Re: unable to open profiling views [message #92395 is a reply to message #91268] |
Fri, 09 February 2007 16:33 |
Originally posted by: dbassu.research.telcordia.com
Think I have the same problem - updated from the main TPTP update site
and now I can't open any of the views. Am not putting the stack trace
down since I see its just like the one you've posted.
Is there any way to revert back to the original condition or fix the
problem? Wish I could post the current set of active features/plugins in
my installation - is there a way to get that in some cut/paste view?
- Devasis
Yanroy wrote:
> Hello again,
> I've got yet another problem. I'm not sure if this is related to my
> previous one or not. I convinced the RAC to run by running it as root -
> somehow that memory error disappeared (I didn't have to run it as root
> with the old version, iirc). Now, I have a problem on the client end.
> Once I connect to the RAC, I try to open the views for execution stats
> and memory stats and I get an exception in Eclipse. I just updated my
> TPTP a few moments ago and that seems to be the cause of this. Here's a
> stack trace for the memory stats window:
> ava.lang.NoClassDefFoundError:
> org/eclipse/tptp/platform/common/ui/internal/CommonUIMessage s
> at
> org.eclipse.hyades.trace.views.adapter.internal.MemoryStatis ticViewer. <init>(MemoryStatisticViewer.java:41)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e
> Method)
> at
> sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
> at
> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
> at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
> at java.lang.Class.newInstance0(Class.java:350)
> at java.lang.Class.newInstance(Class.java:303)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
> And another for the exection stats window:
> java.lang.NoSuchMethodError:
> org.eclipse.hyades.trace.views.adapter.internal.MultiLevelSt atisticMethodViewer.setDefaultFilterName(Ljava/lang/String;) V
> at
> org.eclipse.hyades.trace.views.adapter.internal.MultiLevelSt atisticMethodViewer. <init>(MultiLevelStatisticMethodViewer.java:29)
> at
> org.eclipse.hyades.trace.views.adapter.internal.ExecutionSta tisticViewer2. <init>(ExecutionStatisticViewer2.java:63)
> Method)
> at
> at
> at
> Sorry I have so many problems... I appreciate any help. Thanks,
> Yanroy
FUDForum. Page generated in 0.03036 seconds
