 'polygon',
_'tool.description' = 'Create new DomainHyphothesis'
abstract class Object extends Nodes
property objToInhLink#inhLinkToObject : InheritanceLink[*] { ordered };
property otherObjToInhLink#inhLinkToOtherObj : InheritanceLink[*] { ordered };
property objToAggLink#aggLinkToObject : AggregationLink[*] { ordered };
property otherObjToAggLink#aggLinkToOtherObject : AggregationLink[*] { ordered };
property objToCardLink#cardLinkToObject : CardinalityLink[*] { ordered };
property otherObjToCardLink#cardLinkToOtherObject : CardinalityLink[*] { ordered };
property objIsMonitored#monLinkToObject : MonitorsLink[*] { ordered };
property objIsControlled#contLinkToObject : ControlsLink[*] { ordered };
property objectIsConcerned#concernsObject : ConcernsLink[*] { ordered };
abstract class Agent extends Object
property agentMonitors#monLinkToAgent : MonitorsLink[*] { ordered };
property agentControls#contLinkToAgent : ControlsLink[*] { ordered };
property agentPerforms#perLinkToAgent : PerformsLink[*] { ordered };
operation agentNumberOfLeafGoals() : ecore::EIntegerObject[?]
body:
if self.oclIsKindOf(EnvironmentAgent) then self.oclAsType(EnvironmentAgent).numLeafGoals() else if self.oclIsKindOf(SystemAgent) then self.oclAsType(SystemAgent).numLeafGoals() else 0 endif endif;
class SystemAgent extends Agent
property agentToReqLink#ReqToAgentLink : AgentReqLink[+] { ordered };
body: self.agentToReqLink->collect(agentReqLinkToReq)->size();
color = '255,160,122',
_'border.color' = '255,160,122',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '10 20 60 70 60 20',
_'polygon.y' = '25 40 40 25 10 10',
_'tool.description' = 'Create new SystemAgent'
class EnvironmentAgent extends Agent
property agentToExpLink#expLinkToAgent : AgentExpLink[+] { ordered };
body: self.agentToExpLink->collect(agentExpLinkToExp)->size();
color = '255,182,193',
_'border.color' = '255,182,193',
size = '80,50',
figure = 'polygon',
_'tool.description' = 'Create new EnvironmentAgent'
class Event extends Object
attribute frequency : ecore::EInt[?] { ordered };
color = '189,183,107',
_'border.color' = '189,183,107',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '10 10 60 70 60',
_'polygon.y' = '10 40 40 25 10',
_'tool.description' = 'Create new Event'
class Entity extends Object
color = '143,188,143',
_'border.color' = '143,188,143',
size = '60,30',
figure = 'rectangle',
_'tool.description' = 'Create new Entity'
class Relationship extends Object
property relationConnObject : Object[1] { ordered };
property objectIsConnByRelation : Object[1] { ordered };
label = 'name',
source = 'relationConnObject',
target = 'objectIsConnByRelation',
color = '255,127,80',
width = '2',
_'tool.description' = 'Create new Relationship between two Objects'
class OperationNode extends Nodes
property operationNodeToOperatLink#operatLinkToOperationNode : OperationalizationLink[*] { ordered };
property operationIsPerformed#perLinkToOperationNode : PerformsLink[*] { ordered };
operation operationNumberOfAgents() : ecore::EIntegerObject[?]
body: self.operationIsPerformed->collect(perLinkToAgent)->size();
color = '211,211,211',
_'border.color' = '211,211,211',
size = '60,30',
figure = 'ellipse',
_'tool.description' = 'Create new OperationNode'
color = '0,0,255',
width = '2',
style = 'dash',
color = '0,0,255',
width = '2',
width = '2',
width = '2',
color = '0,139,0',
width = '2',
class OperationalizationLink extends Links
attribute label : String[1] = 'Operationalization' { ordered readonly };
property operatLinkToGoal#goalToOperatLink : Goal[1] { ordered };
property operatLinkToOperationNode#operationNodeToOperatLink : OperationNode[1] { ordered };
label = 'label',
source = 'operatLinkToGoal',
target = 'operatLinkToOperationNode',
color = '105,105,105',
width = '2',
_'tool.description' = 'Create new OperationalizationLink between an Operation and a Goal'
class ConcernsLink extends Links
attribute label : String[1] = 'Concerns' { ordered readonly };
property concernedByGoal#goalConcerns : Goal[1] { ordered };
property concernsObject#objectIsConcerned : Object[1] { ordered };
label = 'label',
source = 'concernedByGoal',
target = 'concernsObject',
color = '205,133,63',
width = '2',
_'tool.description' = 'Create new ConcernsLink between a Goal, Requirement or Expectation and an Object'
class DomainPropLink extends Links
property DomPropLinkToGoal#goalHasDomProp : Goal[1] { ordered };
property goalToDomProp#domPropToGoal : DomainProperties[1] { ordered };
source = 'DomPropLinkToGoal',
target = 'goalToDomProp',
color = '148,0,211',
width = '2',
'Create new DomainPropLink between Goal, Requirement or Expectation and Domain Invariant or Domain Hipothesis'
class AgentReqLink extends Links
property ReqToAgentLink#agentToReqLink : SystemAgent[1] { ordered };
property agentReqLinkToReq#ReqToAgentReqLink : Requirement[1] { ordered };
source = 'ReqToAgentLink',
target = 'agentReqLinkToReq',
color = '233,150,122',
width = '2',
_'tool.description' = 'Create new AgentReqLink for connecting a System Agent to a Requirement'
class AgentExpLink extends Links
property expLinkToAgent#agentToExpLink : EnvironmentAgent[1] { ordered };
property agentExpLinkToExp#expToAgentExpLink : Expectation[1] { ordered };
source = 'expLinkToAgent',
target = 'agentExpLinkToExp',
color = '176,48,96',
width = '2',
_'tool.description' = 'Create new AgentExpLink for connecting an Environment Agent to an Expectation'
class InheritanceLink extends Links
invariant linkToHimself('Object ' + inhLinkToObject.name + ' can not be a refinement of himself.'):
inhLinkToObject <> inhLinkToOtherObj;
property inhLinkToObject#objToInhLink : Object[1] { ordered };
property inhLinkToOtherObj#otherObjToInhLink : Object[1] { ordered };
source = 'inhLinkToObject',
target = 'inhLinkToOtherObj',
_'target.decoration' = 'closedarrow',
width = '2',
_'tool.description' = 'Create new InheritanceLink between Entities'
class AggregationLink extends Links
invariant linkToHimself('Object ' + aggLinkToObject.name + ' can not be a refinement of himself.'):
aggLinkToObject <> aggLinkToOtherObject;
property aggLinkToObject#objToAggLink : Object[1] { ordered };
property aggLinkToOtherObject#otherObjToAggLink : Object[1] { ordered };
source = 'aggLinkToObject',
target = 'aggLinkToOtherObject',
_'target.decoration' = 'filledrhomb',
width = '2',
_'tool.description' = 'Create new AggregationLink between Entities'
class CardinalityLink extends Links
attribute firstEnd : String[1] { ordered };
attribute secondEnd : String[1] { ordered };
property cardLinkToObject#objToCardLink : Object[1] { ordered };
property cardLinkToOtherObject#otherObjToCardLink : Object[1] { ordered };
source = 'cardLinkToObject',
target = 'cardLinkToOtherObject',
width = '2',
_'tool.description' = 'Create new CardinalityLink between Entities'
class MonitorsLink extends Links
attribute label : String[1] = 'Monitors' { ordered readonly };
property monLinkToAgent#agentMonitors : Agent[1] { ordered };
property monLinkToObject#objIsMonitored : Object[1] { ordered };
label = 'label',
source = 'monLinkToAgent',
target = 'monLinkToObject',
color = '102,205,170',
width = '2',
_'tool.description' = 'Create new MonitorsLink between an Object and an Agent'
class ControlsLink extends Links
attribute label : String[1] = 'Controls' { ordered readonly };
property contLinkToAgent#agentControls : Agent[1] { ordered };
property contLinkToObject#objIsControlled : Object[1] { ordered };
label = 'label',
source = 'contLinkToAgent',
target = 'contLinkToObject',
color = '34,139,34',
width = '2',
_'tool.description' = 'Create new ControlsLink between an Object and an Agent'
class PerformsLink extends Links
attribute label : String[1] = 'Performs' { ordered readonly };
property perLinkToAgent#agentPerforms : Agent[1] { ordered };
property perLinkToOperationNode#operationIsPerformed : OperationNode[1] { ordered };
label = 'label',
source = 'perLinkToAgent',
target = 'perLinkToOperationNode',
color = '0,0,0',
width = '2',
_'tool.description' = 'Create new PerformsLink between an Agent and an Operation'
class Conflict extends Links
invariant linkToHimself('Goal ' + conflictBtwnGoals.name + ' can not be a refinement of himself.'):
conflictBtwnGoals <> goalHasConflict;
attribute label : String[1] = 'Conflict' { ordered readonly };
property conflictBtwnGoals : Goal[1] { ordered };
property goalHasConflict : Goal[1] { ordered };
label = 'label',
source = 'conflictBtwnGoals',
target = 'goalHasConflict',
color = '205,0,0',
_'source.decoration' = 'arrow',
width = '2',
style = 'dash',
_'tool.description' = 'Create new Conflict between Goals'
annotation gmf
foo = 'bar'
and the problem is with the operation modelDepth
Current Time: Fri Apr 26 21:32:55 GMT 2024
Powered by FUDForum. Page generated in 0.02917 seconds
